Question about Compaq Presario S6000NX (DQ178A#ABA) PC Desktop
Windows xp logo will start to load then......
The computer will turn on a boot all the way to the windows loading screen then it gives me a screen that is blue and says something i cant read because it restarts. i have reformated and it will go through the whole process of reinstalling windows but when the installation is complete and the computer resets to start xp it will do the same thing again. i've never had a problem with this computer until now. now i am on an old emachine 533. please help!!
  • somuchin Dec 15, 2008
    I have already tried that it will not boot all the way with any of the options on that menu. I have also tried another hard drive that I know works, still the same thing. Do you know anything else that might work?
    Problem Solver:
  • 15 Answers
To solve this will require more information from you. The Blue screen is Windows way of telling you that it has a driver issue with a basic component, usually your video card. Did you recently make any hardware changes? If so please let me know what was changed.
When windows first boots, you can repeatedly press the F8 key until you see a menu giving you choices of windows booting. You need to select Safe Mode. Safe mode should allow you to at least boot without a blue screen. The blue screen could also be cause by a virus or other software.
Microsoft has a description of Safe mode here;
http://support.microsoft.com/kb/315222
but here is a quick snippet
To use a Safe Boot option, follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Posted on Dec 13, 2008
I have IBM P3 and i want to change win xp but its not booting pliz help me and it doen't give me option of booting
Turn the computer on. Keep your eyes glued to the bottom of the monitor screen. This usually comes by fast, so keep your eyes peeled.
When the computer manufacturer logo screen comes up, look for the -> enter CMOS Setup, or enter BIOS Setup, <- key to press.
Write it down.
If Windows loads on your computer, allow it to load, and run for a few minutes.
Turn the computer off normally.
WAIT 20 seconds, or so; then turn the computer back on.
AS SOON AS you press the Power On button, start tapping on the enter BIOS Setup key. (Or enter CMOS key)
Tap in 2 second intervals.
If you hear beeps ignore them. They are Stuck Key Error Code beeps, and it is you that is doing it.
Once you get into BIOS. look for Boot Options.
In Boot Options set the first boot device to CDROM.
http://www.hiren.info/pages/bios-boot-cdrom
REMEMBER, you have to Save Changes, or it will be like you have done nothing at all.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 07, 2013 | IBM NetVista PC Desktop
Tip
Quit the Registry Editor and log off
Automate the above task using this utility
This tiny utility provides you the option to choose a color from the Color Picker dialog and can reset the logon Wallpaper if you want. Choose your preferred Color and click Apply Background color. Remove Logon Screen wallpaper option clears the logon
How to disable the Windows XP Splash Screen / logo at startup ?
To disable the Windows XP splash screen (logo) at startup, and to see the list of drivers loading at startup, follow these steps:
Click Start, Run and type MSCONFIG
Click the Boot.ini tab
Under Operating Systems section, select the appropriate entry and then enable the /SOS switch in the Boot Options section below
Click OK and close MSCONFIG utility.
The corresponding entry in the Boot.ini file is automatically added. Example given below:
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect
becomes
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect /sos
The /sos parameter displays the names of the drivers as they load during the boot process. Use when startup fails (while loading drivers) to determine which driver is failing to load. See Boot Parameter Reference for more information.
Also see /noguiboot parameter, which can also disable the splash screen.
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
Starting problem
Immediately after seeing the Dell logo, keep tapping the 'F8' key,
until you see a "menu" (white text over a black background)
giving "startup" options for Windows XP.
Select "Safe Mode" and see if you can start in that mode.
Then, use "System Restore" to go "back" in time, to the most-recent checkpoint (date/time) where your computer _DID_ work.
Restore to that point, and restart.
Jul 17, 2010 | Dell Inspiron 1525 Notebook
When booting up my computer it goes to the error page prior to loading windows and asks what mode...regardless of choice it goes to windows logo screen and sits there and wont load...
1. check to see if your pc is compatible with the software. You didn't specify if you are reloading or installing for the first time.
2.You didn't give hard drive capacity or any information about the Pc you are loading Windows on.
You may not have enough capacity on the hard drive to load the full XP
Wndows xp requires about 2 GB of hard drive space then at least 10 GB of space for swap files and operation files.
Jun 13, 2010 | Compaq MS Windows XP Home Edition for PC
Windows xp boots but the desktop will not come on
well there is a couple of thing you could try 1) power on your computer press F8 rapidly and select "last known good configuration" 2) power on your computer press F8 rapidly and select safe mode login with your account and press yes to restore you computer to an earlier time select a date tah the computer worked ok and click on restore
try it and please if you have any problem please comment
Apr 01, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Windows xp will not load on my computer....
It could be your hard drive problem. Which I called it, "Crash." I would suggest you try to format the hard drive and reload the operation system with your installation CD.
Jul 22, 2009 | Acer Aspire™ T180 PC Desktop
Loads dell logo then goes to load xp then screen goes blank
Try going into safe mode if you can by pressing the F8 key when you first turn on the laptop.
If you get into safe mode then go into the system configuration utility underneath the system tools folder. Click on the startup tab and then click on the button that says disable all. This will keep programs from loading when windows boots up. Reboot the computer and see if you can get into windows normally. If you can then you know its a program thats causing the problem. If you still can't get into windows normally then you'll have to wipe out the drive and restore your computer back to factory default.
You also will have to do this if you can't get into safe mode as well.
May 04, 2009 | Computers & Internet
Problem with Toshiba Laptop U
this is clearly a no boot issue. you can actually do a power cycle first. remove the battery and unplug the ac adapter. press and hold the power button on the computer for 10 secs to drain all power inside the computer. turn on the computer. if it still freezes, tried to boot to safe mode. as soon as you see the Toshiba logo on the screen, start tapping on the F8 button as quick as you can to access Windows Advanced Boot Options. then choose safe mode only. if it doesn't solve the problem then most likely, your Windows XP is already corrupted. try to do system recovery. please be reminded that you will lose all data if you run the recovery.
i hope this helps.
Sep 16, 2008 | Computers & Internet
Dell dem 3000 will not turn on
What you need to do Is to take the Operating System reinstall disk that you got with your computer and boot from that. Once you get to the main screen press the option for a repair. Follow instructions on the screen. If you need more detail on how to do this just tell me and I will help.
All The Best,
RCF
May 28, 2008 | Dell Dimension 2400 PC Desktop
Computer won't boot
you may need to re install the s/w from a recovery cd, or go to safe mode(F8) to do a virus scan..
Apr 21, 2008 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Compaq Presario S6000NX (DQ178A#ABA) PC Desktop Logo
128 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
