Question about Timex T601GT Clock Radio
How can I reset radio stations?
I really need to find a replacement user guide, but I pressed the 'reset' button and now the FM radio station for my alarm is no longer valid. I can't reset the radio station as an alarm.....
  • Anonymous Mar 17, 2014
    Some mornings cannot hear the station because of the noise. High rise building. Can an external antenna be attached?
I have a solution for you. I called Timex. Just go to http://www.timexaudio.com/support.asp
Posted on Jun 18, 2007
  • 944 Answers
Please try timex; Timex Corporation 555 Christian Rd. Middlebury, CT 06762 CT Tel. 203-346-5000 Fax 203-346-5139 i have been unable to find one online - best thing to try is see if you can find a dealer who is selling it and ask if you can copy a manual - they may oblige. Hope this helps a bit :)
Posted on Mar 11, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Mar 11, 2007
    this link has a lot of customer reviews for your model, some discussing controls - maybe help;
    http://www.amazon.com/gp/product/custome...
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
Apr 30, 2014 | Cars & Trucks
Changed battery now radio will work on am only when i push the am/fm button the display reads set1
When you replaced the battery, it reset the radio. You will need to reprogram the radio stations you want on fm. Find the radio station you want and then press the set button on the radio and then the corresponding number on your radio (ie: set1, set2, set3, set4 or set5)
Feb 27, 2011 | 1995 Jeep Grand Cherokee
How do I preset the tuner for radio stations. I've never had a problem doing this with any other stereo. But what I think should work isn't!
Not very specific. Do you have the manual?
The following is from a VSX-03TXH manual. It ain't pretty but it may help.
I'm posting it in multiple parts due to space contraints.
37
Chapter 6:
Using the tuner
Listening to the radio
The following steps show you how to tune in to FM and
AM radio broadcasts using the automatic (search) and
manual (step) tuning functions. If you already know the
frequency of the station you want, see Tuning directly to a
station below. Once you are tuned to a station you can
memorize the frequency for recall later-see Saving
station presets below for more on how to do this.
1 Press the FM/AM button to select the tuner.
2 Use the FM/AM button to change the band (FM or
AM), if necessary.
Each press switches the band between FM and AM.
3 Tune to a station.
There are three ways to do this:
Automatic tuning
To search for stations in the currently selected band,
press and hold TUNE ?©/?? for about a second. The
receiver will start searching for the next station,
stopping when it has found one. Repeat to search for
other stations.
Manual tuning
To change the frequency one step at a time, press
TUNE ?©/??.
High speed tuning
Press and hold TUNE ?©/?? for high speed tuning.
Release the button at the frequency you want.
Improving FM stereo sound
If the TUNED or STEREO indicators don't light when
tuning to an FM station because the signal is weak, press
the MPX button to switch the receiver into mono
reception mode. This should improve the sound quality
and allow you to enjoy the broadcast.
Using Neural THX
This feature uses Neural Surround™, THX® technology to
achieve optimal surround sound from FM radio.
• While listening to FM radio, press AUTO/DIRECT for
Neural THX listening.
Dec 23, 2010 | Pioneer VSX-07TX Receiver
My Grundig Satellit 700 Radio is not working on FM Band but is working well on AM and Shortwave Band. After pressing ON/OFF button and FM/RDS-AF button when we try to operate the FM Band of this radio...
As a side note, most AM/FM radios use a separate antenna for each band, thus why you can pick up AM but not FM. Check your mast antenna connections to make sure they are solid and not missing or loose.
Dec 10, 2010 | Grundig Audio Players & Recorders
Sony walkman fx281 says hold when I push AM or FM button How do I turn on radio?
Srt HOLD switch to Off position as shwon in below image so Radio will start work.
Thanks.
Feb 05, 2010 | Sony Walkman WM-FX281 Personal Cassette...
I can t figure out how to connect my radio up like i got the cd player to work just fine but the radio doesn t work
Press the source button to select fm, press and hold BTM button until Btm flashes. This will automatically store stations for you. Page 8 in this users guide covers same as well as manually setting stations. You do have the antena connected?
http://www.docs.sony.com/release/CDXGT20W_200.pdf
Oct 23, 2009 | Sony XPLOD CDX-GT200 CD Player
How do I preset radio stations on my hi-fi system?
Owner's Manual is PN 3834RH0020U
On pg13
1. Press TUNER/BAND to select AM or FM
(Leftmost rectangular button on left of volume knob)
2. Select station by using TUNING +/-
3. Press PROGRAM/MEMO on the remote
A preset number will appear.
4. Press PRESET +/- (or PRESET ^/v on remote) to
select the preset number you want.
5. Press PROGRAM/MEMO again. The statio is stored.
6. Repeat above for more stations.
Believe you can store up to 30 stations.
Apr 28, 2009 | Denon DRA-375RD Receiver
No radio in menu. only music. voice .settings .
The service may not be available in your area. Make sure the headphones are connected to the player when searching for radio stations: Here's pg 15 of the user manual:
FM Radio (if applicable)
The Sansa
player includes an integrated FM radio for listening to live broadcast FM
stations. Please note that the FM Radio function may not be available in your region.
Listening to FM Radio
To listen to live broadcast FM station, follow these steps:
1. Select FM Radio from the Main Menu.
2. A radio frequency menu will appear.
3. Press |<< or >>| to adjust and search for the desired frequency, or select
preset by pressing Select.
4. For fast search, press and hold the |<< or >>| buttons.
Feb 20, 2008 | SanDisk Sansa Clip MP3 Player
Timex T601GT Clock Radio Logo
235 people viewed this question
Top Timex Audio Players & Recorders Experts
Gyula Lacz
Steve Allison
Steve Allison
Are you a Timex Audio Player and Recorder Expert? Answer questions, earn points and help others
