Dark screen with dull image in background
My inspiron 9300 never gets bright it stays dark but a dull image could be seen in the back ground.
I had the screen and inverter replace with new one the problem still exist, when its hooked up to a external monitor is ok.
What could my problem be.
  • kbkkw7327 Dec 14, 2008
    The orignal screen was removed after it would lightup for a 1to2 second and then go dark with the dull image in the background.
    New screen was put in place along with the a new inverter this screen would not light up at all all that is visable is the Dull image in the background.
    After taking it apart again and looking at the numbers on the back, the numbers on the old # is LP171WX2 17.0" (TL)(A1) wxga +
    The numbers on the old # is LP171WX2 (TL) (B2) this is leading me to believe that the new screen is not the wright screen for the this laptop what do uoy thing.
    kbkkw7327
    Sergeant:
  • 237 Answers
You may need to check your desktop image for your monitor and change it to something lighter
The external monitor usually uses your computer's default and not ncessarily the one from your laptop monitor
Without taking it apart myself, it could be some wiring from the laptop to the screen
Posted on Dec 13, 2008
Dell Inspiron Screen Gets Darker
your screen might need to be replaced. soon you wont be able to see anything. replacing the screen should be an ez fix
Feb 28, 2014 | Computers & Internet
On my Dell E193fpc monitor, the background lighting goes off after a few seconds. The actual Screen-image is still there (can be seen in bright sunlight). How can I get the backlighting to work proper
This sounds as though there might be a problem with the inverter (this is a component that supplies a high voltage for a tube(s) that illuminate the screen.
As there are high voltages on inverters, this is really a job for a repair shop.
Dec 11, 2013 | Dell E193FPC 19" TFT LCD Flat Panel...
Image very dark
go nto the main setting and clear everything and reset it you will have to start from new but the brightness will improve
Apr 29, 2013 | Optoma MovieTime DV10 Multimedia Projector
Vizio lcd flatpanel tv with dark background
If half screen is affected it will be either a board (LCD and Plasma have different names) but in those one board drives each side of the screen unit--worst case is the display panel itself which is fatal from a cost point of view.
May 25, 2012 | Vizio VT Televison & Video
Leapster 2 screen to dull to see
The leapster 2 screen is so dull you can hardly see the writing and programs. Very dark in colour. You can see colour arounf the edge of screen but the darkness overpowers the screen.
Jun 06, 2010 | LeapFrog Leapster 2 Learning System
No brightness to the screen background is dark.
Take the laptop into a darkened room.
Does the correct image show, but very dim ?
If so, then the "back-light" in the LCD has failed.
It's about a $20 part, and it will take a qualified technician less than one hour ($60?) to disassemble the laptop, replace the part, reassemble, and then test the laptop.
Nov 19, 2009 | Dell Inspiron 2200 Notebook
Numerous, bright, multi-colored vertical lines on 9300 screen
Try taking out the Ram memory first one stick at a time. Sometimes when Ram goes bad or overheats, it first affects the display. If that is not the issue, here is the link to your service manual.
http://support.dell.com/support/edocs/systems/ins9300/sm/index.htm
Oct 09, 2009 | Dell Inspiron 9300 PC Notebook
Background ghost like images
CHECK IT IN THE DIFFERENT ASPECT MODES. IF THE IMAGE STAYS IN THE SAME PLACE REGARDLESS OF ASPECT. THEN YOU HAVE A LCD PANEL PROBLEM. PANEL WILL HAVE TO BE REPLACED.
Feb 27, 2009 | Televison & Video
Display is dark
try to adjst the brightness and the contrast..
Feb 21, 2009 | Dell Inspiron E1505 Notebook
Screen went dark (almost completely)
check your power cord and make sure it's plugged in all the way, and if it is, check your brightness setting.
Usually it's the Fn key + an arrow key. Make sure the brightness is up all the way
Dec 12, 2007 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
138 people viewed this question
David Payne
David Payne
