Question about Zanussi ZWF1430W Front Load Washer
Zanussi zwf 1431 starts programme, drains but then stops
Zanussi zwf 1431 starts a programme, sounds like it is draining and then stops and the digital panel goes back to 0. The first couple of times it displayed error E80 but isn't doing this anymore.
  • gazzawillo12 Feb 01, 2009
    zanussi zfw 1431 starts programme then skips straight to drain then stops and shows error fault e80
SOURCE: E60 error code
Our machine - a ZWF1437 - has developed the same problem. Our friendly engineer has checked his manual and told us that there is no such error code. He suggested switching the machine off and unplugging it to allow any residual charge to clear from the memory chip. The next step is to clean out the filter at the front - remember to empty the water out first. After a couple of hours, switch the machine on, press reset and then spin to empty any remaining water. Hopefully, this could work ---it didn't work on ours but he assures me that this tip usually works.
Posted on Jan 24, 2008
  • 4 Answers
SOURCE: zanussi zwf 1415w become very noisy when it is running all time?
you have to call a technician to check the drum bearing
Posted on Jun 04, 2008
abhishek33
  • 1239 Answers
SOURCE: zanussi zwf 1632 w
hi follow this Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by handStep 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
thank u.......................
Posted on Sep 12, 2008
SOURCE: My Zanussi ZWF 1221 W will not rinse. Any ideas?
my zanuzzi 1500 will not rinse
Posted on Aug 22, 2009
apart4u
  • 213 Answers
SOURCE: how do i remove the door seal on the zanussi zwf 1220s
Follow these steps to replace your door seal:
For all Free appliance repair videos visit our VIDEO TUTORIALS Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Posted on Jan 19, 2010
My zwf 16581 w zanussi shows E32 error code. I have replaced the pressure switch but nothing has changed. Please help
If you are replacing an analogic pressure switch and nothing has changed I suggest you the following:
  • Drain the water from the tub.
  • Are pressure switch hose and air trap system free? (You can disconnect the hose and blow in it to check if the system is free).
  • If YES, than check the draining system (filter, drain pump, drain hose). Is the machine draining correctly?
Dado
Feb 23, 2016 | Zanussi Washing Machines
Why did my washer stop mid cycle and now won't work at all?
Hope your warranty is still in effect. It sounds like your control board has an electronic problem that will require replacement; typically around $135 for the part and $110 for the service visit.
Aug 21, 2014 | Zanussi Washing Machines
Error code E 31 on a zanussi zwf 1431 front loader machine may not be water in. water feed and filter ok
The code E31 relates to a problem normally with the pressure switch,heater or maybe the Programmer.The heating element may even check out with a test meter but it can be an earth fault and normally just replacing this part cures the fault.If you are not electrically competant it would be worth getting it checked.
Hope I have helped.
Apr 25, 2010 | Zanussi ZWF1430W Front Load Washer
Zanussi washing machine won't start E10, E40 & E50 at times
It was suggested that the pump had failed and taken out the programmer with it - expensive! Wife wouldn't wait, and bought new machine. Problem almost solved - anyone want an out of order washing machine?
Feb 03, 2009 | Zanussi ZWF1440 Front Load Washer
Zanussi zwf 1020w drum not revolving
The drum will not rotate until the draining process is satisfied, there is either something in the pump or pump is broken
Oct 20, 2008 | Zanussi FJD1666W Front Load Washer
Zanussi zwf 1440
Something wrong with the pump,leave out let hose down as flat as possable into a basin or whatever,to drain water,remove pump test and check it.
Sep 05, 2008 | Zanussi ZWF1440 Front Load Washer
Zanssi washing machine ZWF 1221 W will not spin
Do you realise there is a law I understand that says for 6 yrs the goods should be fit for the purpose you bought them for. Look at this "your rights " & go tackle the store you bought the machine from.
http://www.guardian.co.uk/money/2006/jun/01/yourrights.legal4
Jun 21, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi zwf 1432 front loader
check the filter down on the right and cleane it
May 28, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Zanussi ZWF1430W Front Load Washer Logo
117 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
