Question about Samsung CLP 300 Laser Printer
Samsung printer printing half positive color and half negative
I moved the printer and now it prints color prints that are half positive and half negitive looking prints
  • Anonymous Mar 12, 2014
    samsung printer prints half side
    Sergeant:
    Novelist:
  • 327 Answers
Remove all the cartridges from the printer and shake then all 1 by 1 for 5 minutes.and then reinsert it will work properly.as all the powder in the caRTRIDGE is got collected on 1 side so this type of printout is comming.
thanks.
Posted on Dec 14, 2008
Hello there. I have a Samsung C410W Printer which won't print and keeps giving me a "Paper Jam" error message, when there ISN'T one. It is out of Warranty, was bought secondhand, but it is relatively
You need to check all the flags in the paper path to ensure that they move freely. It is pretty common that when removing a paper jam that these little flags get knocked out of position.
Dec 08, 2014 | Samsung Xpress SL-C410W Laser Printer -...
Every half inch the printer is printing black lines???
If the printhead is printing but is not moving across the page then a single block of print will be produced across the whole page. When this happens the problems include the printhead positioning motor, the timing belt, the home position sensor, the control board or the power supply.
With the power off manually move the printhead to the center of the printer. Turn the printer on to see if the printhead seeks the home position at the far end of the printer. If the printhead moves to the end of the printer and doesn't shut off or doesnt return to the center of the printer then the home positioning is malfunctioning and should be replaced. If the printhead moves on startup but doesn't on printing then the control board should be replaced. If the printhead doesnt move any time check to see if the printer is in maintenance mode. In this mode the printer keeps the printhead assembly in the home position. I f no mode problems are present the positioning motor should be replaced.
Goodluck
Mar 09, 2011 | Lexmark X3350 All-In-One InkJet Printer
My Samsung color laser printer CLP-310N prints a half of a page then stops with the paper still in the printer.
I have the same issue - it is def the driver as deleting all samsung drivers and then getting the printer to produce a self test print works perfectly!
Dec 25, 2010 | Samsung Office Equipment & Supplies
I am curious if there is an easy way to print and change positive to negative. What I mean is I want to print a recipe out of a magazine that has a ligt printing on a dark background. Rather than use a ton...
Yes you can but it's called setting the print color to "black and white" only. This way the solid black page will be just a very light gray and uses less ink.
To change the print color to "black and white", go to your printer icon in Control panel and right click on your primary printer (the one that is on default). Next click the button "printing preferences" or click on the tab that says the same. Click on the tab that says paper / quality and choose the "PRINT BLACK OR WHITE" option.
That should help you save your black printing problems.
Let me know if this worked for you ok?
Aug 09, 2010 | Office Equipment & Supplies
Samsung CLP-315W Color Laser Printer will print only half page
http://www.fixya.com/support/t3934542-exit_sensor_problem_samsung_clp_315
Mar 23, 2010 | Samsung CLP-315W Laser Color Printer
My CLP-350 Samsung printer only prints black ink on half the page! While the other colours all print perfectly, the black ink prints strong and clear on the right side of the page but as you approach the...
Here is my solution, hope it will solve your problem.
From your post, I believe your CLP-350N printer has enough black toner. The black cartridge is on the far right side of the printer, so the black toner is harder to go to left side of the roller than right side. Everytime we start the printer, it will move some toner of each color to the roller before it shows ready to print.
Because we always use B&W printing when we start the printer, but less Color printing. The result is there are always enough toner on the 3 color rollers, but the black toner is lean on the black roller. When this gets worse, the left side of the black roller may hardly get any toner at all -- so it only print black on the right side fo paper.
Step by step solution
(CAUTION: Never loss balance while tilting printer! You may drop and damage your printer! Hold the printer firmly all the time! Ask someone to help you if needed!)
Here, front of the printer is where you can access the cartridge, back of the printer is where you connect the power cord and USB cable, left is your left, right is your right.
1.Lift the front to keep the printer tilt to its back at about 45 degree
2.Power on printer while it's tilted back, wait untill green light is on
3.Open the front door, red light will be on, then close the door, printer will start up again,wait untill green light is on
4.Repeat step 3 once again, then put the printer back to level position
5.Lift the right to keep the printer tilt to its left at about 45 degree
6.Open the front door, red light will be on, then close the door, printer will start up again, wait untill green light is on
7.Repeat step 6 once again, then put the printer back to level position
8.Print some test page to see if there is any improvement of black print quality.(Hold the printer button for 3-5 seconds, it will print the test page.)
You may try several times and print several pages each time before you finally cure the problem.
Good luck! And do it safely!
Jan 09, 2010 | Samsung CLP-350N Laser Printer
Won't print in color. Looks like a negative
Try going to printer settings either via 'file' 'print' or 'start' 'control panel' 'printers'
some printers have settings colour - text - photo - gray scale - chrome - negative etc Click on the one you need & 'save'
Alternatively, if the print has some colour but lacks others you may be out of ink/toner of the missing colour[s]
Dec 23, 2009 | Dell 3100cn Laser Printer
My printer worked fine when I used it a month or two ago to print color photos. Now it is printing them in negative for no reason. Even when I do a preview before printing the preview shows the photo in...
When you are on the print window at the end of the process, look for a "Preferences" or "Options", then look for tabs or other menus that say "Color" or some sort of "output" mode and see if there is a negative option you can disable.
Apr 16, 2009 | Canon Pixma iP4500 InkJet Printer
Color printing negative
Hi, check your printers preference settings that they are set to normal printing and colour printing. Post back if this is no help. cheers lilacgerry xxx
Jan 27, 2008 | Office Equipment & Supplies
Samsung CLP 300 Laser Printer Logo
59 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
