Question about Hotpoint TDC32 Electric Dryer
Empty water light staying on machine will not work
Empty water light staying on allthough empty machine will not start or work at all has only been used a few times was first time water emptied
  • Hotpoint Master
  • 3,463 Answers
Probably sticking float switch
Remove lower bottom left filter completely run water thro it to clean all fluff out reach inside and clear any build up of fluff that you can see or feel.
At the back of this aperture is a small hole that gets clogged up,feel for it and poke a plastic bag tie or similar, and poke it clear, if this does not work then it would probably involve a strip down to access the float chamber and switch assy.
Plz rate my solution.
Thanks.
Posted on Jan 03, 2009
I have a sunbeam EM 6910 I have just replaced the seal. When I power it on it goes through the warm up then the power light stays red and the machine starts pumping straight away.
I had this same problem. Turns out that tons of crawling insects had been living in my machine and caused an electrical fault. On my machine, this issue stops when the machine senses the water is empty, so you can try just removing the water level magnet from the tank. If you do, you still get the low water beeping and flashing red light. I sorted that by disconnecting the beeper and light from the main board but I had to open the machine right up for this, so that will take much more effort. Didn't really FIX the problem, but did circumvent without much loss of function (except the low water warning). See if that works.
Jun 13, 2015 | Sunbeam Cafe EM6910
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
Empty water light, empty condenser
I experienced the problem with a hotpoint TCYM 750, with the red empty water light failing to switch off. After removing the filter and cleaning it, cleaning the condenser and drying anywhere I had access to the machine still didn't heat and the light remained on. Reading the post about the machine having 3 reservoirs it struck me that one of the reservoirs may be hard to access. So I unplugged the machine and tipped it onto its front. The reservoir drained, I pushed the machine back upright and cleared up some water around the condenser. The drier now works properly and the empty water light is off - job done!
Feb 04, 2014 | Hotpoint Dryers
058 model does not fill up continuously, water in and stops starts and stops does that a few times and stop completely and beeps all lights stays on. Please help. Thanks
I have the same problem, just checked the switch and its all ok. But the machuine also stops and starts when its trying to empty after the last rinse cycle to start the spin cycle. Starts to drain then stops and repeats, it does empty some without stopping but starts to go silling when its nearly empty?
Jan 15, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
The empty water wanrning light will not go out. I
there is a float switch at the pump that has become stuck, and when this happens, the "empty water" light will stay on and the machine will operate but with no heat. just locate the floating switch and give it a light tap back into its place, this will solve your problem.
should you have any problems you can email me at appliancesdav@hotmail.com
pallesappliancerepairs.com
Feb 02, 2010 | Dryers
Empty water tank light stays on
The only thing thats comes to mind is the reed switch and the float on the water tank. Check the float make sure the magnet is working, if yes then the reed switch on the inside of the machine is not in the correct position.
Dec 30, 2009 | Solis Palazzo Espresso Machine
Empty water light stays on and doesnt get hot
allways with this type of unit it is best to always empty the container after every dry,this is because when the water rises in the pump chamber it operates a switch which shuts of the heater and puts on the light. and they stick quite a lot,disconnect from power and rock the appliance from front to back quite hard and this should rectify the problem
Jun 27, 2009 | Dryers
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Hotpoint TDC32 Electric Dryer Logo
291 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
