Question about E-Machines T2898 (764296109563) PC Desktop
Headphone jack broke off inside
If I am unsuccessful at removing the broken jack from inside the port.
Can I disable the port and route the sound output on my pc elsewhere?
I have T2892 Emachine. On the back I have pink sound in port and two other green ports next to it which have a different symbol than a headphone symbol I see on the front of the computer.
I use the port to run sound out into my stereo system. 1/8in adapter end (snapped off) connects two stereo speaker jacks at the other end of the adapter.
Any suggestions?
  • 1 more comment
  • wulfeckinc Dec 13, 2008
    I have an emachine T2892 with NVIDIA nforce
    How do I mute the headphone jack and ensure sound from back of PC
    I do not have RealTEK. ( Windows XP operating system)
  • Anonymous Feb 14, 2009
    the pin cannot be removed from the jack. Can I detach the jack from the inside of the PC by pulling it off with pliers, or might that damage the computer?
  • mkumar93 May 07, 2009
    i have acer laptop.and hadephone jack broke inside the port and laptop is in under warrenty.how can i remove it.or may be change main board?????
    Problem Solver:
  • 15 Answers
Yes, you could easily open the computer and physically remove the wires from the mother board for the front audio jack. These are pin headers. Most all the time they are labeled.
The rear audio should already be working from the green jack. If not, then perhaps you have the RealTek Audio chipset and software. The realtek audio software generally has a orange speaker icon in the system tray. You can double click to open it, go to the Audio I/O tab and then click the little wrench icon. It will open the connector setting. On the connector settings screen is a checkbox. Disable front panel jack detection. Uncheck that, also a check box for Mute rear panel output when fron headphone plugged in, UNCHECK this. That should do it.
If you want to try further to remove the broken jack make sure the machine is off, use a very tiny needle nose pliers (electronic type) you should be able to pull it out.
What kind of computer do you have? You could also possibly remove the jack assembly from the inside, so you can get a better view for the extraction of the plug.
b
Posted on Dec 13, 2008
    Problem Solver:
I was lucky enough to get mine out easily but have not been able to figure out how to replace.Ii took another off another cord I had but now the sound is just faint. I just twisted the 3 wires together for temp fix.Any suggestions.
Posted on Dec 27, 2009
Headphone jack is broken INSIDE the port and is overriding the speakers. Can I override this override?
Or instead of having to open up your computer and messing with the mobo. Just use the control panel in to disable the headphone jack.
May 09, 2014 | Dell OPTIPLEX 745 PC Desktop
Broken headphone jack, no sound threw laptop speakers
change the entire jack you will get it for 200 bucks by breaking the jack you shorted out the speakers
Apr 05, 2014 | Toshiba Satellite A105-S4074 Notebook
Audio input jack for headphone component broke off need to find new input and how to replace
No way to do that unless you can figure out a way to remove the part. The contacts inside that plug determine where the sound goes. No way to turn it off unless you remove the broken part. If you feel confident enough, remove the back of the TV and remove the broken piece from the jack.
Mar 02, 2014 | LG 32LD350 32 in. LCD TV
Headphone jack has a piece of connector stuck in it and it is making my speakers not work how can i fix this problem?
You will need to remove the broken piece. Power down the computer and unplug it. The only suggestion I would have is see if you get get to the jack from inside the computer and push out the broken piece with a paper clip.
Jun 11, 2012 | Dell Dimension E510 Dual Core 2.8 Ghz...
The headphone jack broke off inside my audio port. Is there a way to get it out?
You can use a thin needle type pointer with a bend at the end like a puller to pull out the broken piece inside the jack socket.
Since there is a small hole in the jack this can be made use to hook and pull out and it will engage to come out.
Also you can hold down the PC to tap and assist while you pull out using the tool.
Aug 24, 2011 | HP ProBook 4510s FM849UT Notebook
The tip of the headphone jack broke and got stuck inside our lcd tv's headphone port. Now the tv has no sound unless you put the head phone
You need to lay the TV down on a carpet or bed, take the back off and possibly the board that has the jack to poke the tip out from the other side.
May 25, 2010 | Samsung LN-S4051D 40 in. LCD Television
My headphone jack broke inside of laptop how to
Unfortunately this can only be repaired by a shop.
Oct 30, 2009 | Acer Aspire 3050-1733 Notebook
Headphone snapped off in jack so lack of sound
If you want, you can open the laptop up and attempt to remove the broken piece.
Go to powerbookmedic.com and you'll find free pdf's on how to open up your particular laptop... It may save you some bucks!
most macs are easily opened and if you need a replacement part, their website has most available...
good luck..
k
Oct 03, 2009 | Apple Computers & Internet
you should be able to get it out from the inside on the card. Do you have a sound card or is your sound on the motherboard?
Jan 27, 2009 | Dell Dimension 8200 PC Desktop
Sound out of one ear
take it back to where u bought it and ask them
Jun 25, 2008 | Apple iPod MA446LL/A MP3 Player
E-Machines T2898 (764296109563) PC Desktop Logo
1,339 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
