Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Icemaker just stopped making ice.
About four days ago, I noticed that when I pressed for crushed ice, it took almost a minute before I got crushed ice if any at all. When I looked into the ice holder, I found there was only a small amount of ice in it. So I closed it back and did not try to use it for a day. There is no ice being made. There is water coming through, but no ice. Can anyone tell me what to look at in order to solve this delema.
  • 1,031 Answers
This problem often happen with the refridgerator, , you will need to replace the ice maker. to get it working well again it cost about $100 .
Posted on Dec 13, 2008
No crushed or cubed ice being produced
Ice tray may not be filling. Have a look under or on the side of the icemaker., Some have a little button to reset it. Press and hold the button in and see if the ice tray rotates and refills with water.
Nov 20, 2016 | Refrigerators
Samsung RFG298AARS is cylcing between crushed and cubed ice several times a minute and chimes each time it does that!
\it could be that the switch for the ice selection is stuck or just went bad and shorted out. You can check with appliancepros.com to get price of switch and trouble shoot the problem
Apr 07, 2014 | Samsung RFG298HDRS 29 cu. ft. French Door...
Describe your frigidaire frs23f5a freezer
With ours it is ice collection on the fan in the freezer section. This is located about half way down under the icemaker (please unplug to proceed). If you remove the four hex head screws and lift up the metal flap you will find the fan assemble and most likely the ice build up to chip off.
Jul 01, 2010 | Frigidaire FRS23KF7AB Side by Side...
Our Jenn air fridge is a few yrs old. A few
ok stop the water // the water valve is bad..very bad . change it ..its a dual valve in the back . right where the lin is hooked up . this will correct problem .. **** hope this helps . i think it will .. / feed back pls ..
Jan 12, 2010 | Refrigerators
Ice maker has stopped working. It was fine 3 days
check water valve or icemaker valve is at the back of the unit
Apr 07, 2009 | Admiral 26 cu. ft. Side-By-Side...
10 yr old Frigidaire ice maker stopped making ice
try forcing the cycle by manually triggering the cycle a few times. Sometimes you can detach the trip arm or turn the tray by hand by disconnecting it from the gear. There may have been a switch bumped to turn it off or the switch somehow jammed. Maybe check for freeze-up. If there is water in it, it's going somewhere.
Sep 27, 2008 | Frigidaire FRS26R4A Side by Side...
Ice maker stopped after electric shutoff
You may have a problem with the computer control board in the ice maker.  Try this.  Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button.  Press and hold this button for 12 seconds to get it to force extract.  This will confirm that the motors will work and push the ice cubes out.  Afterwards, let it run by itself.  If it still doesn't make ice, you will need to replace the icemaker.
Sep 19, 2008 | LG LSC26905TT Side by Side Refrigerator
My icemaker is not making ice. This has happened 3 times in the past 3 years but this is the longest it has gone without making ice. The other 2 times it lasted 2 days. It has now been 4 daysince the ice...
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
May 15, 2008 | Amana Refrigerators
check to make sure the fill tube is not plugged with ice if it is not then i would guess the valve is shot
Oct 30, 2007 | Frigidaire FRS3R5EMB Side by Side...
Whirlpool icemaker not giving cubes, only crushed ice
If less than a year old should still be under warranty
Sep 05, 2007 | Whirlpool ED2FHEXN Side by Side...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
99 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
