Question about Singer HD-110 Mechanical Sewing Machine
Top thread bunches under the fabric
I am so frustrated with a Singer 4205 I bought last year. Periodically when I sew, the top thread bunches in big loops under the fabric. My cure has been repeaded threading of the machine, making sure I am doing everything correctly and replacing the bobbin, making sure that is loaded correctly. I am in a time crunch to finish a huge batch of doll clothes by tomorrow and this machine started doing this and I have not been able to get it to stop after many times of trying everything I can think to try. PLEASE help me. Thank you so much.
  • 4 Answers
Try switching to class 66 bobbin or adjust your tension to a higher setting. Also check your stabilizer.
Posted on Jan 04, 2015
  • 275 Answers
What you might need is a Hyrostick Stabilizer Specifically designed for hard-to-hoop items, Wet ?N? Set is an adhesive-backed stabilizer that allows you to secure socks, neck ties, bags, and karate belts so they can be easily and professionally embroidered. This unique stabilizer features a moisture-activated adhesive on the back that will hold any item in place within the hoop. It?s simple to use and only requires lightly applying moisture with a damp sponge, rag, foam paint brush, or stamp roller. Make sure the adhesive side is up. Do not over wet it.! Lay the blank item on top of the adhesive and smooth out any wrinkles. Then embroider and trim. If you need to reposition, or you find the adhesive too aggressive - simply go right to the glue line ? where the adhesive touches the fabric - remoisten it lightly! This will reactivate the adhesive and it will peel off easily. Go here : http://www.jennys-sewing-studio.com/stabilizers/stabilizer.asp
Posted on Dec 13, 2008
  • 4,806 Answers
Check that the stitch setting is correct for the type of stitch you require, also make sure the thread tension is tight enough, get a piece of rag and alter the tension till it goes right.
Check that the spool bobbin is feeding the thread correctly from underneath and that there is no trapped thread clogging the spool mechanism
kind regads
I have a 9020 singer sewing machine I bought without a manual. I can't seem to sew without looping the thread under it. Almost in knots.
Are you saying the upper thread is knotting under the fabric as it stitches? This is bird nesting or thread nesting and is generally caused by mis-threading, the thread not being seated in the tension disk, or the upper tension too loose.
When threading the upper thread, ALWAYS RAISE the presser foot. Verify that the machine is threaded correctly. If one guide is missed, the stitching will go haywire. Start out with the upper tension set around the midway point and then tweak it through test stitching.
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Dec 22, 2016 | Singer Sewing Machines
Why is sewing machine thread gathering under fabric?
adjust the tension to a appropriate setting,
See the video here.
Sewing Help Sewing Machine Problem Thread Bunching Under Fabric
The knob and its location can differ based on the model of your sewing machine.
Oct 29, 2016 | Sewing Machines
Have a Singer 11910000A and the bobber thread bunches up and makes a mess in the feet when sewing
Is it really the bobbin thread that is globbing? Check closely. Usually it is the upper thread accumulating under the fabric.
If it is in fact the bobbin thread, then the bobbin case is not threaded correctly, the bobbin case tension needs adjustment, or it is broken and needs replacement. There are web sites and YouTube videos that show how to adjust the bobbin case tension.
QUICK FIXES: Remove all the thread from the machine. Clean the area around the feed dogs and bobbin area. Oil as instructed in the owner's manual using ONLY fresh, good quality sewing machine oil (only 1-2 drops each spot). Install a brand new needle insuring it is installed correctly. Avoid using fuzzy, old, or bargain bin thread. Rethread: Be sure you raise the presser foot BEFORE threading the upper thread so it will seat properly in the tension disk--and check to make sure you are threading the machine correctly. Check that the upper tension is set properly (the factory standard is usually the halfway point between the high & low number on the selection). Test on a scrap of the fabric you wish to sew. Adjust the upper tension--either tighten to pull the upper thread toward the top of the fabric, or loosen to pull more upper thread down.
Here are some web sites that may help.
sewing machine birdnesting
https://answers.yahoo.com/question/index?qid=20100303212248AAnRUQA
8 Tips to Fix Birdnesting in Embroidery
http://www.marthastewart.com/1085057/common-sewing-machine-repair-tips
and here's another Hint that may be helpful:
https://www.youtube.com/watch?v=KDERq4I7l-Q
Dec 29, 2015 | Singer Sewing Machines
The hook casing that holds the bobbin in my Singer Inspiration 4205 will not rotate when I sew. Therefor the top thread can not pick up the bobbin thread.
there could be something wrong with the hook and hook race, it needs to be checked to see it the parts are damaged or need a adjustment
Mar 07, 2015 | Singer Inspiration 4205 Mechanical Sewing...
How to fix a hook & timing issue on singer inspiration 4205?
I would over ride the auto setting and trial and error the process by manually turning the tension my self, also it has to do with the fabric too, sometimes whatever fabric is being used tends to regulate the tensioner too, good luck
Sep 01, 2014 | Singer Inspiration 4205 Mechanical Sewing...
Bobbin thread is bunching under the fabric what is causing this?
check the needle to see if it's bent
check to make sure the needle & thread are right for the project
some sewing machine bunch under fabric when the top thread come off the thread take up lever
Sep 27, 2010 | Singer Sewing Machines
Top thread bunching under fabric when sewing
tension could be too loose. start with bobbin tension- should allow thread to pass with SLIGHT resistance. then adjust top tension at about 2-3 to start.
Jun 01, 2010 | Singer 8280 Mechanical Sewing Machine
The thread will not go into the fabric
Check the timing of the needle to the hook. Here is a guide to generic principles of Timing
http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Hook%20Timing.htm
Sep 04, 2009 | Sewing Machines
Thread bunches up under the fabric
For normal everyday fabric, tension should be 3-5.
If it is looping on the bottom, the problem is the threading of the machine. If it loops on the top then the problem is with the bobbin.
Mar 22, 2009 | Singer 3116 Simple
Singer Inspiration 4205... doesn't work!
Check the position of the bottom piece that holds the bobbin carrier to the left so it rides smoothly on the rotating hook that carries the upper thread around the bobbin. I found my wife"s machine loose so the bobbin carrier was out of position and not riding on the ledge of the rotating part. loosen two screws and push it to the left and tighten.
If upper thread bunches below the material it needs more tension so it pulls back up through the material.
If the old singers were fords this is a yugo
(been fixing and adjusting her machines for years. ))
Dec 13, 2007 | Sewing Machines
Sewing Machines Logo
191 people viewed this question
Top Singer Sewing Machines Experts
Bargain Box
Bargain Box
Mike Cairns
Mike Cairns
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
