Question about HP Compaq ProLiant ML530 Server
Explorer.exe - application error
When i open few of the folders which contain videos this application error box appears. and when i click on iether cancel or ok..all explorers shut down.
explorer.exe - application error
the instruction at "0x6fc63ad3" referenced memory at "0xfffffff0". the memory could not be "read".
    Problem Solver:
  • 6 Answers
Try the following to gather additional information.
Run a test on the hard drive(s) for any bad sectors via chkdsk
Run a memtest to verify the integrity of the physical memory. I would suggest the memtest via the Knoppix CD.
Look in the Windows Event Viewer, Application and System log for any possible resource contention issues or other system problems.
Posted on Dec 28, 2008
Hp 1402 fatal error and MSI.scan
Hi Ihan,
You are facing terrible problem with that error message.. However we can try to fix it. There are few methods you can do..
Solution 1.
  1. Insert the product software CD into the CD-ROM drive on the computer.
  2. Right-click Start and then click Explore . Windows Explorer opens.
  3. Locate and select the CD-ROM drive that contains the product software CD.
  4. Locate and double-click the Setup and then the Scan folders to open them.
  5. Double-click Data1.cab or Scan.cab to open the contents of that file.
Extract, rename, and save the filesLocate the following files, right-click them, select Extract , and save them to the Windows Desktop. Leave Windows Explorer open after extracting the files.
  • F1922_TWUNK_16.EXE.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the Desktop, right-click it and rename it to TWUNK_16.EXE .
  • F1923_TWUNK_32.EXE.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the desktop, right-click it and rename it to TWUNK_32.EXE .
  • F1928_TWAIN.DLL.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the desktop, right-click it and rename it to TWAIN.DLL .
  • F1939_TWAIN_32.DLL.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the desktop, right-click it and rename it to TWAIN_32.DLL .
Then you have to copy these files to C:\windows\system32 folder ( this means overwrite the files ) and try to install the software. it should work.
for better understanding check the link below.
MSI.SCAN Solution
Solution 2.
you need to remove all the HP Printer entry from Add/remove or Programs and features under Control panel.
Then download the latest software from HP website by clicking on the link below.
HP PSC 1402 Printer Drivers
Regards,
Suhail
Oct 19, 2011 | Office Equipment & Supplies
Tip
Alternate method to access Application Recovery/Recovery Manager in HP PC
Scenario: Recovery manager or Application Recovery on your HP Desktop PC doesn't work or you are unable to access Application Recovery or Recovery manager.
Tip:
For Application Recovery:
1. Click start, my computer.
2. Open C: and Windows Folder.
3. Open SMINST folder within Windows folder.
4. Double click appinst.exe to open application recovery.
For Recovery Manager:
4. Double click restore7.exe to open Recovery Manager.
If above folder is not found. Then,
1. Click start, run. Clear contents of run box.
2. In run box, type "D:\hp\apps" without quotes and hit ok.
3. This will open a folder that would show couple of folders. These are the applications shipped with your PC. You can identify the software you need. In that folder, open SRC folder. You will find setup for the application here. Install the application from here.
on Jan 18, 2010 | Computers & Internet
Tip
Set a new Windows Explorer launch folder When you run Windows Explorer, it...
Set a new Windows Explorer launch folder When you run Windows Explorer, it always opens to the Libraries folder. That's fine if you use Microsoft's default file organization, which designates Libraries as the overall container for your folders. But what if you don't? You might prefer to have Windows Explorer open to Computer or any other folder you choose. Here's how to do it:
1. Right-click the Windows Explorer icon on the taskbar (it's the one that looks like a folder), and then right-click the Windows Explorer icon from the context menu that appears and select Properties. The Windows Explorer Properties dialog box appears.
2. You'll have to edit the Target field on the Shortcut tab of this dialog box in order to change the default location at which Explorer opens.
If you want Explorer to open to a specific folder, simply enter the name of the folder, substituting your folder name for Folder, below, like this:
%windir%\explorer.exe c:\Folder
So to open Explorer to the folder named Budget, you would type this in the Target field:
%windir%\explorer.exe c:\Budget
If you want Explorer to open to special, pre-set locations, such as Computer, you'll need to enter special syntax in the Target field. Following is a list of three common locations and the syntax to use, followed by the syntax for the Libraries folder in case you ever want to revert to the default.
  • Computer: %windir%\explorer.exe ::{20D04FE0-3AEA-1069-A2D8-08002B30309D}
  • My Documents:%windir%\explorer.exe ::{450D8FBA-AD25-11D0-98A8-0800361B1103}
  • Network: %windir%\explorer.exe ::{208D2C60-3AEA-1069-A2D7-08002B30309D}
  • Libraries: %SystemRoot%\explorer.exe
3. After you've changed the Target field, click OK. Next time you launch Windows Explorer, it will open to the new location you've designated.
on Jan 12, 2010 | Computers & Internet
CD html presentation-hyperlinks don't work with other pc's
To create an Autorun-enabled CD-ROM, proceed as follows:
  • Create an Autorun.inf File
    Autorun.inf is a text file that is located in the root folder of your application CD-ROM. It provides to the computer the name and the location of the startup program for your application that is installed when the CD-ROM is inserted. The Autorun.inf file can also contain optional information including the following:
  • The name of a file that contains an icon that represents your application's CD-ROM drive. This icon appears in Windows Explorer instead of the standard drive icon.
  • Additional commands for the shortcut menu that appears when the user right-clicks the CD-ROM icon. You can also specify the default command that runs when the user double-clicks the icon. Autorun.inf files are similar to .ini files.
  • The [autorun] section contains the default Autorun commands. All Autorun.inf files must have an [autorun] section.
  • icon: Specifies the path and the file name of an application-specific icon for the CD-ROM drive.
  • open: Specifies the path and the file name of the startup application.
Autorun.infThe following is an example of a simple Autorun.inf file. It specifies Filename.exe as the startup application. The second icon represents the CD-ROM drive instead of the standard drive icon.
[autorun]
open=Filename.exe
icon=Filename.ico
May 07, 2009 | Dell Dimension 4600 PC Desktop
Link from e-mails
Hi
If clicking a hyperlink in Outlook Express appears to do nothing at all, there are likely one or more registered file associations that are configured incorrectly. To repair the associations:
Open My Computer and click Folder Options on the Tools menu.
Click the File Types tab.
Select URL:Hypertext Transfer Protocol in the list of registered file types.
Click the Advanced button (Windows XP), or the Edit button (other versions).
In the list of Actions, select open and then click the Edit button.
The Application used to perform action box should contain this, including quotation marks:
“C:\Program Files\Internet Explorer\iexplore.exe” -nohome
If instead it contains a short name version of that path, or an incorrect path, change it to the above.
Click OK, click OK.
Repeat steps 3-7 for the file type URL:Hypertext Transfer Protocol with Privacy.
Click OK to close the Folder Options window.
Feb 25, 2009 | Computers & Internet
I'm unable to open .eml attachment in Windows Vista.
Here's some info: E-mail message saved by Microsoft Outlook or other e-mail program; may also contain an e-mail attachment, or file sent with the message. Note: If EML files will not open in Outlook Express, try the following:
  1. Open My Computer.
  2. Select Folder Options from the Tools menu.
  3. Click the File Types tab.
  4. Under Registered file types, select EML Outlook Express Mail Message, then click Advanced.
  5. Click Open, then click Edit.
  6. Type the following line in the "Application used to perform action" box:
    "C:\Program Files\Outlook Express\MSIMN.EXE" /eml:%1
  7. Click OK twice, then close the window.
EML files may also be opened in Internet Explorer since they are formatted the same as .MHT files; changing the file extension from ".eml" to ".mht" should cause the file to open directly in Internet Explorer.
Hope this helps.
Dec 25, 2008 | Computers & Internet
No new icon even after the program shows successful completion
OK, if the program can be found in the start menu, (Start/all programs/ "the program")
Then right click on it and select " Send to> " move across the next select box which appears and select " Desktop (create shortcut)
If your program isn't in the start menu, then go Start / Control Panel / Add or remove programs (XP) OR Programs & Features (Blista) check if the program you installed is listed, if it isn't reinstall it, if it is, Right Click on Start and select "Explore" Find the Folder in the tree called Program Files, in that folder find the Folder with your program name, in that folder drill down to you find the program name .exe (it will be type Application) double click and find the one that opens the required program eg. CinePlayer is here, Local Disk (C)/Program Files/ Roxio/Digital Media Plus/CinePlayer/CinePlayer.exe
Right Click and select Desktop (create shortcut) and/or Pin to Start menu
Sep 28, 2008 | Computers & Internet
Vids wont work
Before you put your videos on your player, you have to convert them in MTV format with the software provided in the CD that comes with your device.
Jul 01, 2008 | Coby MP-C7085 MP3 Player
My video converter won't convert saome of my vids?
1. In Menu scroll down to Setup
2. In Setup scroll down to USB Mode
3. In USB Mode there are 2 settings MSC Mode & MTP Mode, check or highlight
MSC Mode. This enables the PC to recognize the player as a removable
Device or Drive.
4. Connect to PC via USB port/cable, the PC now reads the device as
MP-C70X5 (E:)
5. In WIN Explorer click “Open to View Files”, on display will be 6 .DIR folders
& a .xml file
6. Now launch the VideoConvert.exe (application file) located on the
installation disk.
7. Click Input Video button (Browse to the folder containing .avi files) & select
.avi file for .mtv conversion
(if you want to save the .mtv file to a different destination folder click the folder
icon to the right of the Video Output text box).
8. In Output Frame Size box check 176X144 (this is the max size for this
device).
9. In Output Frame Rate box check Sports Video.
10. The Output Audio Quality box defaults to Good.
11. Click Start Conversion button.
12. The saved .mtv file can now be copied to the device by simply dragging
from its destination folder or ctrl + C & ctrl + V to the MOVIE.DIR folder in
WIN Explorer as per step 5.
13 The .mtv file is now saved to the device ready for viewing, however there is
just one remaining small lissue which may a software glich or another hassle
with this player, because whilst playing video’s every 60 seconds in the
background a womans voice exclaims what sounds like “Weeee Gamble
whatsup with that.
ionfreez
Jun 28, 2008 | Coby MP-C7085 MP3 Player
Mp3
Device or Drive.
MP-C70X5 (E:)
& a .xml file
installation disk.
device).
with this player, because when the video is playing, every 60 seconds in the
whatsup with that.
Jun 23, 2008 | Coby MP-C7085 MP3 Player
HP Compaq ProLiant ML530 Server Logo
274 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
