Carrier 48ss-048120341 propane unit smells bad, smoking. think the heater tubes may have holes in them. how are they removed, can they be replaced, can I braze holes if found
  • 334 Answers
First recommendation. Turn off the furnace, and buy some carbon monoxide detectors. I definitely do not recommend you using the furnace without them.
Yes, the heat exchanger can be replaced.
No, you would not want to attempt to braze the holes.
If the HE is cracked or has holes, it needs to be replaced. That can kill you.
They are usually removed by disassembling 90% of the furnace and part of the cabinet. This is a major repair, and not a do it yourself issue unless you have some experience and training in the operation of furnaces and electrical controls.
Also be aware that your HE may be under warranty depending on the age of the unit. Most are 10 year warranties. Some are even lifetime.
Posted on Dec 14, 2008
Reddy heater 75 125000 propane heater. Fan comes on, have spark, smell propane and still won't fire
There are couple possible reasons your unit refuses to fire; some units tjis big have to be level, this is a saftey feature bulit in if it is not level, it will not fire, ( it believes it has been tipped over), the smell of propane could also mean it has a leak on your line connection ( bad fitting, not sealed properly), finally check the temperature sensor may be bad and need replacing......
Jan 21, 2017 | Reddy Heating & Cooling
Where is the metering devive on a 48ss-048100321aa
If it has a capillary tube (thin long copper tube usually rolled up to save space), then that IS your metering device.
Aug 12, 2011 | Carrier Heating & Cooling
Smoke coming through vents temp. gauge going up acting like its going 2 overheat turn heater on hot and smokes bad turn to cool and smokes a little my husband thinks it's the thermostat and wants to...
If the heater core is leaking, you would get a lot of steam that would smell "sweet". That would also leave you low on coolant, which could be a source of your overheating. If it's more of an electrical smell, you may have a blower motor or a blower motor resistor going bad, but won't cause the engine to overheat.
May 03, 2011 | Ford Ranger Cars & Trucks
I have a rlp100 heater that works well but now has an annoying smell. It also burns your eyes some. It is 3 years old and hasn,t been used much. What can I do to get rid of the smell?
The smell is unburned propane and the burning of the eyes is caused by carbon monoxide. My heater (RLP100) does the same and I was able to measure the carbon monoxide at 95 ppm (deadly). I have yet to figure out what exactly is happening. Tried a new regulator/hose from a new unit - no help. Also pulled apart the burner nozzle and cleaned the holes - helped a bit. Next step is the valve.
Dec 18, 2010 | Reddy Heater RLP100 Portable Forced Air...
I just cleaned my jets on my purex mini max plus 400 heater. It is heating great now but has black smoke coming from the top. I think it is rich and is getting too much gas. Is there an adjustment or do i...
First have you always had this connected to propane? There are different models for natural gas and for propane.If you connect a natural gas to propane the "jets" are way too big for propane. How did you clean the jets? IF you "drilled" them out they may be too large now. If you have adjusted the gas regulator, decrease gas pressure. I believe this unit has a combustion blower, be sure it is debris free on inlet and in fan, check for leaves. Make sure black smoke is not coming from debris built up inside of heater. Here is a link to a location for the complete manual for your heater: http://lawnandgarden.manualsonline.com/manuals/mfg/pentair_pool_products/400k_btu_hr.html
Jul 05, 2010 | Pentair Minimax Ch 400,000 Btu Propane...
Pilot flame burns above pilot tube in propane heater. the sensor does not register. the pilot top of the tube shoul glow red. I have cleaned the tube, in few occasions it has lit and worked for above 10 to...
Hi it there a leak on the pilot causing it to burn that high can you adjust the pilot gas going in to the pilot ?
have you cleaned the pilot injector out or is the hole in the injector too big
Jan 25, 2010 | Williams 2509612 Ceramic Mid-Size Heater
Dometic RM2652 will not cool on A/C or propane, I've checked fuses, and AC to refer. I opened the access panel on outside of Travel Trailer, and there is yellow powder on bottom, and some on heating tube....
Ammonia is just what you a re smelling as the coolant is ammonia based Your cooling unit has leaked and is done for- Sorry I had to be the one to tell you
2 choices Replace the refer or Replace the coiling unit, I would suggest replacing the refer and having a new warranty
Jun 07, 2009 | Dometic RM2652 Refrigerator
Smoke or vapor coming from new h400fdn hayward pool heater.
Not at all uncommon. New heaters have to glaze over the file tile in the burner chamber and will often smoke and smell during the first week or so of operation.
Using a mirror, check to see that your flames are about 4" proud of the burner tubes when running. As long as they are and the color is a nice blue with little to no yellow/orange color, the heater is fine.
May 28, 2009 | Hayward H Series Pool & Spa Heater 400k...
INCREASING SMELL OF PROPANE WHEN USING HEATER,
get it checked out professionally before it makes a smoking hole in the ground
Mar 23, 2009 | Desa International RCP25 Utility Heater
My Heater Sparks and shoots out smoke
Most likeley a bad transformer. Shut off the breaker, then remove the cover of the box containing the transformer & circuit board. If the transformer is bad, it will look and smell burnt. Mark the wires before you disconnect it, so you know how to connect the replacement. Then remove the bad transformer and bring it to a heating & AC parts store so they can match up a replacement part for you.
Dec 23, 2008 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
150 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
