Question about Harman Multimedia HKTS 11 System
Hkts11 fuse blowing off repeatedly
I have harman kardon hkts11 speaker system it was working fine suddenly its gone off, the power connection is ok, i checked the fuse(1.6A, 250 volt), its blown off, tried replacing it with new fuse, the new fuse are getting blown off too, what might be the problem,any solutions??---sachin,U.A.E
4 Suggested Answers
  • 236 Answers
SOURCE: Harman Kardon AVR 245 Receiver PROTECT Error Message/Shutting Down All Equipment
could be your receiver only, it has tripped due to discrepancy on the output stage of your amp. that cracking sound in one of your speakers could have caused the trouble. it is possibly shorted. but in your case it could have damaged already the amp that;s why it would not turn on. normally it will first trip, turn on then turns off. but to stay off and not to turn on again is major problem of the amp. or maybe it emanated from miscabling, probably the ceiling speakers got connected to a high output or main amp. but try removing all speakers first then turn the unit on. see if it does power up.
Posted on May 22, 2008
SOURCE: no sound
I had the same issue. I took it to an HK authorized repair center and they repaired it for $135. Something about a number of capacitors being blown.
Posted on Dec 10, 2008
SOURCE: Harman/kardon avr 247 no audio or LED display on the reciever
I've had the exact problem. HK in the states is no help, you need to deal with a company in Montreal (Jan Industries). Regular techs are unable to fix it without schematics that only authorized dealers have and the manufacturer. This problem happened to me just after 2 years and outside warranty. I've bought a Yamaha today.
Posted on Apr 03, 2010
My MacBook's audio still on even when harman Kardon speakers are connected to the computer.(Original version with USC connectors).
As I seem to recall the very first version was powered by the computer and as such may not be compatible with your Mac. I may be thinking of Apple's Clear speakers though? Do your HK Soundsticks have a power adapter or AC cord?
Oct 15, 2013 | Harman Kardon HARMAN/KARDON SOUNDSTICKSII...
Harman Kardon speaker jack broken. What to do
if you know how to solder you can just remove the jack and replace it with another one, of course you can ask someone else to do it at a nearby electronics store
Dec 12, 2007 | Harman Kardon Harmon Kardon SoundStick II...
Harman Kardon SoundSticks II Computer Speakers
Hello
It seems that the power supply section of your speaker systen has the fault. Check the fuse inside it. If it found blown out, never replace an other fuse in place. Check the power supply circuit board for any short circuited components in it, before replacing an other fuse.
Mar 21, 2012 | Harman Kardon SoundSticks II Computer...
What is the fuse size ( I know voltages but not proper ampage) for thr Harman/Kardon hk 695? Thank you
Greetings - You need a Radio Shack 270-1062 3/4 amp slow blow fuse or equivalent. Any .75-1 amp fuse of the same size should work fine.
Regards and Good Luck.
Thanks for using Fix Ya.
Mikeywaf
May 01, 2011 | Harman Kardon HK695 Computer Speakers
Flat screen tv stopped working suddenly hooked up thru HK230
Hi there bud , Are you sure you are using the RCA cables correctly? and not just connecting the speakers into the T.V?
Jan 04, 2010 | Harman Kardon Harmon Kardon SoundStick II...
Harman/Kardon HK395 speakers no power
there is actually a fuse in the subwoofer
Oct 21, 2008 | Dell HK395 Computer Speakers
Subwoofer
Repeated fuse blowing generally indicates a blown power supply, or blown output stages or both. One thing to do is be sure that you have replaced the fuse with the correct type. A T stamped into the metal of the fuse near the rating, indicates sloblo or Time Lag fuse. A fast blo fuse, may work once, or more times, but will never replace a sloblo fuse in this type if unit. Good Luck, hope this info helps, don't hesitate to hit me back here for more help :)
regards
Graeme
Feb 13, 2008 | Harman Kardon HKTS 7 System
Harman kardon
Orastie
Wow, general problem here, but the most near your problem could be, power failure, or the Power adapter is bad, or a energy failure at home, time to buy a new adapter.
Carl
Dec 29, 2007 | Harman Kardon Harmon Kardon SoundStick II...
Sound sticks II
My problem is fixed now. I plugged the speakers into the earphone socket. There was no immediate effect just silence. I twiddled the control on the bass unit, played with the volume controls on the sticks. Then I realised the sound was back with the external speakers not the internal ones. It was as though the Harman Kardon system was re-booting itself. Very weird.
Dec 05, 2007 | Harman Kardon Harmon Kardon SoundStick II...
Subwoofer - no sound
Had the same problem when mine first arrived. Unplug and replug the power cord at the back of the woofer. Worked for me!
May 16, 2007 | Harman Kardon HARMAN/KARDON SOUNDSTICKSII...
Harman Multimedia HKTS 11 System Logo
173 people viewed this question
Top Harman Multimedia Audio Players & Recorders Experts
Josh Whitehead
Josh Whitehead
Steve
Are you a Harman Multimedia Audio Player and Recorder Expert? Answer questions, earn points and help others
