Question about Hitachi 43FDX01B TV
Blue Yellow Wave
There is a blue and yellow wave across the top half of the screen and a sort of ghost below pictures on the screen. I have to drive this 43" TV to another town for repair and was wondering if you could help me either solve this problem or suggest what the approximate cost would be to repair. The TV is approx 4 years old.
    Sergeant:
  • 308 Answers
I believe what you have is a convergence problem and it is usually caused by two Integrated Circuits going bad which also opens up one or two resistors associated with them. Replacing the Convergence Ic'S - (Ik04 & Ik05) and Resistor Rk62 a 1.8 Ohm .5w. Metal Film type should take care of the problem. As far as costs involved, I would guess about $350-$425 to get repaired. With it only being about 4 years old, it should have that many more years left of good use for you.
Posted on Mar 12, 2007
  • george k Jun 28, 2012
    you hit the nail on the head one of the head I missed soldering one of the pins on a Ic's bingo! blue and yellow converged. Thanks
Luxor lux0140001B/01 1 week old picture has top half with a grey see through screen
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Check the cables, connectors and connections.
Apr 12, 2014 | Televison & Video
I have a Hitachi Projection TV (43FDX01B). It has a blue wave across the top to middle of the picture/screen. I suspec it may be some sort of bulb replacement. I do not have a user manual. Thank you
Its much more likely to be a convergence issue with the blue . Does writting appear sort of 3 D looking? The user manual I have for that model if you want to send a request to slinteriors@yahoo.com I will email the user manual to you.
Aug 21, 2011 | Hitachi Televison & Video
Hitachi 53udx10b screen is dark, very blue and red. there is a red wave across the top of the screen. there is a blue "ghosting" of any text on screen.
The tv have a problems known as a convergence picture problems,it is dead.Tv set have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead to causes all these problems.Now the tv set convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv set convergence board to solved the tv set convergence pictures promblems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 18, 2011 | Hitachi 43UWX10B 43" Rear Projection...
Blue wave across top, opened up, cleaned mirror and lenses, blew out dust in lower portion.
not a clear description... could be a blue retrace line(problem with blue picture tube) or blue convergence(defective convergence IC)
Oct 29, 2010 | Hitachi 43UWX10B 43" Rear Projection...
I have a blue and yellow wave across the top of my tv its a hitachi 53udx10ba
Ur convergence it dead.U know how to solders?Must replaced 2 Convergence ICS and all it resistors.Tries Tv Repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Jan 17, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi TV 43FDX10B has yellow line with blue curve line above it
It sounds like your convergence ic's are messing up
They have a kit for this tv it is available through local parts distributors
If you can't find it locally just Google HITACHI CONVERGENCE KIT
If you are not good with de-soldering and soldering do not attempt this repair. Remember to replace all the resistors in the kit
If you are not sure about doing this repair you should have your local tv guy do it for you
Jan 27, 2009 | Hitachi FDX Series 43FDX10B 43" Rear...
Toshiba 57h81 green will not focus
Typically this is a convergence problem and can be repair relatively easy. Refer to this video to determine if you truly have a convergence problem. Also make sure you use your TV's original remote to make this adjustment.
Nov 15, 2008 | Toshiba 57H81 57" Rear Projection...
Blue wave across screen
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
Double images and colors are blurry .Blue,red and yellow wave coming up from the bottom of the screen on the lower left symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Sep 08, 2008 | Apex Digital GB5108 51" Rear Projection...
Hitachi 43FDX01B TV Logo
96 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
