Question about Coby DVD-224 DVD Player
Squished Picture My dvd player has a squished picture (i'm not sure how to describe it)...i don't know what to do to fix it...if you had ideas that would be GREAT...thanks
  • Valerie Schiller
    Valerie Schiller Apr 14, 2007
    I tried that...didn't work...it might have something to do with the Magnavox TV though...if you know anything about those, i would appreciate advice. Thanks!! :)
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
The best way to address a dvd problem is to call the 800 number of the company that made the unit. Have them work on the problem first. You can try connecting the dvd player to another set and see if you have the same problem. Next use a different type of connection to the set.
Posted on Apr 17, 2007
  • 97 Answers
Go to the picture settings with no disc in unit. Deselect 16x9/wide/stretch mode (depending on your player, it will be one of these).
Posted on Apr 12, 2007
SOURCE:
Picture is squished short, curved, and too wide
This sounds like either a convergence or pincushion problem.
Mar 29, 2014 | Televison & Video
Toshiba cf2662b the picture is "squished" Hoe do I adjust the vertical size and linearity? Thanks.
Most likely your tube is burning out. If there are any adjustments at all to fix this it will be in the menu under picture setting.
Mar 02, 2014 | Televison & Video
All I get is a squished picture in the middle 40-50 percent of the screen. The top and bottom parts are black. Also, in using my remote's up/down buttons, all I get are channels 2 to 13. If I press channel...
Are you by any chance using Closed Caption?
The channels that do appear are they full screen?
How about what the picture is on a DVD through the Video inputs.?
Please fill us in on these suggestions.
Sep 29, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Last lines on page printing squished
It is a problem with the drive train. It is not finishing the feed process. Or it could be the toner. Try replacing the cartridge and see if that helps.
Jul 07, 2010 | HP Office Equipment & Supplies
Hi there When I shoot in 16x9 widescreen with my Canon XL1 the viewfinder shows the same image as when shooting in 4x3. Can this be adjusted. Regards John
It is not showing the same image, it is showing the 16x9 squished down to the 4x3 aspect ratio. I thought I had the same thing at first too. But to check & make sure set up a shot of something square in one or the other shooting ratios. Then go into the menu & set it up on the 16x9 on/off. To make it easier to see the picture hook up to a monitor to see the picture without squinting through the eye piece. Now while you are watching the picture switch the 16x9 on & off on the camera. If you started in 16x9 the square will lengthen from side to side in 4x3, while the square in 4x3 will become squished on the sides. If you can't tell, take a piece of tape [removable tape that is] and make the sides of the box before & after you change the aspect ratio.
Apr 29, 2009 | Canon XL1S PAL Mini DV Digital Camcorder
The RDR-VX535 does not transfer the 1:33 aspect ratio from VHS to
Did you try the unscaled option, that sould fix the issue.
Apr 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Fuzzy picture, oval shaped, scrolling up slowly
I would start by checking the large filter capacitors in the power supply. I can't be sure since I'm not seeing the set, but it sounds like you're describing AC ripple. In a 20-year-old set, some of those electrolytics will be drying out. A few replacements may take care of the trouble for you.
Jan 01, 2009 | Panasonic PT-56WXF95 56" Rear Projection...
Jpeg images are all squished up
The jpeg images will have to be resized using PhotoShop or another image editing program in either a 4 to 3 proportion, or a 16 to 9 proportion - whichever format you want to stick with. Then reburn the images to disc.
-Tha Mp3 Doctor
Mar 17, 2008 | Philips PET710 Portable DVD Player
How do I adjust the picture, I lost my remote..
Sorry Bud you cant. An original remotes available at http://www.remotes.com or 1800-remotes for about $61.00 + shipping. Without seeing a picture Im not even sure if thst will help ya man. If you wanna try to see if an alighnment will help then get the remote. I would advise you against doing any sort of technical alighnments as this set has high voltage around inside even afterv its been disconnected for a while. Good Luck
Jun 09, 2006 | Hitachi UltraVision 55HDS52 Television
Coby DVD-224 DVD Player Logo
41 people viewed this question
Top Coby Televison & Video Experts
Steve Allison
Steve Allison
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
