GE Projection TV model # 46GW944 won't "start"
We have a GE projection TV model# 46GW944. When we troed to turn it on it came on, then there was a slight pop sound and the picture/sound were gone.
I opened the front cover to look inside. There is a small black box, smells a little burnt, when I turn the TV on and off there is a small flash and click sound from the back of this peice. There are many removeable wires entering the box. It appears everything runs into this box in order to "start" the TV.
I'm guessing this is my problem. If you agree can you tell me where I might locate a replacement part?
Thank you for your help.
Darin Erdmann
derdmann@juno.com
702-280-0623
  • 106 Answers
That is the HV distribution block. The wires running into it are thicker red wires. (There should be 4 or 5 of them). The part number is 205064. If you decide to do this, make sure the power is OFF for about 15 minutes and the unit is unplugged. There are 30000 VOLTS on those wires when the TV operating. Please rate this solution and let me know if I can be of further assistance
Posted on Dec 13, 2008
Power button lights up but tv won't turn on
Older set but pretty good set, set is prone to the HV transformer going bad but not many other issues.
Sep 03, 2012 | GE 46GW 948 46" Rear Projection Television
GE TV MODEL #52GW945---WONT TURN ON
Have someone check to see if the Horizontal output transistor is shorted==that and the high voltage transformer were common failure parts in this model
May 23, 2012 | GE 46GW945 46" Rear Projection Television
My tv attemps to turn on sound starts but when picture starts the system turns off.GE model d52gw12
This set shares the same chassis as some of the RCA models so More than likely a problem with the Horizontal deflection or the flyback transformer. Its not really something that the average person should take on and without the proper test equipment you could do more damage than good. But thats a starting point.
Aug 13, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
52'' GE Projection TV will not turn on
Called a service technician. Found bad board and wanted $437.00 I bought a new TV
Nov 12, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE D52GW12 turns off shortly after being turned on.
that model is famous for bad flybacks. It uses flyback number 265409 you can get a replacement at the following link with free online tech support that will explain how to install the replacement. Here is the link.
http://servicemanuals.vstore.ca/
Aug 28, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE Gemstar 46" model 46GW948
can you hear the starting or a noise from the back?try unplugging then put back.sound to me that you will need a tech
most probably the trippler going bad.
Jose
Aug 09, 2008 | GE 46GW 948 46" Rear Projection Television
46 inch rear projection tv bulb replacement model number 46gw944
The tubes are most likely not the trouble,sounds like you have a bad screen asy part number is 204809,must use the generic,Thomson discontuned this part.
Feb 05, 2008 | GE 46GW945 46" Rear Projection Television
1) In customer menu, adjust all video controls to center,then
increase "picture" to 3/4
2)Locate focus/screen adjust block above chassis...adjust
RGB screen controls for best mixture = B/W tracking..
Check with customer color level at minimum..should look gray.
If you turn screen controls up too much,you will see faint
re-trace lines in picture.....once B/W looks good,put color level
back to middle...................................................T.
Feb 05, 2008 | Televison & Video
Televison & Video Logo
142 people viewed this question
Top Televison & Video Experts
