Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Admiral LTF2112ARW cooling problems
I turned off my refrigerator for several months, and now when I turned it back on, the refrigerator and freezer won't cool down. It is an used fridge that came with my house, and I don't have the manual for it. It sounds like the compressor and the fans are all working fine, but it won't cool down.
    Novelist:
  • 161 Answers
First I would make sure the compressor is running.
Unplug the Ref. for about 15-20 min, plug it back in and listen for the compressor to start. You will have to be behind the Ref to tell the difference between the compressor fan and the compressor. If the compressor clicks and doesn't run then the relay on the compressor should be replaced. If it runs then it is probably low on coolant.
Posted on Dec 21, 2008
I have an Admiral LTF2112ARW refrigerator. The refrigerator is working but the freezer won't stay cold even though the thermostat is on the coldest setting. Any suggestions about what is wrong?
ITS NOT A GOOD IDEA TO USE THE COLDEST SETTING CUZ WHAT U WILL GET IS EXACTLY THE OPPOSITE A MORE WARM SETTING. A HIGH SETTING CAUSES THE COMPRESSOR TO OVER WORK IT SELF CREATING TO MUCH COLD IN ONE SECTION TO THE NEGLECT OF THE OTHER SECTION. UR PROBLEM IS NORMALLY THE OTHER WAY AROUND TO MUCH FREEZER AND NOT COLD IN FRIDGE.? BUT i WOULD CHECK THE THERMISTORS IN THE FREEZER. AND ALSO TRY ADJUSTING UR SETTINGS TO MED AND CHECK UR AIR FLOW CONTROL VENT AKA COLD CONTROL THERMOSTAT.
Feb 23, 2015 | Admiral Refrigerators
My Admiral mullion is hot
Probably the defrost element has failed, ice & frost will continue to build up & it's ability to cool will deminish over time. Has to be checked & possibly replaced.
Nov 20, 2013 | Admiral Refrigerators
Not cooling
It's probably either a defective thermostat, fan or compressor.
May 14, 2012 | Admiral Refrigerators
My Admiral side by side fridge freezer is not self defrosting. Hence the fridge freezer stops cooling. When I switch it off and defrost it and then switch it back on it works for about a month and then the...
If your Admiral refrigerator is not equipped for automatic defrosting, your only alternative is to defrost it manually every month. There is a reason why automatic defrosting has become so popular.
Dec 08, 2017 | Admiral 26 cu. ft. Side-By-Side...
I have an older admiral refridgerator, when you open freezer it sounds like water dripping on a hot skillet. I unpluged it, later pluged it back in and wont come on
The sound was water dripping on the defrost coil...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 25, 2010 | Admiral 26 cu. ft. Side-By-Side...
Side by side Admiral freezer freezes but fridge
check the damper vent door between the refrige and freezer and make sure its opening up to let cold air from freezer into the refrige,sometimes they freeze up and cant open and close when called upon to do so,if so deice it with a hair dryer,the side being hot is good telling you the compressor is operating correctly
Jul 28, 2010 | Admiral 26 cu. ft. Side-By-Side...
Freezer and fridge not cool enough
Check if the syrofoam pieces block air inlet. If so then this may be the problem.
May 08, 2017 | Admiral Refrigerators
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
626 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
