Question about Motorola Mobility W385 Cellular Phone
Battery Too Dead to Charge?
Last night, my phone died while I was talking on it. It had started beeping a few minutes earlier, and I plugged it in at that time. I figured I'd turn it back on, let it charge all night, and it would be good. No such luck. When I woke up this morning, I found that it was dead again. I turned it back on, only to have it die about two minutes later (I was not using it, just letting it charge), and I tried turning it on again. All that came up was the motorola screen, and then it shut off again.
I am now worried that it won't work again, because it needs to be on to charge, but if it won't turn on, how can I charge it?
I have suspicions that the outer screen (with the clock on it & such) is to blame for draining the battery while charging.
Please help? Thanks so much.
  • vtien Jan 21, 2009
    I have the same prob, I can only talk on the w385 for 3-6 minutes then it beeps and shuts down. When I charge the phone after a +10 minutes it says Charge Complete, then it only last 3-6 mintutes. It had great battery life before these episdoes. You think it's only the battery and not the phone? I just ordered a new battery, should come in in 7 more days.
  • vtien Jan 22, 2009
    i've notice my son, yanks on the home cord to give me the phone so I told not to anymore. I have to tilt, wiggle til the home charger says "connected". Yet I recently got a new car charger for w385, and it charges right away, whatever position i put it....then same problem...after 3-6 mins..."beep...shutting down". I will wait for the new battery...and see...right now it's not in my budget to get a replacement. hope it's just the battery.
You're on the right track. First check the charging port carefully. If it works intermittently, it's probably shot. If it's shot, the phone is shot. If it's okay, replace the battery. They're dirt cheap on Ebay.
Good Luck!
Adios447
Posted on Dec 23, 2009
The issue is probably not the battery but the charging port. I'm having the same issue. I happen to have Motorola Phone Tools on my computer. It works with the W385 but sometimes doesn't recognize the phone. Battery has 2 bars. If I wiggle the cord, it will recognize it. Then 4 seconds later, lose the connection. I already replaced this phone 5 months ago for the same issue.
I think the problem is the charging port is not working.
Posted on Jan 21, 2009
It might be because its an old battery. I had a phone for 3 years and everytime I took it off the charger maybe 20 minutes later it'd be down a bar or two. You should try taking it to the place you bought it and ask them.
Hope this helped
Ashley
Posted on Dec 22, 2008
My samsung gt 15500 won't charge up. It was working fine 2 days ago and yesterday i brought the usb lead to work with me to charge it with my computer. Nothing happened when i plugged it in so i...
If the phone was totally dead before it refused to charge initially, then the refusal to charge is due to the fact that there was no residual charge left to bring it to a charge, because the battery completely died.
To fix it, kick start the charging process.
Remove the battery, and using a universal charger (desktop charger) charge the battery for say 10 minutes, before re- inserting the battery to the phone and continuing with the normal charging process.
If this does not work out, then problem is with the charging port. It has to be replaced. This can be done by nearby local phone repairers.
Hope it helps?
Success.
May 12, 2011 | Cell Phones
1997 Audi died, lost power acts like bat dead but then starts?
the alternator is not charging and once you run out of battery power car dies when you let it sit battery builds a small charge enough to run short period of time.get charging system checked.
Jan 12, 2010 | Audi A6 Cars & Trucks
My phone was working fine yesterday, It ran out of charge last night and when I put it on the charger thismorning it now just flashes white screen every 5 seconds or so ... is it dead ? cheers Wal
The phone should never be left to die out of charge anytime for good health of battery and phone.
So the problem is that the battery has completely died out so its not getting charged again, it bound to happen sometimes. So all you need to do is get it to a repair shop and just boost the battery initially so that it starts charging again.
Its similar to jump start in a car. So do not worry its a cheap fix only and never let it again to die out of charge.
Nov 21, 2009 | Sony Ericsson W850i Cellular Phone
Bought my phone yesterday...Battery was losing charge quickly.. battery was down to half charge after about 15 minutes of fully charging.. Was trying to let the phone die completley then fully charge it,...
Ok first of all you should never let a phone die out of charge at all.IF it dies out of charge there are chances it might charge again once you charge it but in some cases it wont, you need to boost your battery just like jump start your car.It cannot be done anywhere except some service centre. If you are not taking to your service center , then you need to buy a new battery.
Oct 08, 2009 | Cell Phones
Charged my phone last night and will not turn on this morning
Thats what my phone does when the battery is dead. perhaps it did not charge last night. see if the phone will turn on while connected to the charger. if so, the battery is dead or defective.
Feb 27, 2009 | LG VX5200 Cellular Phone
Charging Black and Decker Simple Start
First plug the charge adapter into an outlet, then plug into the unit. Push the power button to turn the unit on. Now, push the button for the light. The light should come on. At this point you hit the charge button and the green light should start blinking and there will no beeping. Then turn off the light. The green light should continue to blink and the unit will charge. This worked for me, hope it helps!
Jan 19, 2009 | Black & Decker Simple Start Car to Car...
Motokrzr
Well it sounds like a combo of both. Definitly get the battery replaced again. The phone itself probably needs new software. take it your service provider's corp store to get the software updated.
Sep 23, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Cell phone won't charge/or hold a charge
i had that same exact problem, with my razr so i just went out and bought a new battery for like 15 dollars, and now it works like a charm :)
Jun 23, 2008 | Cell Phones
Not Taking a Charge
your phone wont turn on?
try this: pull out the battery, and try starting it like that. try it a few times, pop the battery back in, and see if it works.
Jan 08, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Phone loses connection after few minutes
I looked up the battery specs for your phone. They are 3 X 200mah= 600mah battery packs. They should last 8 hrs talk time with the headsets. This style of battery pack in my experience only last about 1 1/2years and sometimes longer and "sometimes" shorter...much shorter. I bet you never had problems when you first got them. Basicly this "battery design arrangment" goes back many years before newer battery technlogy was developed. But designers still insist on using them even today. They are cheap to make. ****Time to replace them with new ones.**** Make sure you follow the mfgs charging instructions: "After battery installation, place the handsets in their base unit or charger and allow to charge for 16 hours before use. You can keep the battery charged by returning the handsets to their base unit or charger after each use. When the battery is fully depleted, a recharge takes about 12 hours. Average talk time on a fully charged battery is about eight hours depending on environmental conditions, standby time is approximately four days." Good luck
Jul 19, 2007 | AT&T E5640 Phone
Motorola Mobility W385 Cellular Phone Logo
479 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
