I have a 3 year old GE GHDA455 dishwasher that does not work. I have cycled the breaker which causes the normal wash and heated dry light to light up, but none of the controls respond and it shuts off completely in about 10 minutes (lights shut off..the washer never actually works). This is the third GE appliance out of the four I purchased in December of 05 to either die or develope a major issue. Any suggestions? I really cannot afford a new dishwasher at this point.
SOURCE: AMANA ADB1500AWQ Control buttons not
unplug the power cable from wall socket.check the voltage from the household receptacle to the dishwasher, volt meter.It might be your neutral line is bad,or the console is bad
SOURCE: ////////////////////my kitchenaid dishwasher lights are flashing
Can you explain the issue in detail - is your dishwasher not working at all, or the buttons continue to be lit up, etc?
First and foremost, check the dooe switch to see if it is functioning properly.
SOURCE: Buttons won't work on GE Profile PDW7980N10SS
You have the control lock activated. Press and hold the heated dry pad for 5 seconds and it should unlock it
SOURCE: jenn air diswasher mod # JDB1100AWS
disassemble front door to get to the latch. Check if the latch is properly in place, sometimes the metal cylinder that hold it in place, slips out of position.
SOURCE: Our GE Triton Dishwasher, mod#
The drying fan and vent system seems faulty.
Refer this diagram. Item 918.
I will go through the manual to see if I find anything else.
Can you try in the ECO cycle which does not require drying to confirm the problem is only with the drying cycle.
