Question about ASUS MyPal A730 Pocket PC
Restoring information on pda from backup
I recently flew longhaul and my battery was removed. When I switched it on again it attempted to restore the info but something went wrong. (possibly the battery was flat) When I was able to reset it - all info has disappeared and it's back to square one. I have a backup on my SD disc but the filename doesn't show when I get into the Asus Backup.I can't type in a file name - it won't let me. Is there some way of doing this? I have also tried to connect to my active sync on my computer which has files backed up but it doesn't recognise the pda and I am not sure what I called it last. When I looked at the file it had my first name and surname (last name) on it so I have renamed the user using the same again. Help!!!! How do I restore all the info from my backup?
SOURCE: ASUS MyPal A626 Wouldn't boot
thank you this helped me repair my A626
Posted on Aug 21, 2008
SOURCE: Hardware buttons does not work anymore...
My Asus A639 is also frozen on the blue Heart of Technology screen AGAIN. None of the buttons work, hold button is not active, cannot switch it off. The first time it was fixed by Asus under warrantee - took 5 weeks. The freeze might be related to using GPS software Copilot V6 - not certain.
Help please - how do I do a total reset?
Posted on Nov 08, 2008
SOURCE: Sound Problem on ASUS A636N
The problem is related to TomTom software. There are two methods to solve this problem.
(1) You can choose to install TomTom 6.1 which has solved the sound problem if TomTom V6.1 is available for end user.
(2) Find “BtCoreIf.dll”in Windows directory and rename it to "BtCoreIf.old”. Then, reset the device to solve the sound problem.
Posted on Apr 23, 2009
SOURCE: My ASUS A626 pda won't turn on. Screen dark
Next to the headphone jack, on the longer side, you will find a "HOLD" slider switch. It is presently showing red, meaning engaged. Push it back to the off, or normal position. This will release the lockup.
Posted on Sep 05, 2009
  • 6 Answers
SOURCE: Asus A639 wont start
Solved the same problem after it was bloking at boot screen
Pay attention to the way you format the card before starting firmware upgrade, look here : :
http://itbits.tk/en/hardware/asus-mypal-a639-rewrite-firmware
Posted on Jun 19, 2011
I need to change my password but my 5s isnt allowing me to do so
Go to iphone setting - then passcode or touch id & passcode. now tap on change passcode and then enter your old passcode and then new passcode. And if you forgot your passcode and your ipod iphone disabled and you want to unlock disabled iphone ipad.
here is the detail procedure
First method you can restore your ipod. But this will erase all your data on ipod. So if you have recent backup then go for restoring ipod. For that just connect your ipod to computer- then open itunes. Make sure you have installed latest itune version otherwise update your itunes first. Now open itunes then find your ipod under deivce tab at the top left sidecorner. Click on your ipod icon. Click on summary and then click on restore.
You can also restore your ipod from old backup also. For that open itunesfind your ipod under device menu. Now select your ipod and then right click on your ipod the you will get options for restore from backup.Select restore from backup this will provide list of all your previous backup on that computer itunes. Now select your backup which you want to restore and then click on continue. Once your restoring is completed your ipod will shut down and then again restart your ipod it will take few minutes to start up. And it also asks few information about you. Once you complete all that procedure your ipod is unlocked which was disable or locked due to wrong passcode.
Dec 26, 2016 | Apple iPhone 5S
How can I unlock a passcode?
If you repeatedly enter the wrong passcode, your iPhone will be disabled for longer intervals before you can try again. After too many unsuccessful attempts, you won't be able to try again until you connect it to the computer with which you last synced it [if it has been synced to a computer].
Note: You can configure your device to erase itself after ten consecutive incorrect password attempts. This setting is off by default. It can be turned on by tapping Settings > General > Passcode Lock.
If you cannot remember the passcode, you will need to restore your device using the computer with which you last synced it [or iCloud]. This allows you to reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced with the device, you will be able to unlock the device for use and remove the passcode, but your data will not be present.
Please also note that Apple representatives can't unlock an iPhone for you without restoring the iPhone, either. The restore process will erase everything on it.
Apple's official instructions to restore an iPhone with iTunes are:
  1. Connect your iPhone to your computer [that you have previously used to sync the device].
  2. In iTunes, select the iPhone in the "devicess" list, then "Summary" at the top of the screen.
  3. If iTunes doesn't automatically synchronize your iPhone, do so manually [and confirm that the sync and backup were successful.]
  4. Click "Check for Update." iTunes tells you if there is a newer version of the iPhone software available.
  5. Click Restore. Follow the onscreen instructions to complete the restore process. When restoring, it is recommended that you [again] backup the iPhone when prompted.
  6. When iOS Setup Assistant asks to set up your iPhone, choose "Restore from iTunes backup."
  7. Select your device in iTunes and choose the most recent backup of your iPhone.
After this process, your iPhone should be restored with the information from its last backup, but it no longer will have the passcode enabled. It would be wise to think carefully before setting another passcode or using the passcode feature again.
Apr 04, 2016 | Apple iPhone 4 Black Smartphone
FORGOT PASSWORD
If You Are Locked Out, Have Forgotten Your Passcode, or Just Need to Restore Your Device
If you have forgotten your Restrictions code, then follow the instructions
below but DO NOT restore any previous backup. If you do then you will
simply be restoring the old Restrictions code you have forgotten. This
same warning applies if you need to restore a clean system.
A Complete Guide to Restore or Recover Your iDevice (if You Forget Your Passcode)
If you need to restore your device or ff you cannot remember the passcode, then you will need to restore your device using the computer with which you last synced it. This allows you to reset your passcode and re-sync the data from the device (or restore from a backup). If you restore on a different computer that was never synced with the device, you will be able to unlock the device for use and remove the passcode, but your data will not be present. Refer to Updating and restoring iPhone, iPad and iPod touch software.
Try restoring the iOS device if backing up and erasing all content and settings doesn't resolve the issue. Using iTunes to restore iOS devices is part of standard isolation troubleshooting. Restoring your device will delete all data and content, including songs, videos, contacts, photos, and calendar information, and will restore all settings to their factory condition.
Before restoring your iOS device, Apple recommends that you either sync with iTunes to transfer any purchases you have made, or back up new data (data acquired after your last sync). If you have movie rentals on the device, see iTunes Store movie rental usage rights in the United States before restoring.
Follow these steps to restore your device:
1. Verify that you are using the latest version of iTunes before attempting to update.
2. Connect your device to your computer.
3. Select your iPhone, iPad, or iPod touch when it appears in iTunes under Devices.
4. Select the Summary tab.
5. Select the Restore option.
6. When prompted to back up your settings before restoring, select the
Back Up option. If you have just backed up the device, it is not necessary
to create another.
7. Select the Restore option when iTunes prompts you (as long as you've backed up,
you should not have to worry about restoring your iOS device).
8. When the restore process has completed, the device restarts and displays the Apple
logo while starting up:
After a restore, the iOS device displays the "Connect to iTunes" screen. For updating
to iOS 5 or later, follow the steps in the iOS Setup Assistant. For earlier versions of
iOS, keep your device connected until the "Connect to iTunes" screen goes away or
you see "iPhone is activated."
9. The final step is to restore your device from a previous backup. If you do not have a
backup to restore or have forgotten your restrictions passcode, then restore as New. If you are restoring to fix a forgotten Restrictions Code or as a New device, then skip Step 9 and restore as New.
Feb 13, 2014 | Apple iPod nano 5th Generation
My phone wants to shut off at any given time
Has the phone been jailbroken? If not, which version of the OS does it run? It might be a hardware problem, maybe the battery, but hardware problems are pretty hard to troublesolve without the phone in hand and proper tools. If it's a software problem there might be a fix. Have you tried restoring it? Beware before doing so though, everything on the phone will be erased. So backup everything before you attempt this, you can backup with iCloud on the phone itself, just turn it on and connect the phone and open iTunes "Settings->iCloud->Storage&Backup" Remember to activate Wifi for iCloud to work.
Restoring iPhone to it's factory settings: Install itunes->Connect iPhone->Select your phone when it appears in iTunes->Click the summary tab->Click the "restore" button->After the restore the iPhone should restart.
Aug 06, 2013 | Apple iPhone Cell Phones
Switched my iphone 3 on today and all i got was the logo apple cant do anything els with it what the problem
Using the Restore function for your device is part of standard troubleshooting procedure. Restoring your device will delete all the data from your device, including songs, videos, contacts, photos, calendar information, and any other data. All settings are restored to their factory condition.
Whenever you restore your device, Apple highly recommends that you perform a sync prior to restoring to back up any changes since your last sync. If you have movie rentals on the device, see iTunes Store movie rental usage rights in the United States before restoring.
Use the following steps to restore your device:
  1. Make sure you have the latest version of iTunes installed and running before attempting to update.
  6. When prompted to back up your settings before restoring, select the Back Up option (as seen in the image below). If you have just backed up the device, it is not necessary to create another.
  7. Select the Restore option when iTunes prompts you (as long as you've backed up your device, you should not have to worry about restoring your phone).
  8. Once the restore process has completed, the device restarts and displays the Apple logo while starting up:
    iPhone only: For the iPhone only, after a restore, the iPhone displays the "Connect to iTunes" screen. Keep your device connected until the "Connect to iTunes" screen goes away or you see "iPhone is activated." If iTunes does not have an Internet connection, you cannot complete this step.
  9. The final step is to restore your device from a previous backup. Once your device is restored and-in the case of the iPhone-in the process of activating, you should be able to see the following in iTunes:
    Select the backup you want for your device and select the Continue button to complete your device's restoration.
If you do not want to restore from backup, select "Set up as new..." If you want to preserve previous backups that iTunes has made, be sure to back up the appropriate directory before choosing to set up as new.
Aug 12, 2011 | Apple iPhone 3G
My computer crashed. I have a backup of all my Palm files but am having trouble recovering them. Does anyone have instructions on how to restore backup files on a Palm Tungsten E2?
Hello.
Palm backups are located in the following directory: C:\Program Files\Palm\username>\ED\Backup\
When you HotSync a PDA that has undergone a hard reset, HotSync will compare the two devices. When it sees that the PDA is empty, it will attempt to reload any backup that exists on the PC. Once this data is reloaded, the PDA will ask to do a soft reset. This is simply a restart of the device and doesn't affect any of the newly installed data. This returns the PDA to working order, with all the data and programs functioning as they were before.
Hope this resolves your problem.
Jan 23, 2011 | Palm Tungsten E2 Handheld
Restore information
I can understand you very well since I use a PDA also and this battery problem is an issue for me too. I assume that your backup file is in your storage card and is a standalone exe file (means you don't need your backup software being installed first to start a recovery process). You can remove your storage card from your PDA first and back it up to a PC to ensure that your only backup file is safe. Next, you can do another hard reset to your PDA and do all the settings steps again. After that, you can try to recover some of your data by starting the recovery process and performing not a full backup, but just the necessary data first. I am recommending this step because you have a PDA that's main storage area is very limited (like mine) and if you are normally using it filled up, backup process can be terminated before it finishes because of the backup file is nearly equal to the total main storage area,  and this causes your device to stop working even after your incomplete recovering process. This is mainly becuase recovering process needs lots of space and when the process is near the end, it can't have enough space on main storage area to continue. So, you can try to recover the necessary data first (Softwares, contacts, appointments, ...), then, if it is successfull, you can open your backup file again and this time you can select the other personal documents that has been left in the first process. (I hope your backup software supports selecting the needed data to recover.)
Apr 13, 2009 | i-mate Pocket PC
Nov 17, 2008 | ASUS MyPal A636N Pocket PC
Restoring SD Card from ActiveSync Backup
I am fairly sure that you are out of luck. The Active Sync backup does not backup SD card data.
Sep 08, 2005 | HP iPAQ H2212
Backup and restore data
Section A - How to use a Toshiba Pocket PC e740 without loss of data: Never let the battery fully discharge. Never disconnect the battery from the e740. Regularly backup your stored data. Always connect the product to an external power source before changing the battery. Section B – How to backup your data: B1 – Using Activesync You can make a backup of the Toshiba Pocket PC e740 data to your notebook or desktop computer. If you have backed up your data to your notebook or desktop you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended. The following types of data can be backed up: FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program. REGISTRY: Setup information of Windows or programs. DATABASE: Database information from Pocket Outlook. When making a backup or restoring data please DO NOT remove the Pocket PC e740 from the USB cradle and DO NOT turn off the power to the device until the backup or restore is completed. Backup Instructions: Insert the Toshiba Pocket PC e740 into the USB cradle. A connection between the e740 and your notebook or desktop will be established. Please close all active applications on the e740. On your notebook or desktop start Activesync and select Tools and then Backup/Restore. Select Full Backup. Select Back Up Now to start the backup process. B2 – Using a Compact Flash (CF) or Secure Digital (SD) Memory Card: a) How to insert a Compact Flash Memory Card: Ensure the e740 is connected to the mains. Turn the e740 off. Remove the dummy card if necessary. Confirm the direction of the Compact Flash memory card by lining up the side grooves of the card and groove edge of the card slot. Insert the card smoothly and completely. b) How to insert a Secure Digital Card: Ensure the e740 is connected to the mains. Turn the e740 off. Remove the dummy card if necessary. Insert the Secure Digital card with it’s contact surface (the metal contacts) facing the back of Toshiba Pocket PC e740. Press the card down until it clicks. You can make a backup of the Toshiba Pocket PC e740 data to your Compact Flash or Secure Digital memory card. If you have backed up your data to your Compact Flash or Secure Digital memory card you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended. The following types of data can be backed up: FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program. REGISTRY: Setup information of Windows or programs. DATABASE: Database information from Pocket Outlook. When making a backup or restoring data using the DataBackup program please DO NOT remove the Compact Flash or Secure Digital card from the Pocket PC e740 and DO NOT turn off the power to the device until the backup or restore is completed. Backup Instr
Sep 07, 2005 | Toshiba e740 Pocket PC
ASUS MyPal A730 Pocket PC Logo
78 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
