Question about ATI DVD RADEON X800 XL, (256 MB) Graphic Card
Screen resolution jumps every 15 seconds
I have a ATI Radeon X800GTO card and lately the screen resolution jumps all by istself every 15 seconds from 1280X1024 to 480X640. I reloaded the drivers from ATI with no luck. I have the original disc, should I try to start from scratch? What about registery files?
  • 100 Answers
Try this as follows: 1) Remove any ATI graphics drivers from your PC. 2) Install your driver from the original disc. 3) if it works, ok, if not, update to the latest driver from ATI's website. 4) if that doesnt work, try to maunally delete registery entires of ATI, IN SAFE MODE of course. then remove the driver of ATI, then install it from CD, again, if it works, ok, if not, update it from ATI website.
Posted on Mar 13, 2007
SOURCE:
My pc boot but when i insert my radeon x800gto ther no post
In which case your graphic card is faulty. It could be the Memory on it rather than the Graphic processor.
Sep 30, 2013 | Sapphire RADEON X800GTO, (256 MB) AGP...
My Radeon X800GTO is not giving a output signal it's getting power the fan works but no picture no obvious signs of ware latest drivers is it dead
Possible bad connection re- put it back in and check your cables!!!
Could also be monitor or windows bad install.
Feb 08, 2013 | ATI RADEON 9550 Graphic Card
Ati Radeon HD 2400 XT blacks out monitor randomly
That's because those programs you are using are switching the resolution from the native windows resolution.
Jun 25, 2012 | HP Computers & Internet
An incompatible video signal has been received check the output device settings connecting a sharp aquos to my ati radeon HD2400
what the problem is your pc is displaying a resolution you monitor cant display most likely its to low do you have a 2nd monitor you can hook up to set resolution Once you have done that set resolution that your new monitor can take and then hook up . when i moved from a 19inch monitor which ran at 1280 x1024 to a 32 inch samsung 1360x768 i had same problem as my screen cant display that res so set to what ya monitor can do .If you dont have a second display keep connected turn pc off with only your sharp cable in and it should turn on once into windows
Oct 07, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Ati radeon HD 3650 agp crashes!
Its could be overheating because its happening during games and the card takes straine....i suggest download ATI tool and put you r fan speed up to cool your card down here is the link for ati tool http://www.techpowerup.com/downloads/Tweaking/ATITool/ ...otherwise also try updating your driver by downloading it from this link...http://drivers.softpedia.com/get/GRAPHICS-BOARD/ATI/HP-ATI-Radeon-HD-3200-3450-3650-Graphics-Driver-853310-Rev-A.shtml
Oct 02, 2009 | Computers & Internet
Is my motherboard compatible with a new graphic card
Being agp3.0, it is backwards compatible so in theory, it should work. With the older system, it may be dangerous. I would find a card that clearly states that it works in x8 (3.0) 1.5v. If it doesn't work it could fry the whole system. If i find a card that works, I'll let you know.
Oct 27, 2008 | XFX GeForce 6800 GT, (256 MB) Graphic Card
Screen goes blank on Log on
You must uninstall your previous video card drivers before installing the new card, especially if they were nVidia drivers.
Jul 23, 2008 | IBM NetVista PC Desktop
Hp pavilion zd8000 ati mobility radeon x600 128 mb
A bit late over a year has passed.........
I have a smilar problem, with the ATI enabled the laptop black screens on startup.
If you disable the ATI x600 in Device Manager (using safe mode) the laptop works fine as the ATI is not being used.
Solution is to replace the ATI x600, which unfortunately is a specialist job as this is soldered directly onto the motherboard. Or replace the motherboard.
I have located a company in Manchester (called CRM) that repairs HP computers, and they can repair/replace the ATI for around £175, or replace the motherboard for about £250. Replacing the board gives you a 12months warranty. add VAT to those figures. There phone number is 01618881232, I have found them to be very helpful.
Mar 24, 2008 | ATI RADEON X600 Pro, (128 MB) PCI Express...
Ati Radeon 9000 video card driver
It could be related to the display resolution settings. If you can boot into "VGA mode", that should get you started.
Dec 19, 2007 | ATI RADEON 9000 Graphic Card
ATI DVD RADEON X800 XL, (256 MB) Graphic Card Logo
149 people viewed this question
Top ATI Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Argospete
Argospete
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
