A key came off of my dell 1525 inspiron keyboard
It is the p key and I want to know how to fix it
    Master:
  • 474 Answers
There should be the key, and a X movement piec of white plastic that it connects to with a rubber nipple in the center.
did the white X bracket come off also, or just the Key?
If its just the key itself, then look at the bottom of it. One side will have push in clips and the other will have littl flapped groves. you lay the key on the keyboard and slide the groved part into the nubs that are on the X bracket and then press down to push the clips onto the cliped part.
Thats about it.
Its hard to be any more detailed as this is delciate work. You should slide then push down.
you will have to determine the direction based off looking at the bottom of the key.
Posted on Dec 13, 2008
3 Suggested Answers
  • 461 Answers
SOURCE: dell notebook keyboard malfunction
I suspect just as you suggested something was spilled on it. Other than loose keys laptop keyboards are generally not repairable. They are not that difficult to replace, but check the Service Manual before deciding to do it yourself.
Posted on Dec 17, 2008
ikechinedu
  • 184 Answers
SOURCE: I need to install a keyboard for a Dell Inspiron
Before you begin, Follow these steps carefully;
  1. Shut Down to turn off your computer. Ensure that the computer is off and not in a power management mode. If you cannot shut down the computer using the operating system, press and hold the power button for 4 seconds.
  2. Disconnect your computer and all attached devices from their electrical outlets. Disconnect any telephone or network cables from the computer
  3. Remove any installed cards from the ExpressCard slot.
  4. To help prevent damage to the system board, you must remove the battery from the battery bay before you service the computer. to do this, Turn the computer over, Slide the battery release latch until they click into place. Slide the battery out of the battery bay.
  5. Turn the computer top-side up, open the display, and press the power button to ground the system board. Now you are ready to remove your Keyboard;
  6. Removing the Center Control Cover, Remove the two screws securing the center control cover from the battery bay,
  7. Turn the computer top side up, and open the display as far as it will open.
  8. Insert a plastic scribe into the indent to lift the center control cover on the right side and ease the center control cover up.
  9. Disconnect the cable from the media control buttons connector located underneath the center control cover. NOTICE: To avoid damage to the data cable connected to the system board, ensure that you do not pull hard when you are raising the center control cover. NOTICE: To avoid damage to the center control cover, do not lift the cover on both sides simultaneously.
  10. Remove the center control cover.
  11. Remove the two screws at the top of the keyboard. NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard.
  12. Lift the keyboard and hold it up and slightly forward to access to the media control buttons connector.
  13. Disconnect the media control buttons connector and remove the media control buttons cable.
  14. Lift the keyboard and hold it up and slightly forward to access to the keyboard connector.
  15. To disconnect the keyboard cable from the keyboard connector on the system board, rotate the keyboard connector latch toward the front of the computer.
  16. Slide the keyboard cable out of the keyboard connector.
  17. Replacing the Keyboard
    1. Slide the keyboard cable into the keyboard connector.
    2. Rotate the keyboard connector latch to secure the cable.
    3. Align the tabs along the bottom of the keyboard and slide them under the palm rest.
    4. Press on the right edge near the top to snap the keyboard into place.
    5. Replace the two screws on the top of the keyboard.
  18. Replacing the Center Control Cover
    1. Reconnect the media control buttons cable to the connector below the keyboard.
    2. Align the tabs along the bottom of the keyboard and slide them under the palm rest.
    3. Press on the right edge near the top to snap the keyboard into place.
    4. Replace the two screws on the top of the keyboard.
    5. Reconnect the media control buttons connector to the center control cover.
    6. Insert the left edge of the center control cover.
    7. Press from left to right until the cover snaps into place.
    8. In the battery bay, replace the two screws that secure the center control cover.
Posted on Apr 17, 2009
DELL INSPIRON 1525 HELP
It should be a simple fix. Start your laptop and pay attention to the screen. Press the F12 key (or F11) to enter "SETUP" then find the NUMLOC command and make sure that its DISABLED or OFF. This will turn this option off andyou will only be able to use the number's keys on the top of the keyboard. Be careful when entering SETUP. You don't want to change anything you don't have to.
Dec 26, 2011 | Dell Inspiron 1525 Notebook
The F8 and F9 keys on my Dell Inspiron 1525 are messed up. Do you know where I might purchase those two keys from?
Dell is notorious for shipping several different types of keyboards (as far as the tiny parts under the keys are concerned) from different manufacturers. While the entire unit fits and plugs in exactly right, chancing replacing keys is risky. I speak from experience having repaired 100's of Dell laptops.
I recommend buying a new keyboard from one of the vendors at the link below. Then go to Dell support and you'll find your Service Manual there to replace the keyboard. It's relatively simple.
It's worth the 15 bucks...believe me
http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=dell+inspiron+1525+keyboard&_sacat=See-All-Categories
Best Regards,
Marcus
Sep 14, 2010 | Dell Inspiron 1525 Laptop
Keys 3,e,d & c does not work on my Inspiron 1525?? what has happn an what shoul I o
I had the same issue, I don't know if what I did had anything to do with the fix or if it was just pure luck, I held the Fn (Function) key then hit the letter (e) a few times and it started typing. Hope this helps anyone that may experience the same problem.
Dec 25, 2009 | Dell Inspiron 1525 Notebook
Stuck keys
You don't have to buy a whole new keyboard to replace few keys. Try taking off the key cap and its retainer clips (plastic pieces underneath the key cap). Repair it yourself with the help of this video:
Nov 29, 2009 | Dell Inspiron 1525 Laptop
My Dell Inspiron 1525 Laptop keyboard is malfunctioning. It is either not responding or keys are always engaged and I cannot log on. I was told by a technician to buy a new keyboard from Dell Philippines...
Hmm you know ebay has alot of keyboards for laptops , very cheap too, would be no harm typing your laptop name + keyboard into ebay, ive often bought them from there for people. hoep this helps
Nov 29, 2009 | Dell Inspiron 1525 Notebook
How do i get my enter button back on my inspiron 1525?
The keys just pop on and off. If the key will not snap back on, then the keyboard will most likely need replacement.
Replacement keyboards are less than $20
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1311&_nkw=dell+inspiron+1525+keyboard&_sacat=See-All-Categories
Oct 23, 2009 | Dell Inspiron 1525 Laptop Midnight Blue
Delllptop inspiron 1525 key rubbe came out.
Yes, dell will relace the faulty part absoultely free, if your laptop is under warrienty, you need call to dell technical support and log a call, you have to provide your system service tag when you are talking to Dell person. Make sure you sould not loose the key rubber, you need to submit that to Dell Engineer
Aug 06, 2009 | Dell 0Y3740 Keyboard
Certain letters are not working
When keys go faulty the entire keypad needs replacing. You can't replace individual keys. I would suggest contacting dell and ordering a new keyboard, it's an easy fix: http://www.essortment.com/articles/install-replacement-keyboard-dell-inspiron_102151.htm
If you need to purchase one, I did locate: http://yallstore.com/laptop-keyboard-replacement-for-dell-inspiron-1525-p-4228.html For $16
May 23, 2009 | Computers & Internet
I have a new key board but I don`t no how to remover the broken one its a dell inspron 1525 lap top
The link below will take you to a step by step guide for replacing the keyboard:
http://support.dell.com/support/edocs/systems/ins1525/en/SM/keyboard.htm#wp1180346
Good luck and please let me know how you do with the replacement.
~ Spoem
Apr 13, 2009 | Dell Inspiron 1525 Notebook
Dell notebook keyboard malfunction
Dec 17, 2008 | Dell Inspiron 1525 Notebook
Computers & Internet Logo
549 people viewed this question
David Payne
David Payne
