Question about Zephyr Venezia ZVE-E42S Kitchen Hood
Flashing "A" a flashing "A" appears when the fan is turned on in stead of displaying the number of the fan speed which is then running
  • donnamat Jan 26, 2008
    I have the same problem. the flashing "A" appears when the fan is turned on. How do I fix this?
Press and hold the (-) button with the unit off untill the (A) clears. It's a 30 hour timer to remind you to clean the filter
Posted on Dec 13, 2009
Initially fan in indoor unit was surging,cutting in and out,now has stopped completely and red/green flash twice followed by red flashing 4 times
The flashing indicates a fault code. Not knowing what make / model you have makes it impossible to determine the exact fault. If the indoor fan was running erratically, it may just be a fan capacitor on the indoor unit. Some units have a separate capacitor, some have the capacitor mounted on the main indoor control board. Check and see if the fan starts if you give it a flick to start it spinning when you turn the air con on. If it runs and the error flash does not appear, then you will know its a fan capacitor.
Apr 12, 2015 | Heating & Cooling
Tip
Frigidaire Dishwasher Error Codes and Service Test Mode
Many modern appliances have error code build in to the control programing to help with the diagnosis of a failure. Frigidaire dishwashers with display s will flash Er then a two letter error code.
Er i s a Switch error (Replace Console Pn# 154639207)
CE is a Configuration error (Replace Control Pn#154543602)
UO is a Vent that will not close. (Replace Vent Pn#154682301) or remove blockage
uF is a Vent fan Not running (Replace Vent Pn#154682301) or remove blockage
Other codes you my see in the display that are not errors
LO is Low rinse aid
PF is power failure
Ho is Water Heating
CL is close Door
01-24 hours of delay
Service Test
To enter service test you must turn off the power and PF will be displayed. While in PF press and hold Pad # 1 and Pad # 7 at which time an “rt” will appear in the display. To get it out of service test Press Pad # 1 and the Pad # 7 this will return you to PF mode.
[ (#1)(#2)(#3)(#4)(#5)(#6)(#7) (#8)(#9)(10)(11) ]
Press pad # 1 Active water valve Ultimate Scrub Maxx Clean Valve on =FL Valve off =rt
Press pad # 2 Test Speed motor (1 Time) motor @ 2800 rpms Speed Wash pad ”28′ First two digits motor speed
Press pad # 2 Test Speed motor (2 Times) wash motor @2950 rpms Speed Wash pad “29′ in display
Press pad # 2 Test Speed motor (3 Times) wash motor @3150 rpms Speed Wash pad “31′ in display
Press pad # 2 Test Speed motor (4 Times) wash motor @3450 rpms Speed Wash pad “34′ in display
Press pad # 2 Test Speed motor (5 Times) turns off wash motor No light on ”rt” in display
Press pad # 3 Test Dispenser dispenser powered Normal Wash on = “Sd” off = “rt”
Press pad # 4 Test Drain pump on/off China Crystal or Party glasses on = dP off = “rt”
Press pad # 5 Test Fan dry Active vent on/off Top Rack,Eco Wash Glasses on = Fan speed off = “rt”
Press pad # 7 Test Rinse aid level none Rinse only low = RE full = RF off = “rt”
Press pad # 8 Test Soil Sensor none Wash Silencer or Wash pressure on = sensor voltage reading off = “rt”
Press pad # 9 Test Thermistor none Wash Temperature on = Temperature in °F off = “rt”
Press pad #10 Test Heater on/off Heater on/off No Heat Dry on = HO off = “rt”
on Dec 23, 2009 | Dishwashers
Whirlpool microwave fan not working
I would unplug the oven for 2 minutes to do a hard reset and try it again, just in cause there was a glitch.
Without knowing your full model number from the tag on the oven, I would wonder if it has a separate internal cooling fan from the hood vent exhaust fan. It could be an unrelated issue.
For more free DIY and other help & advice, feel free to contact me with your full model number and FCC ID number from the tag on your oven.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 11, 2017 | Microwave Ovens
G 2582 scvi
make this test and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 24, 2013 | Dishwashers
Cuts off and speed is variable and shows err 4
Precor Error E4, Incomplete Initialization Probable Cause Indicates that an incomplete upper PCA to lower PCA initialization occurred. When this error occurs, all lift motor and drive motor motion is ceased and the display will go blank except for the error displayed.
Corrective Action Run the initialization program. Caution: The treadmill's running belt will accelerate to the treadmill's maximum speed (12mph). DO NOT stand on the treadmill's running belt during the procedure.
  1. Set the on/off switch to the OFF position. Wait a minimum of 10 seconds to allow the internal power supply to discharge.
  2. Remove the safety key from the console and set the on/off switch to the ON position.
  3. Press INCLINE UP and SPEED DOWN keys together. While pressing these keys, replace the safety switch on the console. Continue holding the INCLINE UP and SPEED DOWN keys until the display goes blank. INIT will appear in the time window of the display. The EEPROM is now clear and reset. After a second, 1.25 will appear in the distance/calories window, 15.0 (the maximum incline) will appear in the incline window, and 12.0 (the maximum speed) will flash in the speed/pace window.
  4. Press QUICKSTART to begin the speed calibration process. Power bits will appear in the incline window, the target speed will appear in the time window and the actual speed will appear in the speed/pace window. At the beginning of the process, the target speed will be .5mph. The running belt will start. Once the actual speed reaches .5mph, the target speed will then change to 12mph and the running belt will accelerate until it reaches 12mph, then it will stop.
  5. When the running belt stops, the display will return to the user mode and the initialization process is complete.
Precor Error Code E4
Feb 27, 2013 | Precor 9.1 Mode 1 Treadmill Repair Parts...
Have a 2003 dyna the check engine light comes on and the tail light goes out,the speedo quits working, and it feels like one cyl is dead for about 15 seconds, and when the light goes out all is well. can u...
To Get the codes you need to follow these steps:
1. While holding the odometer reset switch in Turn the ignition swithch to IGN. Make sure Run/Stop is in the run position. When you release the reset switch does Diag Appear? If yes press and release the reset switch, PSSPT should appear.
2. Flashing P= DTC's for ECM press an hold reset switch for more than 5 seconds you should have a device response.
3. To Choose the TSM/TSSM/HFSM Codes press and release the reset button a flashing S should appear. Press and hold the reset switch for more than 5 seconds you should have a device response.
4. To Choose the Speedometer Codes press and release the reset button a flashing SP should appear. Press and hold the reset switch for more than 5 seconds you should have a device response.
5. To Choose the Tachometer Codes press and release the reset button a flashing T should appear. Press and hold the reset switch for more than 5 seconds you should have a device response.
If any of the above have none displayed you are ok.
If any of the above have DTC's displayed then press and release the reset switch to see if any more are displayed.
After writing down the codes then press and release the reset switch and the part number of the module will be displayed.
Feb 28, 2011 | Harley Davidson FXDWG Dyna Wide Glide...
Why won't my vision fitness simple T9500 run? I tried holding down the stop button for 3 seconds. It did clear the screen. Then when I hit start it puts 6000 in the screen and will not run. It beeps as if...
With the safety key in place, press and hold “ELEVATION UP” and “SPEED DOWN” for 5 seconds. The software version will appear in display window shortly before model number appears. Press “ENTER” to accept correct model number IF YOU CANNOT GET INTO CALIBRATION EITHER UPPER CONSOLE ELECTRONICS OR OVERLAY CONSOLE ASSEMBLY HAS FAILED.
• Press “STOP” to enter “ENG1”. Press “ENTER”. PLEASE NOTE: HR Window = “0” for miles, “1” for kilometers, treadmill will calibrate in kilometers if set for kilometers. STEP 2 MINIMUM SPEED • Press “ELEVATION DOWN” button, “P0” will appear in display. • Press “START” button, the running belt will begin to move at minimum speed. • The display window should read approximately “.49 - .51”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “.49 - .51”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P0”. STEP 3 1/4 SPEED • Press “ELEVATION UP” button, “SP1” will appear in display. • Press “START” button, the belt will move 1/4 speed. • The display should read approximately “2.71 - 2.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “2.71 - 2.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP1”. STEP 4 1/2 SPEED • Press “ELEVATION UP” button, “P1” will appear in display. • Press “START” button, the belt will move at 1/2 speed. • The display should read approximately “6.72 - 6.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “6.72 - 6.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P1”. STEP 5 3/4 SPEED • Press “ELEVATION UP” button, “SP2” will appear in display. • Press “START” button, the belt will move at 3/4 speed. • The display should read approximately “9.41 - 9.43”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “9.41 - 9.43”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP2”.
STEP 6 MAXIMUM SPEED • Press “ELEVATION UP” button, “P2” will appear in display. • Press “START” button, the belt will move at maximum speed. • The display should read approximately “12.10 - 12.12”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “12.10 - 12.12”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P2”. STEP 7 MINIMUM ELEVATION • Press “ELEVATION UP” button twice, “P4” will appear in display. • The display should ready approximately “190 - 205”. • To adjust, press “ENTER” for value which should read “190 - 205”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P4”. STEP 8 MAXIMUM ELEVATION • Press “ELEVATION UP” button, “P5” will appear in display. • The display should read approximately “750 - 765”. • To adjust, press “ENTER” for value which should read “750 - 765”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P5”. REMOVE SAFETY KEY TO EXIT ENGINEERING MODE REPLACE SAFETY KEY AND PRESS START TO TEST TREADMILL
Jun 14, 2010 | Dmm Vision Fitness T9500 Treadmill
Error code of "Er s" appears on the display and inside the light remains on at RINSE Low. HELP!
LO is Low rinse aid
PF is power failure
Ho is Water Heating
CL is close Door
Service Test
Let me know how this works out for you.
Benjamin
My monitor green light keeps flashing. I cannot get a stead display.
Flashing power light often means the monitor isn't getting a signal. When you turn the monitor off and back on, do you see the viewsonic logo for a few seconds? Try plugging it into a different computer to see if it comes on.
If plugging it into another computer doesn't work, it may be a bad power circuit in the monitor. A common problem with monitors is the capacitors going bad. If you're handy with a soldering iron, you can try replacing them yourself. Look here for pictures and instructions: Fix an LCD Monitor
Dec 23, 2009 | ViewSonic VX924 19" LCD Monitor
After pushing Power button the printer turns off within few seconds. During that period the display shows nothing, just lights up, the power light is flashing. I've tried several times to start, but same...
remove the rear cover that conceals your main pca. turn on your printer and check the cpu fan. if the fan is not rotating up to speed, this can cause your problem. you can purchase a similar fan at microcenter or you can search online for one. shouldn't cost you more than $10.00. you can purchase it direct from HP the part number is (if they haven't changed the number) Q1271-60160
Sep 11, 2009 | HP Designjet Z6100 InkJet Printer
Zephyr Venezia ZVE-E42S Kitchen Hood Logo
743 people viewed this question
Top Zephyr Kitchen Ranges Experts
Treefrog15
Treefrog15
Tom Chichester
reliableservice
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
