Question about Intermatic Inc. ST01C Digital In-Wall Timer
Timer heats up
The wall timer gets very hot to the touch
  • 16 Answers
Sounds like you are controlling too much for this timer.
Posted on Jan 12, 2009
Why does the control panel on my Whirlpool electric range get too hot to touch when oven is operating at 350 degrees?
heat transference and radiated heat at that temp is normal
the stove should have an air gap between unit and wall
not pushed up against the wall
and internally insulated
check to see if your whirlpool model oven ever had a safety recall 26301150-vpuqtjtdvoowntuyvcl35auo-4-0.jpg
Oct 04, 2016 | Whirlpool Kitchen Ranges
All lights are working belt is attached dunno why ifs not filling up or moving when I switch a wash program on but make a slight buzz as if it wants work
How to Check a Washer when Is Not Filling With Water OTHER washers test similiarly
# Test procedures to follow when a GE Hotpoint washer is not filling
* Disconnect the washer from the wall outlet
* Set the timer dial on regular and pull the knob to turn the timer push-pull switch on
* Set the temperature switch to the cold/cold setting
* Open the controls panel to gain access to the water mixing valve solenoids
* Touch the 2 terminals on the cold water solenoid with your volt meter test proves. Make sure that your body don't touch the washer cabinet, this eliminate the chance of getting an electrical shock.
* Have someone plug the washer cord for you while you check the voltage
* The reading should be 120 volts
* Touch the 2 terminals on the hot water solenoid with your volt meter test proves. Remember, to keep your body from touching the washer cabinet to eliminate the chance of getting an electrical shock
Have your helper plug in the washer cord again so you could check the voltage at the hot water solenoid
* The reading should be 120 volts. If you get 120 volts, this tells you that the wall outlet, the timer, the water temperature switch cold and hot water settings are working ok.
If the GE Hotpoint washer is not filling, the problem should be on the water valve, the screen filters or the water supply
If one of the solenoids is bad you will need to replace the complete water mixing valve assembly YOU SHOULD ALSO GET AN OHMS READING OR SHOW CONTINUITY WHEN TESTED UNPLUGGED ON BOTH SELINOIDS HOT AND COLD
Mar 29, 2015 | Washing Machines
Hot center wall in refrigerator
This is more likely to a defrost heater sticking on and not turning itself off, could be either a timer, board or defrost temperature sensor issue
Apr 03, 2014 | Refrigerators
Freezer has warm spots. All around freezer is hot to the touch. Compressor is hot, coils are clean, condensor fan is running.
Thats normal.
The condenser coils are located just inside of your exterior cabinet walls on the sides and top.
So the freezer gets cold inside and heat has to be released from the condenser coils.
If this is something new, you may have a problem with the defrost timer
Sep 11, 2011 | Kenmore Side by Side Refrigerator
We have a taco timer aquastat that's pretty hot to the touch; and were not getting hot water to the house. Does it need replacing?
The pump has air in it and you need to purge out the air..
Here is a tip that I wrote about heating circulator pump problems.
It will give you the information you need to learn about your circulator pump problems and solutions for it.
Heating Circulating Water Pump Problems
Aug 20, 2010 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
2006 pontiac grand prix, heat only gets warm not hot
Have you checked the coolant level? If that checks out ok... With the engine fully warmed up touch the heater core hoses where they go into the fire wall (about the center of the firewall). They both should be pretty hot to the touch. You'll likely find one hot and one warm. If this is the case flushing the heater core will likely get your heat blowing out hot again.
Mar 07, 2010 | 2006 Pontiac Grand Prix
Ceiling fan controled by intermatic e1010/e102 doesn't come on
If you are getting heat on the timer it is time to replace it
Jul 28, 2009 | Hardware & Accessories
Kenmore Dryer Model 110
If all of the components are reading ok then you need a timer. Touch your 2 leads together. 0 ohms rght. That means you have a complete circuit.If you get the 0 reading then the element must be otay. Bad timer. Take that fancy meater of yours and atttach one of them leads to the timer leg marked RH. Yank the wire off the terminal beore you test. Move the timer around. You should get the famous 0 reading along the way. If you don't then that means you have the bad timer.
Feb 04, 2009 | Kenmore 62602 Electric Dryer
Intermatic EJ500 gets VERY HOT on metal portion around timer
Sounds like you have too much load. The device is using its heatsinks like they were designed for. To dissipate heat.
Dec 14, 2008 | Intermatic Inc. EJ500C Digital Wall Switch...
Outside wall on freezer side is hot to the touch
clean your condenser coils under the frig,your over working with dirty coils and it is over heating-mike
Oct 18, 2008 | Samsung RS2630SH Side by Side Refrigerator
Intermatic Inc. ST01C Digital In-Wall Timer Logo
176 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
