Question about Haier 42EP24S 42 in. EDTV-Ready Plasma Television
Haier L26V6-A8 Screen is White
I have a Haier L26V6-A8 26" LCD TV. It has been working fine for 9 months. I just moved it to a different room and hooked my son's PS2 up to the AV input on the left hand side. It worked fine. Then suddenly the screen went pure white. It occurred as I was pushing a button on the remote, the teletext freeze button. I was doing this just to see if I could adjust the picture. I do not know if this caused the issue or was just coincidence. Now I cannot get anything on the screen, no menu, no channel changes, no display box, no input changes.... nothing but a bright white screen. I am living in England and currently have no other inputs hooked up to this TV. I do not get what happened. Any advice. I have a very disappointed son.
  • horkavi Dec 16, 2008
    I tried the power recommendation. No luck. There has to be another reason. Help
    Sergeant:
    Novelist:
  • 327 Answers
It may have just got something shorted internally due to the ps2 not connected properly in the units socket or it could also happen if over load current passed through the unit for a particular period of time and the unit could not handle that over load current and blowed its component located on the main board.get the main board checked and replace the faulty component .it will definately work.
Posted on Dec 16, 2008
  • 365 Answers
Try to reset the unit.thank you
Posted on Dec 14, 2008
  • JITHIN ANTONY Dec 25, 2008
    does the problem solved
  • 10,515 Answers
Hey,
When u on the lcd, u can only c "White" or some dostorted images,,,,any logo.......
Try to reset the LCD. that a possibility......any buttons on the remote working?
Sceen freeze , or buttons might be on that LCD working :(
Your Tv Will Default To Factory Settings If It Is Unplugged Or Loses Power To The Unit So You Will Need To Program The Settings...
    President:
  • 2,110 Answers
Ok lets try something easy. while the tv is on unplug it for 3 mins and try again. if it still does it then we have a problem in the video circuit and a repair will range 120-160.
How to fix issues whith component outputs on haier hlh26atbb 26 in. lcd ?
When you make the connection with HDMI are you changing the source or input key on the television to activate HDMI port? If you don't activate the corresponding source you connect to and leave the TV in the TV mode, you won't actually see the device you are connecting. It's possible the TV does not support the 1080P from your PS3.
Apr 17, 2015 | Haier HLH26ATBB 26 in. LCD Television
Sound but no picture
Contact any service technician. This is a very very bad symptom with LCD TVs.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 30, 2014 | Haier HL26P2 26" LCD TV
I need a code for haier L26V6-A8. I have a one for all remote and the codes don't work
Hello
Four digit universal remote codes for Haier TVs are:
0081 0216 0217 0157
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Feb 29, 2012 | Haier Televison & Video
Sharp 26'' LCD HD screen went white, sound is fine
Go ahead and try unplugging the video (yellow) cable and plugging it back in.
If that doesnt work, do you have any spare video cables try those.
Then unplug your tv for 2 mins and hope for the best.
GOOD LUCK.
CNBY
Jun 03, 2010 | Televison & Video
Tv screen is white; sound is ok
Need more information about you problem. Does the white screen appear on all functions.Does any input signal like a dvd or vcr show picture. If so, then you have a problem with signal connection coming from the television signal source, like a cable or satellite box. You need to check the connecting cables to see if they are outputting signal. Try using different cables to connect the signal source to the television. If this does not work. Try hooking up the signal source to another television to make sure you are receiving signal from them.If all this seems to be working fine and you are sure that you are using the remote control inputs correctly, you may have a problem the video input signal board on the television. You can contact PROSCAN at this web address. www.oncorpus.com. Go to customer support and ask for their technical assistance with your problem. The telephone number for PROSCAN service is 1-888-977-6722. I hope this has been of help with your problem.
Apr 08, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Olevia LT26HVE Power issues?
Finally recieved an email from syntax olevia customer support after 1 month. a standard desktop computer power cord is all you need for your Olevia LT26HVE flat screen. We lost ours in a move and FINALLY have it up and running again...for only 9 bucks at RadioShack!
Dec 07, 2008 | Syntax LT26HVE 26 in. HD-Ready LCD...
Haier 26; TV Tuner
contact the Haier Service center in NY. www.asnyonline.com
May 25, 2008 | Haier HL32BG 32 in. LCD Television
Acoustic solution lcd tv
This sounds like the unit is expecting component video input (RGB) rather than composite (yel). Check the settings on the set. The power cord makes no difference.
Keep us posted.
Dan
May 20, 2008 | Televison & Video
Haier 42EP24S 42 in. EDTV-Ready Plasma Television Logo
67 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
