Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
We are stuck in ZOOM. No one has a head!
This problem may have started when we moved recently, but I don't see why that would be the case. The tv was plugged in as it was before, etc. The tv is 'stuck' in zoom mode. We attempted to fix the problem logically by using the remote and adjusting the settings, but for no reason we can understand, the tab for "normal" can't be chosen--it's grayed out on the panel. We were advised by a local tv repairman to simply turn off the set and leave it off to 'reset' for several hours, which we did with no change. What can we do??? Thanks so much.
  • Anonymous Mar 31, 2014
    Cannot get picture to fit screen seems as though the wide zoom is stuck tried several adjustments but to no avail the normal setting comes up as not being available please help!
    President:
  • 1,284 Answers
Are you using an HD cable or sat. box? If so then the settings on that can certainly lock out the zoom/normal feature on the TV. The way you can tell is go to another input and see of the selections are still greyed out. If not then your cable box or sat. rcvr is incorrectly set. Let me know what happens.
Posted on Mar 12, 2007
Is not working properly
A good possibility is the zoom head is causing the clicking sound. As we zoom the flash, the inside of the head moves to the back and forward. Gently tap it a few times see if that helps. My guess is it needs servicing.
Apr 18, 2014 | Canon SPEEDLITE 580EX TTL Flash
Canon 380ex
I had a similar problem with my 430 EXII flash recently and discovered that after using the flash head in a "bounce" orientation, where the zoom automatically sets itself to 50mm, It wouldn't go back to wide angle or telephoto when I folded it back into place. The problem was caused by a small piece of confetti preventing the head from fully resting in the forward position. Check to see if there is any debris caught in there.
Dec 15, 2013 | Canon Cameras
I recently bought speakers for my tv and I don't
We will need the model numbers on both the speakers and the television you wish to connect them to, so we can answer your question.
Jul 21, 2013 | Televison & Video
How do i get aux to work on a rca tv
Some TVs don't have an "input" button(mostly older picture-tube types).In most cases,you select"input" by pushing channel down until you are below channel 3.Start at "3",and keep pushing channel down to 2,1,etc.
Sep 07, 2012 | Televison & Video
Setting up sony bravia kdl46ex400
If you don't have any other signalling devices (e.g. DVD, VCR, etc) then into the cable box.
Jan 24, 2018 | Televison & Video
Power board for 37pf5521d
hello!
You don't need to replace power supply in most cases. If you can to the board itself, it buried deep under metal shield, up side down, remove it from the set by unscrewing 6 machine screws, unplugging few plastic connectors. Be careful, connectors are fragile, gently move those in every direction, while pulling out male part of connectors. You will find at least 1 "bloated" electrolytic capacitor, remove and replace those. It's good have "in circuit" capacitor checker to determine quality of "hot side" of power supply capacitors. If you won't find and replace those, small: 1mf 10mf or 22mf, your set will start up, might even work fine for a while, then will quit for good! I've seen that happen! If you don't have capacitor gizmo, then replace all small electrolytic capacitors on "hot" side of power supply. "hot" is that side, what connects to main power in plug area, contents one large capacitor, I.C. chip diver, power mosfet, etc. worst case scenario: if you can't replace those parts yourself, remove the board and take to local TV repair shop. It won't cost you that much to do so, compare to complete TV repair.
Good luck,
Alex.
Feb 19, 2012 | Philips 37PF5521D 37 in. HD-Ready LCD...
Just recently my sharp aquos lc 40 e is stuck in stretch of wide screen and the heads or top of things are being cut off. When i go to view mode it only gives me 4 options wide, stretch dot to dot or zoom...
Not all TV programs are broadcast in 1080. When you use zoom or stretch on a program in 720 or 480 and a 1080 program is viewed you have to go back and take off zoom and stretch to get a correct picture.
Aug 29, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
04 Nissan Sentra recently installed remanufactured OEM Rockford Fosgate stereo. Problem: CD player does not play, displays "error 1"
Sometimes CD players come with a plug that keeps the reader arm in place during shipping. If you don't remove this plug it doesn't allow the arm to move, thus a code. You might recheck this. If that's not the case, check your warranty papers, you might need to use them.
Aug 22, 2011 | Rockford Fosgate Car Audio & Video
Picture has gotten darker over recent months regarless of signal source and continues to get darker. Brightness is set to maximum.
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos aroundimages.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Aug 02, 2011 | Hitachi 53SDX01B 53" Rear Projection...
Can't access all the channels. I moved tv from one
You didn't say what model number, but check the setup menu to make sure it is set for cable (if you are using cable) and not AIR. Otherwise let me know the model number and what you are using for signal (cable, satellite, etc.)
Jul 04, 2011 | Sharp Televison & Video
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
242 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
