Question about Lite On (LTR-52327S/5238S) (LTR52327S5238SBKRE) CD-RW Burner
CD-RW Problem Okay my problem is that when the cd drive is powered on all i get is the led (never ending) and when i push the open button it will not open
  • Greg Woodard Mar 12, 2007
    I think the motor may be burned out
    I think the motor may be burned out or something (it started after lightning struck my house... but i thought it had a good surge protector) I tried what you said, but to no avail. I asked one of my friends (works for Slipstream PCS) and he told me that the motor is burned.
    Can I replace the motor or should I just buy another one
    (CD-Burner)?
    President:
  • 1,257 Answers
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Posted on May 02, 2008
    Novelist:
  • 198 Answers
There some few tips you can try. Power down the computer then open the cd tray by inserting a sharp object in the small hole near the tray. Look for this hole, then using the sharp object push it pretty hard. With the other hand try to pull the tray out. Once you've pulled it power on the computer (with the cd-rw's tray opened) and watch what the cd-rw is actually doing now. If after it retracts the tray it is doing the same, you will need to dissasemble it. If you are willing to try this, please post another message and also specify there what did the cd-rw drive do when you've applied the method i've told you before.
Posted on Mar 11, 2007
  • Motoi  Bogdan
    Motoi Bogdan Mar 12, 2007
    Whell, I don't think the actual motor is burned out. The speed on wich the motor is turning is regulated by a set of electronic components. They are a diferent part then the actual motor. To modify the motor's turning speed, they modify the value of the current the motor receives. As they are positioned between the power source and the motor, an electrical power spike will damage them, and because when those components burn out the connection with the motor is severed, the motor is "saved" in this way.
    However it is easy to know this. You have to dissasemble de cd-rom drive. Remove it from the computer first. Open the tray (like before, sharp object in that small hole) then remove the four screws on the unit. The front cover (the plastic front side) must also be removed from the metal part. In the end you must remove the upper and bottom part of the metalic covers to expose the motor and lens mechanisms. There is more then one motor. One will spin up the disk, and other will move the lents across the cd surface. You'll see them both. Also there is a servomechanism (kind of a third motor) that moves the lents up and down. All 3 of them must work in proper order for the cd-rom to work. Even the failure or decalibration of one will cause the cd-rom to fail to read or write cd's.
    Here's what you can do. If you dare to try, dissasemble the unit in such way that you can see the circuit board and the components mounted on it. Look very carefully at them to see if you can spot any burned out components. The black chip's, the ones with lots of pins are especially vulnerable. Check them first looking for anything unusual on their surface. If somethings is burned out or damaged, you will shurelly need the unit replaced, as no one has the spare parts to change the damaged ones in a certain model. Only by an incredible luck, but most service centers woun't even attemt such a repair.
    If you see no visual or evident trace of damaged/burned out components do the following.
    First check to see if the lents block is near the central motor. If it isn't, or it is located anywhere else on that line use your hand to carefully move the lents block away from the central motor (in the middle, the one who spins the disk) as far as they go. Then move them back to the central motor as much as they will go. Carefull not to touch the actual lents (blue, or white ones in the center of the lents block).
    After that, assemble the unit back, power it on normally and check out what happens. If this doesn't work, your unit is damaged beyound repair. This happens pretty often when lightning strikes. good surge protection isn't allways enought to stop the power spikes that follow a lightning.
SOURCE:
Sony DVD ROM will not open, light comes on and tries to open but will not. Other DVD works fine. What with the Sony DVD?
try to find a tiny hole on the drive( near LED or eject button) and insert a niddle or some kind of hard pin which can go inside of it push little bit hard (drive will open) , dont keep your drive empty if not in use put any useless DVD ROM in it so that it will get open when you want to use
Apr 24, 2010 | Sony CRX320EE-88B CD-RW/DVD-ROM Combo...
Cd drawer will not open
To open your cd drawer.On the front of your cd you will see a small pin hole,straighten out a strong paperclip and push the end through the hole,and this will release the catch and open the tray. Push hard as the catch will be quite stiff. Hope this helps you.
Regards Bill
Mar 14, 2010 | QPS Que! USB 2.0 Drive CD-RW Burner
My cd is broken inside my lG cd rom what should i DO Now
Hi
Thank you for your query
If you look at the side of the CD rom drive i.e. where the button is that you push to open and close the CD drive there will be a very small hole. If you open up a paper clip and poke the end into that hole you will notice the drive will pop out, once the drive has come out all you need to do is open and remove the broken CD
If this has been useful please leave positive feedback/vote/testimonial as this will help me greatly - Thank you again
Feb 14, 2010 | LG SecurDisc 8x External Double-Layer DVD...
My CD Drive Is Not Opening & Not Showing To The My Computer =(
if when you push the button its led flash but not opening, turn off your computer and open its door by a needle enter and push it in the ole in center of its panel under the door. whon the door open a little use your hand and open it. if the this not solve the problem there is a hardware problem :( But if the drive dosent work at all (even the led light) maybe it's the power, then open th case left door and check th power cable... I hope this helps...
Nov 02, 2008 | Sony (CDU5212) Internal 52x CD-ROM Drive
Tray will not eject on LTR 16102B CD-RW
Most likely due to a worn belt. You can use a paper clip in the manual eject hole while pressing the button repeatedly to get it open. The belt or the drive will need to be replaced.
Jul 07, 2008 | Lite On LTR 16102B CD-RW Burner
Drive won't open
u can see a pin hole on the drive just above the open button or the green light...press the button once n poke the hole with a pin ,,,,it ll hit a soft end...continue pressing it with some force....the tray will open...
Jan 02, 2008 | LG Super-Multi GSA-4163B 16x8x16x DVD+R/RW...
Cd rom tray open problem
normal problem for samsung cd drives . clean the rails of drives that which tray is commin out . it mainly caused due to the change ina laaingnment of drive tray
Dec 04, 2007 | Samsung (DSSMBK482448) CD-RW Burner
Adaptec Burner Problem
If you have a cd in there you can manually get it by using a paperclip and inserting it into the small hole in the front of the drive. It may be possible that your drives are not receiving any power. Are any of the LEDs at the front of your drive on at any time? If not, then it is almost certain that your drives have become disconnected from your motherboard. If this is the case, just open up your computer and make sure that there are at least 2 cables going to each of your drives and that the power cable (which should have white ends with 4 pins) is indeed connected to your drive on one end and your power supply on the other end. Dont forget to check your Bios and try the drivers for an update.
Sep 10, 2007 | Adaptec (OP-CDRI-LIT-CDDVD) CD-RW/DVD-ROM...
Computer doesn't recognise CD drive at all
This may not help, But worth trying. First make sure the eide braid is connected firmly on both end and the power cord is pushed in all the way. if all that is okay do a Google search for lite on they have a website with lots of drivers and firmware upgades. Just need to find yours in the list. Good luck
Jan 06, 2007 | Lite On SOHC-5232K CD-RW/DVD-ROM Burner
Lite On (LTR-52327S/5238S) (LTR52327S5238SBKRE) CD-RW Burner Logo
126 people viewed this question
Top Lite On Computers & Internet Experts
Bill DeLisi
Bill DeLisi
paul shaw
Level 1 Expert
Damen Wong
Damen Wong
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
