Question about Hitachi Televison & Video
50" Hitachi projection TV model#50fx18b v6g000413
When attempting to turn on, the power button clicks but does not turn red (light up) and there is no picture or sound.
  • reng812737 Dec 13, 2008
    Don't know if this will help or not but we'll try it.
    Master:
  • 479 Answers
There could be many options that can turn out faulty for this problem 1)the power wire of the tv gone short,needs to be checked. 2)the fuse of the tv blown out ,very common problem. or 3)it can be the faulty components on the main board needs to be checked with a multimeter and that faulty component should be replaced from the board to make it perfect.
Posted on Dec 13, 2008
  • 470 Answers
It means that the switch is active, but the power is not, im sure it is the POWER SUPPLY my dear, and it will control the power system of your TV, check the power supply on your technician, im sure it has the defects, or maybe the capacitor,, just infor it, dont make it wait beacuse it can cause SHORT CIRCUIT, that will additionally makes problem of your TV,... regards jAN_yuanjia
  • 275 Answers
How long has it being doing that? Did you try unpluging from power supply for 5 mins and then plug back and power back on and see if that works? Usually bad plugs give out short circuits to your appliances and this affects tvs the most, you might need a A/C power supply regulator to avoid this happening again.
    Genius:
  • 1,199 Answers
This sounds like the flyback voltage regulator is burnt out (part is around 70.00
Hope this helps!
I have a 50fx18b and it wont power up i took the back of the set off it has a red light on but nothing happens when i turn power on
the red light = shutdown led
all the green ones indicate the voltage lines that came up
there is a diagram inside that shows all the leds plus fuse locations. you need to check the fuses with an ohm meter to figure out which one is blow or which voltage doesn't come up. with that info, i can direct you.
Jun 04, 2010 | Hitachi 50FX18B/19K 50" Rear Projection...
I have a hitachi 50FX18B and the convergence lines are not aligne
Yes - You will need to either remove the circuit board or lift up the tray. If you are not sure how to do it yourself read the link below.
  • This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 24, 2009 | Hitachi 50FX18B/19K 50" Rear Projection...
Hitachi 50fx18b 50" projection no power
Does it chirp? If so you need convergence chips replaced.
Read the link below.
  • Screen looks 3D
  • TV Makes Chirping Sound
Jan 07, 2009 | Hitachi 50FX18B/19K 50" Rear Projection...
50 inch rear projection Hitachi looks like your watching in 3d
This is a convergence problem and igf you can solder, you can probably fix this yourself. If you feel comfortable working inside the set, and are aware of the dangers of the high voltage present there. try the following: Resolder the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. These are large black ICs attached to a heatsink and should be marked STKxxx.
Keep us posted.
Dan
Nov 24, 2008 | Hitachi 50FX18B/19K 50" Rear Projection...
1996 Hitachi 50FX18B 50"
  • Screen looks 3D
Jul 24, 2008 | Hitachi 50FX18B/19K 50" Rear Projection...
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Hitachi 50" Projector 50FX18B
Common problem. You can get a repair kit that includes the C707 and E994 + repair instructions from www.TvRepairKits.com
Nov 27, 2007 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 50FX18B
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 13, 2007 | Hitachi 50FX18B/19K 50" Rear Projection...
Televison & Video Logo
22 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
