My inspiron 9300 lcd screen displays a dark screen with a dull image in the background.a new screen and inverter was put inplace but the problem remains the same. When hooked to an external monitor the display is ok. What can I do to correct this problem.
    President:
  • 1,952 Answers
. It has an antiglare coating that gives it a dull shine when turned off. On a reflective screen like or Dell screens with TrueLife you'll easily see your reflection with the screen powered off. The coating is not annoying and appears to be uniform over the panel.
Unfortunately, here is where the Samsung LCD panels fail. Black is some shade between grey and black over the entire screen. There is even a characteristic pattern in Samsung screens where the center seems to have the least leakage and there's a small circle about the size of a USA quarter in the top center where there is no leakage at all. If you like deep true blacks then this system will not please you. However, I do want to note that normally it's not noticeable unless you're playing a dark game like Doom 3 or others where there are large dark areas on maps. Light leakage on both the 6000 and XPS2 Samsung screens is minimal at the bottom, but it is there.
Color on the 6000 and any Dell Samsung screen is warm and dull without adjustment. You'll want to immediately jump into your video properties and adjust your contrast, brightness, and others. I like a contrast of about 111%, brightness of 98%, and a gamma of 89%. One of the drawbacks of having an ATi card is that there is no digital vibrance control which really livens up the picture on my XPS2 to make the colors on par with a Sony and Princeton Graphics Senergy LCD. You'll want to play with the color settings and other programs at some point if you're really concerned about having your colors jump out and catch your eye. For most people the simple adjustment I outlined above should be enough.
Posted on Dec 13, 2008
  • mohammed marika thambi
    mohammed marika thambi Dec 13, 2008
    www.laptoprepair101.com/laptop/2006/02/22/troubleshoot-fix-laptop-video-problems/all-comments/ - 742k
    www.laptoprepair101.com/laptop/2006/01/31/dell-service-manuals/all-comments/ - 277k -
    Genius:
  • 1,199 Answers
His is called byrn in (from displaying the same graphic for too long! your going to have to replace screen!
  • 13,433 Answers
The backlight is not functioning, check the cables between the monitor and the motherboard, make sure backlight is at max, theres a button combination for that and it debends on laptop, surely documented in the manual.
you need to replace the backlights most likely
Follow this guide http://www.inventgeek.com/Projects/BacklightFix/Page1.aspx
How do i brighten mytouch screen it looks dull gray? the light use to be brighter in the background know it seems to look dingy and graish not bright it looks ike a lightbulb went out and it makes it...
The dark screen with faint, hard to see display is due to the failure of (i) CCFL (Cold Cathode Florecent Lamp) OR LED, which is the back light or the (ii) Inverter board, which provides high voltage to the CCFL. So, it is recommended that you get it properly checked by any professional for replacement of CCFL/LED.
Also, refer here to my earlier solution to a similar problem, which was rated as very helpful
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
placement of CCFL.
Jan 06, 2011 | HP Computers & Internet
Hello , everyone and experts people. I have a Fujitsu Siemens Esprimo Mobile V5535. laptop good start, green LED lights up, but i have a black screen without any background applications. I tried to pick...
Hi dejandan1
Sorry to hear you are having problems. The very fact you tried an external monitor shows you have some good IT skills. As long as you know this monitor works it is a good test. As you have no image try toggling the video output signal by using Fn (Function) and the CRD/LCD (Cathode Ray Tube/Liquid Crystal Display) keys or Alt (Alternate) and the CRD/LCD keys.
If this does not workthen it is either
1. Laptop on board graphics failure
2. Laptop LCD panel failure
3. Laptop inverter failure
4. Laptop backlight failure
Turn on your laptop and look closely at the screen, can you see what you would normally see but very very dark? If so it is the backlight. If you cannot see anything, which is likely, then it is the inverter, actual panle failure or grahipcs chips on the motherboard.
http://www.daileyint.com/hmdpc/lcd.htm
philswift.gif Above is a link and flow chart that will help you.
It is most cost effective to send or take the laptop in for repair. You can replace inverters yourself but there is guarantee it is that. If the graphics on the motherboard has failed then all you can do is have the motherboard replaced. If the laptop is slow and old it may be time to consider a new laptop. If the laptop is under warranty, goto the Fujitsu Siemens website and log a under warranty repair.
All the best, Phil
Dec 06, 2010 | Fujitsu Siemens ESPRIMO P2500 PC Desktop
Hi There, I've been experiencing the same setback as Kenneth. My lenovo 3000 flashed off and even if I boot it, the screen is still black.How ca I fix it?./ Ty
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.lcdparts.net
Oct 16, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Screen
I assume your computer boots up, the hard disk spins and the hard disk LED light flashes.
If so then you may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
Sep 11, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Laptop screen is totally blank as a duster with magnet was used to wipe the screen by erros
It is highly unlikely that using the magnetic duster could damage a LCD screen except putting scratches on the surface of the screen. There is nothing in a LCD screen that can be affected by a magnet. A magnet will affect a CRT monitor because a magnetic field will affect/deflect the electronic beams that hit the color phoaphorus dots on the screen.
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 05, 2009 | Computers & Internet
I have a HP Pavilion laptop ze4900. Every time I move th screen, the display either goes off completely, or it goes vey dim and I cannot read anything from it. The only thing I can do to get a display
  • Picture flickering with dim display.
May 03, 2009 | Computers & Internet
a
Apr 21, 2009 | Computers & Internet
Dark screen with dull image in background
You may need to check your desktop image for your monitor and change it to something lighter
The external monitor usually uses your computer's default and not ncessarily the one from your laptop monitor
Without taking it apart myself, it could be some wiring from the laptop to the screen
Dec 13, 2008 | Computers & Internet
I've acer travelmate 4500 laptop. Till yesterday it was working fine, but today i donno what happend to it.. the screen display is completely dull. that I couldn't see the display and if I closely observe...
The possible reasons is that you have turned down your brightness and contrast without realizing it, to fix this simply look for a brightness key on your keyboard and turn it up. If it is missing or did not fully work, see if you can notice any image and try to get into your Display properties, click the setting tab and go into advanced and turn up your brightness and contrast from there. If this does not work, im afraid to say you have damaged your LCD screen and this would result in your dull screen appearance. Get a computer technician to take a good look at it to see what has happened if this is the case
Hope This Helps
Nov 18, 2008 | Acer Computers & Internet
My WXGA 15.4" LCD laptop screen for DELL Inspiron 6000 is temperamental. Works most of the time, but when I start up computer the bottom 1/2 of screen looks like color streaks down it (all...
The issue could be one of 2 things. The image inverter or the LCD. From the description it could be either.
Both can be found here:
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=inspiron+6000+LCD&category0=
The inverter is fairly cheap ($20 to $50) the LCD around $150.
Service documents are here:
http://support.dell.com/support/edocs/systems/ins6000/en/sm/display0.htm#wp1006390
Aug 04, 2008 | Computers & Internet
Computers & Internet Logo
29 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
