Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Bent Picture at top and bottom
We have a five year old Philips 60PP9202-17F projection Tv.
All of a sudden last night the picture went screwy at the top where the left upper corner of the cdreen is bending upward and the bottom is sort of doing the same thing. We tried adjusting the cross hairs and all colors seem to be moving in all directions but has no effect on the problem. Whats the deal with this fluid coolant and does that play a part in this issue...Thanks very much for any information you can share.
AJ
  • Edward
    Edward May 11, 2010
    Its not the coolant.
    Does it bounce in and out or is it stationary?
    Scholar:
  • 87 Answers
You have bad convergence amps.The fluid may need to be changed if the picture had a hazey look to it before the convergence went bad.
Posted on Jan 12, 2009
We went to auto focus on our tv. It shook wildly the when the picture came back the picture is bent. When looking inside the tv the green and red are being projected bent at the top and bottom. Please...
You need to replace the convergence IC stk392 -110...2 resistors and a fuse. located in the deflection board of your tv and after you can press auto focus and the picture will be normal.
Dec 18, 2010 | JVC AV-56WP74 56" Rear Projection...
The picture on my akia flat screen went out it still has sound . Is it worth fixing or throw it out? its almost five years old. It was a sudden loss of picture, not gradual
You need to replace the Lamp this set has 2 Lamp #numbers
Look at the serial# on back of TV for either a J or Z in it that will tell you which Lamp you will need to order
Encompass Parts Distribution list this Model#.
Mats Electronics has Lamps for $99.00 1-800-628-1118
Oct 24, 2010 | Akai PT46DL10 46" HDTV-Ready Television
Screen appears to be bent at the top and bottom.
Ur convergence it dead.U know how to solders?Buy a convergence kit use what in that kit.Tries these Websites for parts.Tv repair World.com,Tvrepairkits. Tv shop will cost u $300.Repair by tv tech.
Dec 16, 2009 | Philips 60P8341 60" Rear Projection...
Samsung lcd TV five years old, screen suddenly went black
In order to properly provide you with guidance, we need some hint about the problem. Can you describe the symptoms? Is the set dead? Are there any blinking status lights?
Thanks,
Dan
Sep 20, 2009 | Samsung HC-P4241W 42" Rear Projection...
My 60" Phillips tv has a blurry picture at the bottom and the top
The convergence output IC's need to be changed. A very common problem with all projection tvs.
Jun 04, 2009 | Philips 60PP9352 60" Rear Projection...
Sony HD Projection TV - Picture bent and seeing multiple colors
This is due to failure of convergence out ICs that need to be replaced in D board.
If you are comfortable with TV repair let me know to provide you technical info to fix TV.
Apr 17, 2009 | Sony KP-46WT520 46" Rear Projection...
Philips 51PW9363-17F - No picture but has sound
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Oct 12, 2008 | Philips 51PW9363 51" Rear Projection...
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Help
Please provide Make, Model and month & year built on back
of set........................thanks................................T.
Nov 18, 2007 | Televison & Video
RCA P52830BL picture is bowed and colors separated.
There is a convergence printed circuit board that likely has a few bad components. If you decide to get it repaired, the technican will probably check for fluid leaks from the picture tubes coolant area which has given problems on this model also. If the picture quality leaves a bit to be desired, it may be a wise move to upgrade to HDTV. A Sony KDS-55A20 model has a great picture and should be less than $2300. I just saw one at a local Sams Club store.
Mar 12, 2007 | RCA P52830BL 52" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
101 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
