Question about Philips 42PF9631D 42 in. Plasma Television
TV will not turn on, the light goes from green to red.
My Philips Plasma 42PF9631D/37 will not turn on, the light goes from green to red and then blinks 7 times. The TV is only 2 years old, I have tried everything from unplugging to putting in code 062596 and then press menu button (do this in a quick motion, not letting it time out while keying). I have also heard that it could be a fuse, if so how much would it cost to replace? Any help in this matter would be great.
  • 1 more comment
  • DHADDOX Dec 25, 2008
    TV NOT QUITE 2 YEARS OLD AND SAME MODEL DOING SAME THING AND GETTING WORSE!!!!! MY HUSBAND IS NOT HAPPY AND VERY DISAPPOINTED IN PHILIPS --WHERE IS THE POSSIBLE FUSE IN THE TV?
  • WDSBIGDOG Feb 09, 2009
    I have the same problem with my Philips 42" TV w/ amber light. I pulled mine off the wall and removed the back.cover.
    Where exactly are the 2 cap's located and do you know what the model number, color and size of the capacitors?
    Is this the main board or the one that is to the left side under a cover plate?
    I traced the power wire from P/S block and see the wires going to the main middle board is this correct?
    Thank you for all of your help,
    Wayne
  • hituamin Apr 12, 2009
    same as above
    Welcome Back:
    Visited the website for 2 consecutive days.
I own the same model. You have 1-2 Blown Capacitors. Take off the back cover, And look towards the center of the main power board. Look towards the center of this, and there are 2 capacitors side by side. You should see them swollen at the tops, even maybe a little black residue that has come out. I soldered on 2 new ones, and bingo! I would suggest replacing them both.
Posted on Jan 11, 2009
When I turn on my tv the green light comes on and it starts ticking antiquing and I won't turn on
Posted on May 07, 2011
Blinking red light and tv will not turn on.
problem on power supply , u may have 2 bAD capacitor
Apr 14, 2010 | Philips 42PF9631D 42 in. Plasma Television
Philips 42pf9631d/37 6 slow red flashes and 3 fast
6-7 blinks means there is an issue with the power supply...
I found a replacement for my 42pf9631d/37
Part # Lj44-00117A
at TSM Inc. for $110.95 with free shipping...
http://www.tristatemodule.com/p-10120-lj44-00117a-samsung-tv-module-power-supply.aspx
Jan 28, 2010 | Philips 42PF9631D 42 in. Plasma Television
Philips 42PF9631D 42 in. Plasma Television TV wont turn on..I get the initial green power light, but it quickly goes to a flashing red light (flashes a series of 4 times). Philips tech support is a joke....
Philip have alot power problems with their tv.Check power board for puff up parts like Capacitors,or rust in cracks or soldering.Changes parts or the whole power board.
Jan 08, 2010 | Philips 42PF9631D 42 in. Plasma Television
One minute its good, the next i get nothing.
There is a eletronics parts thats has a cold solder on it. Maybe there is a cable or wire is barely touching on the connector inside the main pcb board. See technician to check your tv. Don't let this problem will continue, bacause some of the electronics will be damage.
Jul 24, 2009 | Philips 42PF9631D 42 in. Plasma Television
Bad power supply
Hi, 9 times out of 10 it will be the capacitors on the power supply board,easy job if your handy, dear as hell if you put it in a shop
Jul 14, 2009 | Philips 42PF9631D 42 in. Plasma Television
Replacing the Y-MAIN or Y-SUSTAIN Board in Philips 42PF9630A/#&
I called PTS 1-800-844-7871 they told me it was an easy fix. The part is $162.75. Im gonna try it.
Jun 27, 2008 | Philips 42PF9631D 42 in. Plasma Television
Philips 42PF9631D 42 in. Plasma Television Logo
594 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
