Bendix WDB1043M stops after spinning and does not proceed to ...
...the next cycle. The electronic module knob needs to be rotated then manually to activate the next cycle.., which is rinsing, Is the Electronic module at fault ? Where I am supposed to get any parts for this model. I live in Canada.
Greg
Thank you.
3 Suggested Answers
SOURCE: WDB1043M Bendix Washer/Dryer
I had the same problem. Then I discovered that the Bendix USA WDS1043 / WDC1024 is the same, or almost the same, as a Splendide Comb-o-matic 6000. You can find an extensive parts manual at
http://www.splendide.com/service/Combo_PartsBreakDown.pdf
and an owners manual at http://www.splendide.com/manual_wdc1024m.pdf
I think Splendide is still in business, in which case they may also be able to supply parts for the Bendix WDS 1043 M - check them out at
They can also supply a replacement washer/dryer combo when your present unit finally dies.
Good luck with a great washer combo!
Colin
Posted on Aug 13, 2008
  • 343 Answers
SOURCE: Hotpoint Electronic 800 WM 12 Aquarius won't rinse
If it won't rinse because it won't fill, it's most probably because the cold water inlet valve is faulty. Many machines will only rinse with cold water....No cold water.....No rinse!! Not a big job.....Nomess
Posted on Apr 18, 2010
Tricity Bendix AW1260W - drum won't turn - 5 beep error repeats
Washer motor control board failure is the likely problem, also check all connectors for signs of burning. Also test the washer motor.
Apr 24, 2017 | Tricity Bendix AW1260W Front Load Washer
My washer runs non stop on the wash cycle...it washes the clothes but doesn't past the wash cycle...doesn't drain, rinse or spins. What can I do?
Can you manually rotate the timer control to the next steps?
Will it proceed thru the cycles when you rotate the timer manually?
If so, then you can complete the cycle manually for the time being...
If so-- then the clock motor that drives the timer.control is not advancing it.
If yours is a newer machine with all digital controls, then I suspect something wrong in that controller, too-- But I do not have any idea of how to 'advance it manually!
(The blessings of modern controllers!-- Give me the old clock motor driven drum controllers! :-) )
Mack B
Dec 28, 2010 | Washing Machines
Drum will not spin
I am the new owner of a used Asko Cylinda 10504.
The last owner briefly demonstrated the washer starting a wash cycle and entering the agitation cycle of the wash before stopping and pumping the water out and spinning in a final end cycle. I bought it. I had the machine installed turned it on and cannot get it to go through the wash cycle. After starting at #1 it goes through a perpetual spin cycle of sorts--water and soap soaking the drum and laundry but not enough water to fill up half way or less. It stops at number 4 on the program knob sits on a red dot (next to the #4) and does nothing. I then manually move it to the next cycle and it repeats the spin cycle again until I have advanced the program to the end. No wash cycle no rinse cycle. Nothing. When it advances to the red dot I wait for at least 5 minutes before manually advancing the knob. The instructions say that I should get the water pumped out by turning the program knob to #7 or #9 but in both cases it just spins and does no empty or finish in the end spin cycle of several (9?) minutes. Nothing but banging and spinning. The water seems to get into the drum as well as the detergent but nothing else is happening.
No mater where I start the program it spins and sloshes soapy water, pumping almost nothing out.
Any suggestions short of putting it on the curb or paying a kings ransom to fly a tech out to look at it?
MY GUESS.
It seems that it is repeating the same brief cycle over and over. During the move to my house the electronics re set(??!?!?) and now need to be set to the normal mode after being re connected?
Can you help?
Blessings,
Douglas
May 20, 2009 | Asko Washing Machines
Bendix WD1043 model RV washer/dryer --all cycles work except for the spin-out cycle, starts to spin but then stops and just sits there....the belt is OK, I looked.please advise further....thanks, Jack
KENMORE RV WASHING MACHINE WATER LEVEL DID NOT STOP. IT JUST KEPT GOING & OVERFLOWED. DOES THIS MEAN THE ELECTRONICS NEED REPLACING OR THE ENTIRE MACHINE.
Aug 15, 2008 | Washing Machines
Colin
Jul 28, 2008 | Tricity Bendix WDR1040W Front Load Washer...
Have you taken the back off the machine? It is relatively simple to do. This happened to ours (exact same model) and there is a brace arm that comes from the right side of the machine (when looking at the back) and it braces the drum. It could have broken off and needs to be welded back in place. We are currently having another issue with our machine that may be a bad motor or a bad circuit board and has once again caused it to stop spinning. The part my husband welded back together is still well attached.
Jan 09, 2007 | Tricity Bendix WDR1040W Front Load Washer...
Final agitation and spin do not happen, timer does not stop
check your knob and sleve on the timer to see if they are the right ones or if they line up. if they doit might be the pin in side the timer.or it might be faulty. another suggestiion is check everything out twice. good luck
Nov 20, 2006 | GE WBSE2090A Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
