Question about Kenmore 30172 / 30174 / 30179 Gas Single Oven
Oven flame Once the oven lights flames shoot up into the oven itself. We have adjusted everything suggested in the manual but it still does this. What do we do??
  • Anonymous Apr 13, 2008
    flames licking at the door
  • Anonymous Nov 27, 2008
    same problem
  • Kenmore Master
  • 4,655 Answers
Did anyone try to assist you on the oven comment listed
 03-11-2007 ? I just began doing this help and would like to know if you found the problem or solution with someone willing to help you. It is also possible that Gas ovens and there uncertainty are a sensitive subject especially with your description of the problem. Let me Know Thanks, Sea breeze
Posted on Oct 26, 2007
Trouble shoot oven
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. I offer free advice bcuz God is so good!
GAS OVENS
The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Apr 26, 2015 | Whirlpool Ovens
Hot surface igniter will glow and put out a flame but is not a blue/orange flame
First you need to get a nice blue steady flame to prove to the ignition module there is flame. Check you orifice and bypass tube.
Feb 22, 2014 | Lincoln Impinger 1116 Gas Oven
Broiler flame on hotpoint stove needs adjustment
as in height of flame? if its too large a flame and you have switched from natural gas to propane gas you must turn the orfice spud down onto the orfice face to adjust it,just land it lightly,do not turn it down overly tight
May 05, 2012 | Hotpoint Ovens
I have a garland oven model st286 it wont light even though there is gas getting to it and the spark is working. It lights if you light it manually
Instructions
  1. Access the burners inside your oven by removing the access panel in the front of the oven or by opening the broiling drawer, depending on your particular model.
  2. Determine if the pilot itself is lit, since some ovens have a small flame on the pilot at all times that then grows and extends to the burner when the oven is turned on. The lack of a pilot flame indicates the oven thermostat is malfunctioning or there is a problem with the gas hose. Check the pilot itself to see if it is clogged with debris or grease that could be preventing the flame from staying lit.
  3. Determine if the pilot flame will grow if it is lit by turning on the thermostat. If the pilot flame doesn't extend, the thermostat itself likely needs replacement. If the flame is extending but the gas valve is not opening, the safety valve could be dirty or defective. The flame should be blue in color. A yellow flame indicates the pilot is dirty and is not burning hot enough to get the main burner to ignite.
  4. Light the burner on the top of the oven with a match if the igniter doesn't appear to be effective. If it lights manually but will not light automatically, the igniter is likely faulty. Do not do this if there is a heavy smell of gas in the kitchen, since there could be a risk of a fire. In that circumstance, turn the oven off, ventilate the room and call a technician.
  5. Listen for any sounds of gas hissing or a clicking sound indicating the oven is trying to turn on. If there is no response from the oven at all, the gas may not be functioning properly and will need to be examined by a technician for safety purposes
Jan 26, 2011 | Ovens
Burners work, broiler works, oven DOES NOT get hot
Might be a bad sensor or spud out of adjustment and the flame is too low. themobilian_494.jpg
The nut to the right is the adjustment turn ccw to increase flame.
Generic picture
themobilian_496.jpgthemobilian_497.jpgI have a service manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 19, 2010 | Maytag CWG3100A Gas Single Oven
Canon Carrick LPG cooker-failure of full flame control bottom oven I have had this cooker for 14 months and used it for 6 months only from new. The bottom main oven has just started to play...
I had the same problem. I solved it by re-attaching a device which had come undone. On the right hand side of the burner is a rod with a metal wire attached. This was lying loose. It should be fixed to a little grey clip which is itself attached to a a piece of metal. By re-fixing the clip and the rod to the clip it solved the problem. Hope this helps. I have photos of how it should look. email info@music-works.uk.com for a JPG.
Dec 01, 2010 | Ovens
I have a bakers pride pizza oven and the bottom oven Including the pilot light) continue to go out for no apperant reason. I have changed the thermocouple 3 times and the pilot light once. Sometimes it...
Several things to check. First be sure the pilot light flame is directly striking the thermocouple. It is a pencil sized rod that is next to the pilot light. Sometimes people reduce the size of the pilot flame to save gas. You may need to increase the pilot flame. Follow the small gas line from the pilot flame back to the gas valve. There is a screw where the small pilot gas line goes into the valve. Remove the screw and then deep in the hole is a tiny screw that can only be reached by a tiny flat blade screw driver. Turn the screw counter clockwise to increase the pilot flame. The thermocouple needs to be red hot to work properly. The second item to check is to see if there are any breezes that occasionally blow through the kitchen. Sometimes the hood fan will draw air under the ovens and actually blow the pilot flame out. Same fix, increase the flame. You may also experience low gas pressure to the appliance during heavy usage. You would need a manometer gauge to check for proper gas pressure. In short, if the oven goes out during your busiest time when everything gas powered is on, the oven may be starved for gas.
Sep 09, 2010 | Bakers Pride FC-616 Gas Single Oven
Kenmore gas oven model no. 273 3248296 pilot free ignition wont fire up
Hi
If it won’t fire then it is possible that the oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The flame needs to heat the bulb up enough to tell it to open the gas valve. Several things can go wrong here that keep this from happening:
The pilot flame may not be hot enough, usually because the flame is yellow instead of pure blue or is too small. The cause for this is usually a dirty pilot assembly. The pilot assembly would either need to be cleaned or replaced.
The thermocouple bulb may not be positioned properly in the flame. You can't heat the bulb properly if it's not in the pilot flame! The thermocouple bulb needs to be in the upper third of a pure blue pilot flame--that's the hottest part of the flame.
The thermocouple itself may be burned out. It happens. It's an internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
But when you turn on the oven or the thermostat calls for heat, the pilot flame gets bigger and jumps down so it can heat up the thermocouple bulb. This extra gas to increase the pilot flame size comes from the thermostat.
If the pilot flame jumps upwards or just gets bigger, but doesn't shoot down, then you need to replace the pilot assembly.
If the pilot flame size does not increase or jump down when turning on the oven thermostat, then the problem is the thermostat not sending enough gas to the pilot assembly. It's also possible that the pilot gas supply tube has a hole in it somewhere.
One final point on the spark-assisted pilot ignition systems. The spark comes from the spark module--the same module that sends spark to your surface burners to light them up. If you're not getting a spark when you turn the oven on, then there are several possibilities:
There could be a problem with the switch in the thermostat. You can confirm this by doing a simple continuity test of the thermostat contacts. If you don't read zero ohms when you turn the switch on, replace the thermostat.
The spark module could be bad. You'll need to measure the voltage at the oven terminals of the spark module when you turn on the oven. If you get 120v but no spark, it's probably a bad spark module. Replace it.
Could be a bad spark wire or broken electrode.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Ovens
Upper & Lower Broiler Flame Adjustment
MY KENMORE OVEN BURNER FLAME IS TO HIGH AND IT WILL NOT TURN LOW
Jul 16, 2008 | Ovens
Bakers pride pizza oven
does it light then immediately go out? if yes, usually you have to hold in a button to allow gas to flow while you light the pilot, and hold this button until the therm0-couple is heated with the pilot flame. If the thermo-couple is not sufficiently heated and you let go of this button, the pilot light will go out as the safety circuit thinks there's no flame and unburned gas is entering the oven.
The other thing you could do is adjust the height of the pilot flame... there's usually an adjustment screw near the button described above which will allow you to adjust the height of the flame. Make the flame just big enough to guarantee that it keeps the thermo-couple hot AND that it can light the oven without being blown out.
Good luck.
Apr 21, 2008 | Ovens
Kenmore 30172 / 30174 / 30179 Gas Single Oven Logo
69 people viewed this question
Top Kenmore Ovens Experts
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
