Question about Sony Playstation 3 (PS3) Console
Ps3 freezes at startup screen/ green red dots/lines,
Hi,when i turn ps3 on the console freezes up with multicoloured lines across the screen,im unable to do anything then and cannot acces xmb screen.ive tryed holding down reset button and tryed the original scart output but still the same from both scart and hdmi.i left the console off for the night and tryed again in the morning and i got into a game then after 5 mins it froze up again,,,,then same thing again now unable to get back to xmb,,,any help would be much appreciated
  • 6 more comments
  • james990 Dec 13, 2008
    I have simuliar problems. I believe its the hard drive, unfortunately.
    as i boot my system up, it says rebuilding hard drive. the system been freezing up repeatably. I may have accidentally turned the system off while the HDD light was flashing, which corrupted the hard drive.
  • Anonymous Dec 14, 2008
    I have a 60 gb ps3 which I got last Christmas.  It worked fine, and then I was playing cod4 when the same thing happened to me.  I turned it off and played it again in the morning and 5 minutes into the game it froze.
  • sgerst08 Dec 21, 2008
    I have the exact same problem. I was updateing it and it froze during the update so unfortunately i shut it down with the main power switch and the next time i turned it on it did it again. i havnt had any luck figuring it out. I tried to re-format it (quick) but that didnt do anything.
  • Anonymous Jan 18, 2009
    The same thing is happening to me, i was playing a game and the console froze, all appears now is the swirly line, left it for a few days and tried it again, still nothing, the menu has disappeared
  • Anonymous Mar 21, 2009
    I've format hard drive, change to a brand new hard drive, and restore PS3 system, etc. and nothing worked.
  • Anonymous May 07, 2009
    I have this same problem but rather than colored lines i get little colored dots everywhere on my screen. It has slowly became worse. i have a 20 gb so i just figured it was getting old but really for the price that they were they should be good for longer than a couple of years or at least i think they should be.
  • Loul Zakarya
    Loul Zakarya Feb 24, 2014
    Solved :) PS3 shop said damaged processor and i should give up but the solution is: 1- Go to any computer that has maintenance department. Ask for thermal paste (looks like white paste) it is also called (Cooler component) it is very cheap ( 5 LE here in Egypt) injection like. Buy 2 is more than enough. 2- Disassemble your PS3 (you have to know what to do) tell you reach 2 metal silver squares (i think it is the processors) on the mother board right before you reach the ventilation fan. (you could watch youtube under title fixing overheating PS3) 3- Remove the old coating thermal paste (mostly you will find it black like burned) by napkin and any pc cleaning liquid till it is all removed. 4- Some video suggests to heat that 2 squares with special heating gun so i did it in case but i used the hair dryer. I am not sure if this step is helping or not but i did it in case. It is heating the squares and push lightly on it in case some of the connection was loose a little, it gets back in the place. Wait till it cool down for around 15 minutes. 5- Start to spread the new thermal paste you bought it equally on those 2 squares and do not splash on the rest of mother board around (clean it if you do). Spread using plastic credit card like. 6- You are done. Reassemble the PS3 and turn it on and go along with the messages will appear and enjoy. I have been playing for an hour and it is fine.
  • Loul Zakarya
    Solved :) PS3 shop said damaged processor and i should give up but the solution is: 1- Go to any computer that has maintenance department. Ask for thermal paste (looks like white paste) it is also called (Cooler component) it is very cheap ( 5 LE here in Egypt) injection like. Buy 2 is more than enough. 2- Disassemble your PS3 (you have to know what to do) tell you reach 2 metal silver squares (i think it is the processors) on the mother board right before you reach the ventilation fan. (you could watch youtube under title fixing overheating PS3) 3- Remove the old coating thermal paste (mostly you will find it black like burned) by napkin and any pc cleaning liquid till it is all removed. 4- Some video suggests to heat that 2 squares with special heating gun so i did it in case but i used the hair dryer. I am not sure if this step is helping or not but i did it in case. It is heating the squares and push lightly on it in case some of the connection was loose a little, it gets back in the place. Wait till it cool down for around 15 minutes. 5- Start to spread the new thermal paste you bought it equally on those 2 squares and do not splash on the rest of mother board around (clean it if you do). Spread using plastic credit card like. 6- You are done. Reassemble the PS3 and turn it on and go along with the messages will appear and enjoy. I have been playing for an hour and it is fine.Add a Comment
Turn off the PS3 with the switch on the back, then turn back on. wait till the light is solid red then hold your finger on the start button for abount 10 seconds until you hear it beep twice.
It will then ask you to connect a controller via the usb cable and press the PS button. Once you do this it will bring up the reset menu.
Unfortunately the only way I found that solves this is a full system restore that wipes the hard drive completely.
You do however retain and data saved online such as COD stats etc and playstation store purchases with your PSN.
Hope this helps??
Posted on Jan 02, 2009
I tried that method before, the whole system restore and all. I thought that it would work...but those pesky green pixels filled the screen and brought the freeze along with it. then my ps3 would not start up at all, i tried multiple time to start it, and nothing happened...just a black screen.
I left it alone for two days and tried turning it on, it started right up, i played bionic commando for about 20mins and then turned it off just in case... i played the same game the very next day (bionic commando-the remake) and maybe 10mins into the game, it freezed again. i just turned it off.
I called power gamer and told them about my problem, gave them my ps3's symptoms and they suspect at cpu, or gpu issue... it cant be fixed, Im going to have to buy a new one.
in other words when something like this happens, something is getting very hot inside of our system. overheating and shorts. Im going to backup all of my data that's on my faulty ps3 and buy a new one, and then transfer the data to the new one.... sucks...but hey i had my ps3 for a while now.
Posted on Nov 15, 2009
    Problem Solver:
  • 6 Answers
Your hard drive may be messed up.
I suggest getting someone to look at it or get a new one.
hope this helps
Posted on Dec 13, 2008
I am having issues with mine same as most above.
I would like to try and reformat/restore settings but it freezes before i can even get the settings page.
Some times the tv doesn't even recognise that there is anything plugged in.
When i leave it for a while it loads up normally but then freezes.
with colourful pixels all over the screen.
Taken it apart, cleaned it still nothing.
i have fixed YLOD on it twice would this have caused something else to break?
it has worked since the last YLOD fix but its b*g*rd up now.
Any one got any solutions as to how to reformat hard drive if you cant turn the ps3 on?
Posted on Oct 30, 2013
  • Tomham
    Tomham Nov 05, 2013
    I really couldnt figure out what the issue was. Luckily my friend had an broken playstation as well. His issue was a broken disc drive. So i took the two apart swapped over the drive. So unfortunately i only managed to fix his playstation and not mine, but as he already had a new one i got a working playstation out of it. Sorry this isnt really any help as to how to fix it.
I've had the same problem for about a month now and restored my file system three times and rebuilt my database several times
Posted on Dec 17, 2012
I am having a similar problem except instead of lines i get small coloerful dots across a blank screen. I've tried the restore file systems. but that didnt work. I called sony and they basically couldnt help me. They told me the only way to fix it is to format the system. But I would really hate to lose everything. is there any other way to solve this problem. I am able to hear the sounds of the ps3 starting but it will not dipsly anything other than the blank screen and dots. PLEASE HELP!!!!!
Posted on Jan 10, 2012
  • gvang96
    gvang96 Sep 09, 2012
    Well when you reformat it you wont lose all your stuff like your online stuff or the things you purchase at psn store but you just lose crappy stuff which is good but it is my opinion and also i have the same problem except when i start the ps3 5 seconds later green lines come out of nowhere and freeze my ps3 so i dunno if some one can help me
Hey guys i tried to but fan beside the play station 3 and that give me 30 second playing and its freez again but when i restart it its work for another 30 min so i think its a problem fan all u need is change the fan in ps3 ill try to do that soon today and ilet u guys know
Posted on May 01, 2010
  • almla May 01, 2010
    its overheating????!!!!
Actually the most likely culprate I found was dust in the system. Some people fixed this with the fanning method (turn ps3 upside down verticaly for awhile), but mine still didn't work. IT's something you could try though.
Posted on Nov 27, 2009
2 Suggested Answers
SOURCE: hi,when i turn ps3 on the console freezes up with
listen just hold down the button, i'm not sure how long like you hear 2 beeps then 3 or something and it will take you to a screen with 6 or so options - choose restore file system, you shouldn't loose data if your lucky, anyway i had a very similar problem and my ps3 sat for a year before i was smart enough to figure this one.
Posted on Mar 04, 2010
When I try to play my ps3 it will freeze up and show these red and green lines on my tv
This is a GPU chip problem, it has a bad connection to the motherboard, that can cause YLOD, no picture, freezing, pixilation, no hard drive activity, no synchronization with the controller through the USB cable , colors get missed up , see lines and different forms of pixels on the screen then it freezes, all these symptoms indicate a bad connection between the GPU chip and the motherboard, there is only one real solution , Reballing the GPU chip , PS3 GPU chip is a very sensitive chip due to the fact that it has a built in memory chips so you need a very reputable place to do that procedure for your console , the photo story you see is an example of the reason and the solution and the link is for the place to fix it for you and give you a one year warranty on the repair.
56c8f7ed-37a5-4044-aae4-c4667c5361b8.jpg 0080ee9a-6834-4bf3-aa92-040ee20db882.jpg PlayStation3 GPU Reballing service
Apr 21, 2014 | Sony Playstation 3 (PS3) Console
Freezes on home screen with red and green going across the screen
It's called the "PS3 Red Light of Death". Time to buy a new one.
May 15, 2012 | Sony Playstation 3 (PS3) Console
When i turn my ps3 on the light on the front comes on green then goes to amber and then goes back to red meaning its turned its self of, nothing comesup on the screen either, plus with it doing this there...
The best way to fix PS3 light goes amber and back to red is to fix by yourself! Learn the PS3 fixing technique by using this product here :
PS3 Ultimate Fixing Guide
This is a package of text and video tutorials written by a professional PS3 repairman. Follow his demo you can easily to unscrew your console and fix parts inside. When you have learned the repair skills, no need to ask anyone here again!
Aug 10, 2010 | Sony Playstation 3 (PS3) Console
Hi,when i turn ps3 on the console freezes up with multicoloured lines across the screen,im unable to do anything then and cannot acces xmb screen.ive tryed holding down reset button and tryed the original...
Feb 02, 2010 | Sony PS3 40GB Best Sellers Bundle Console
When PS3 boots the screen turns green with white dots
Emergency cooling should be cleaned. If not cleaned, you risk expensive repair.
Oct 24, 2017 | Sony Playstation 3 (PS3) Console
Console freezing in main menu after a min green and red dots
do not perform fan test not good for unit. use vacume to clean out unit. if it was the motherboard it wouldnt turn on at all.
Jun 01, 2009 | Sony PlayStation® 3 (60 GB) Console
Game freezes and dots appear on screen
I hate to break it to you, but you may have gotten the Red Ring Of Death. It happens when playing a game and it is transmitted through online play through Xbox Live. 3 red lights will appear around the power button when your console has become infected. The Red Ring of Death may have infected your console causing it to shut down. Most Xbox 360 consoles won't turn back on but some do turn back on but they just won't play games, they will freeze up and have the dotted lines and make the buzzing noise. I'm sorry, but I think you may need a new console. You're in luck if it's still under warranty. Hope this helps!!!!
May 20, 2009 | Microsoft Xbox 360 Elite Console
Xbox 360 freezes and Dotted Lines Appear
hi
my xbox has the same problem as above, also we have three red lights on console is there a solution?
xbox live :leighjay
Nov 26, 2008 | Microsoft Xbox 360 Console
Sony Playstation 3 (PS3) Console Logo
12,121 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
