Question about Epson Stylus C60 InkJet Printer
Get an error message when trying to print test page
I have a epson stylus C60 printer I just plugged into a laptop USB using Windows Vista. Windows recognizes it and says it is installed but when I go to print a test page I get an error message. Alos when I go to capture the port I also get an error message. Yet, I can get the printer to print nozzle check.
  • Anonymous Jan 07, 2009
    I have replaced the black ink cartridge and tried to get my printer to print but it won't. Please help!!
  • Gerry Millward
    Gerry Millward May 11, 2010
    Have you tried uninstalling than reinstalling after a reboot?
    The query by the "other user" is a completely different problem. Please open a separate post.
  • 353 Answers
Please uninstall your printer then reboot the computer. Make sure your printer is switched off, then insert your printer installation disk and follow the instructions. Do not turn the printer on unntil asked to.
Please post a new comment if you need further assistance.
Posted on Mar 05, 2009
Green light flashing Red light on
with regards to the status of the lights., its either the cartridges that you installed is not recognized by the printer's print head or cartridges are defective.
try these steps:
if all the inks are new take them out and get an eraser and rub the small chip gently so as to clean the contacts of the chip ( don't touch it with your finger ) reinsert the cartridges in the printer and allow it to charge.
Apr 07, 2009 | Epson Stylus C60 InkJet Printer
Epson c60 printer not compatable with windows vista need a driver but have no idea where to download it
The driver for the Epson C60 printer is included with Vista - all you need to do is connect the printer to the computer with Vista running and turn it on. If you have already done this and the printer does not work properly (but see the info about the Status Monitor below), turn the printer off, uninstall the printer using the Control Panel-Programs and Features-Epson Printer Software, then reboot the computer. Once Vista is running, turn the printer on and it should then install OK.
HOWEVER, the printer Status Monitor (SM) is not included in this process and if you try to install the XP version of the SM, it will not work. Epson appears to have no intention of remedying this problem. This means you have no means of monitoring your ink levels, nor of changing the cartridges, cleaning the heads etc via the computer, although some of these tasks can be carried out via the printer control panel (see your hand book on how to do this).
A good solution is to use the free SSC utility as your SM - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C60), then close the ssc window. Now right click the ssc icon in the sytem tray and choose the SM function you wish to use.
If you have any further queries on this, please post a new comment.
Oct 23, 2008 | Epson Stylus C60 InkJet Printer
How do I clean and maintain my Epson Stylus C60printer?
Kesha,
In order to find out if it will work you have to get new cartridges so the printer can print. The printer can sense if the ink is to low and can cause it not to work correctly.
Hope this helps
Jul 16, 2008 | Epson Stylus C60 InkJet Printer
Epson c60 not compatable with windows vista
I have an Epson C60 and Vista has the neccessary drivers in box. When Vista is running just connect your C60 and it will do the rest.
I have so far had no problems. The only thing that I can see is missing is the option to preview via the printer software.
Mar 20, 2008 | Epson Stylus C60 InkJet Printer
Not printing.tried everything i think
Sounds like print head issue; have it serviced or u can try this :
How to Unclog Epson Print Heads
Jan 11, 2008 | Epson Stylus C60 InkJet Printer
Epson Stylus C60 InkJet Printer still not printing
what is the connection? USB or parallel ? Try1. Disconnect the printer. Unistall the software and driver. Restart the computer. Now re installed and follow precisely the commands. Come off line Disable A/V software Do not connect printer untill prompted. Try2 Go to printers and faxes Click on install printer When asked CD or select from List - take select ftom list. Select the Make. Select the model. Make it the default printer. Try 3. Go to www.fixyourownprinter.com
Jun 29, 2007 | Epson Stylus C60 InkJet Printer
MY Epson Stylus C60 wont print
This means that your printer is trying to print from the wrong serial port connection, as your printer should be connected via a USB cable. Go to start>control panel>printers and faxes. Double click the printer and faxes icon and your Epson printer icon should be there and set as default with a tick next to it; right click on the icon>properties and then at the top of the next window, click on the tab that says ports and a list of ports will be there and the one that should be ticked should be USB001, and not LPT1 as it will be show, press ok and close windows and restart the pc.
Epson Stylus C60 InkJet Printer Logo
70 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
