Question about HP OfficeJet 7410 All-In-One InkJet Printer
HP 7410xi small plastic piece in print cartridge carrier broken
A small plastic piece in the print cartridge holder which holds the spring which supports the black cartridge in place broke off. Is it worth repairing or should I just replace the printer?
  • Anonymous Apr 01, 2009
    Thanks for the picture. I have the very same problem - a puncture in the flex cable - in the exact same location.
  • Anonymous Apr 06, 2009
    A SMALL PIECE OF PLASTIC BROKE OFF THE INK CARTRIDGE HOLDER AND I KEEP GETTING AN ERROR READING TO REMOVE AND CHECK CARTRIDGE N RIGHT. I TRIED TO GLUE IT, BUT IT DID NOT CORRECT THE PROBLEM...
    Scholar:
  • 137 Answers
If the spring did not damage the carriage flex I would suggest just using some epoxy to hold the spring properly in place. If the spring did damage the flex (as shown in this picture) then you might contact HP and enquire about an extended warranty for this issue. In the US call HP at 1-800-HPINVENt.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Posted on Mar 02, 2009
Thanks for the picture...that's exactly what I have. I used crazy glue to hold the spring, then realized the flex is damaged. What should i do?
Posted on Dec 26, 2009
How to fix broken hp6500 cartridge holder
Get HP Printer related all issues solved, contact and visit now... HP Printer Support
Aug 26, 2014 | Office Equipment & Supplies
X-spring tab broken in ink receptacle (HP officejet 7310)
I think you right. There are a lot of small parts which are finely tuned in a printer and most likely something else is still affected.
You probably are better off purchasing a new unit, unless you have the time and patient to figure it out.
Good Luck!
Sep 16, 2009 | HP OfficeJet 7310 All-In-One InkJet...
The ink cartridge I replaced in my printer is not working.
I have one of these printers (7210-7310) with this same problem and this is what is wrong with it. There is a small wire spring that holds the ink cartridge in place in each cartridge holder. Remove the color cartridge and inspect the ribbon cable (it gray) inside the ink cartridge holder. There is a big problem with these HP printers where the spring pokes a hole the ribbon cable breaking one of the wires and rendering the printer useless. Poor design by HP, sorry.
Mar 07, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Printer keeps telling me to remove and check left cartridge, which i have done and have installed a new one, with the same message coming up.
I'm not sure if this printer has one but some HP printers have a small ribbon cable that connects to the cartridge holder. There is a small wire spring that holds the cartridge in the holder, however this spring will puncher the ribbon cable rendering the printer useless telling the user to insert a new cartridge. Way to go HP.
Feb 25, 2009 | HP OfficeJet 4255 All-In-One InkJet...
The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Jan 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Black cartridge is not being recognized, amber light blinking
Nov 10, 2008 | HP Officejet 7210 All-In-One InkJet...
Hp 6110 remove and check cartridge
this kind of hp printer, have often a specific problem with a cartridge carriage. If you can observe (with a flashlight) inside of cartridge carriage, on the right side of carriage, you can see a small piece of spring made from steel, which is moved from his place, because an broken little piece of plastic.
if you see the spring which is moved, you also may see the hole created by the spring on the electrical contacts of the cartridge carriage.
if you can see the hole... you have a very bad news.
i dont know how much cost the repair of printer, but I tell you, this printer is discontinued.
Sep 22, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Carrtiage jam
buy a trash can and throw the thing in it. I had my hp7410 do the same thing. when i looked at where the cartridge locks in, there is a spring that is held in alignment by a tiny plastic tab. it was broke causing the spring to not stay in place. 3 screws hold the housing on and when i took them loose and pulled the head out, there was a small wire attachment that lights a sensor. i tried numerous times to set the head right and if i can find a manual to show me how to replace the head (don't know what the head will cost) i will get the trash can out and buy another brand.
Jun 05, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Hp Office jet print cartridge error
Remove the cartridge and look at the cartridge holder. There should be a spring sticking out from the right side of the holder. The spring on these often breaks loose and will not allow the cartridge to seat properly. (Look at the left holder and compare it to the right one. They should look alike.) If the spring is loose, meaning the holder is broken, the holder needs to be replaced. I've tried gluing the spring in place but did not have good luck with this.
Feb 20, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Cartridge holder busted
We also had the same problem. We remove the black cartridge, placed a small machine screw or bolt where the head would hold the spring in place. Make sure the head is flat enough so that it will not push the cartridge to the left and cause it to print erratic. You might need small hands to screw on the nut for your bolt. I now prints and faxes, just the LED panel still says to check the right cartridge.
We can live with that!!
Sep 13, 2007 | HP Officejet 7210 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
617 people viewed this question
Seeker5211
Seeker5211
