Whirlpool washing machine model LSR7133kqo does not advance past
PUMP SEEMS OK
  • Barry Coates
    Barry Coates May 11, 2010
    What exactly is your problem? Pump o/k is telling me nothing. except that your pump is o/k!!!!!
gittos73
  • 244 Answers
SOURCE: Washing machine does not drain
does the water pour out when you put the drain hose close to the ground if it does then make sure your pump isnt blocked if it isnt then youll need to replace the pump most pumps have 3 little fins in them if you can stop those fins with a screw driver when pump is going then it deffinatley needs replacing as you cannot fix them sorry for the bad news m8
Posted on Sep 12, 2007
  • 1028 Answers
SOURCE: washing machine
bottom right corner behind the little door
Posted on Sep 27, 2008
  • 132 Answers
SOURCE: whirlpool washing machine won`t spin or pump out
1-check the drain hose maybe cloged 2-check the drain filter maybe filed with materials 3- check no spin mode maybe you selected thank you
Posted on Jun 08, 2009
  • 1891 Answers
SOURCE: How do I clean my whirlpool washing machine pump?
rmove the 3 screws ot the bottom of toe panel . pull down and out to remove . pump is just right of center . about a 3 in lid rigt in front turn t open and clean out tray . mm.
Posted on Nov 20, 2009
Testimonial: "Thank you very much for your help, it worked like a charm."
  • 69 Answers
SOURCE: Whirlpool AWO/D 4605 Clean Pump light on, how do I
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it. Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!! Happy fixing!!
Posted on May 11, 2010
Washing machine wont advance past wash
Your timer might be faulty. It was about a $100 dollar fix for a service man for me.
Apr 05, 2014 | Whirlpool Washing Machines
Won't drain (or spin)
It may be as simple as a clogged drain pipe. The sludge from the solid waste grinders in a lot of the new washers will coat and clog the tube.
Mar 21, 2014 | Washing Machines
I have a whirlpool washing machine, it was working ok before I moved house but now it wont rinse or spin,I cant find the instruction manual the model is AWOE8761 where can I get an instruction manual
simply you can download your instruction manual on samsung main website. Go here and search your washing machine model, you can get the manual
Sep 12, 2012 | Whirlpool Washing Machines
Washing machine will not spin. have cleaned out
I have problem with my washing machine.could you help me please.
Apr 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool ultimate care series washer does not drain and won't spin. what seems to be the problem?
Hi.
It is a drain problem. The machine timer won't advance to spin until it detects that drain is complete. For this reason the machine is also not spinning.
Check lid switch first, this is testted with a multimeter.
Ensure that the drain hose at the back is not clogged or kinked.
Access the drain pump and undo the hose attached to the pump, see if there is any blockage in there.
The pump can be fully tested by a technician energizing it directly.
If the drain system is fine check the pressure switch that detects when the drain is complete, this should not be the case.
If all the rest is OK, replace the control board.
You can find parts and diagrams for most models here.
Regards.
Nov 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Have an oil leak(bad) on Whirlpool Model LSR7133KQO. Can gearbox be repaired by myself? Ordered seals, but having second thoughts on how much work involved!
This would be difficult to answer since it is case to case basis and the big factor would be the extend of the damage, the skill and the willingness of the person. Most of the time the seals are the culprits of such issues, damages on the metals that leads to leak would automatically require replacement or a professional's help. If it is just the seals, I would advise to take a digital cam and take shots for each stages so you would know how to put it back together.
Aug 17, 2009 | Washing Machines
NOT DRAINING
See if you have a sock in the inlet hose at water pump. You have a pressure switch that will not allow the machine to advance until the water has been pumped out.
Nov 16, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Sep 12, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
133 people viewed this question
Top Washing Machines Experts
