Question about Bachmann James The Red Engine Train Set
Trains do not work Bachman HO
After three years in a box we set up the train set last night and it does not work. The transformer gets slightly warm when plugged in but when moved into the forward or revesre postion the trains do not move or make any noise. Where shoud l I begin in trying diagnos and fix the problem? We don't even remember the configuration of how the transformer is to be plugged into the tracks.
4 Suggested Answers
SOURCE: Bachmann HO train set not working
I realized that you can't use two left hand turnouts because they end up making a short when the come full circle!
Posted on Jan 19, 2009
SOURCE: Need Z4000 transformer (trains) manual
We were able to locate a Z4000 transformer manual. Found out our problem was a connection problem with the track and not a problem with the transformer. Thanks anyway.
Posted on Jan 01, 2010
  • 59 Answers
SOURCE: ENGINE DOES NOT MOVE VERY WELL AND IS LOUD
depends what a filter or pump the engines hawe cood bee the fuel pump or filter
Posted on Nov 10, 2010
SOURCE: I have an HO scale
Check the engine motor and second car motor with a digital multimeter for continuity. Make sure the track is connected properly. Also probe the transformer and see if it is sending out power to the track
Posted on Dec 20, 2010
Thomas only runs on power track
PDF]EZ Command instructions.qxd - Bachmann Trains
www.bachmanntrains.com/.../EZ_Command_instru...
Bachmann IndustriesINPUT: 120 VAC 60Hz. OUTPUT: AC 16V 1000mA ... After the track connections are complete, plug the Wall Pack Power Supply into a standard 110 ... If your Control Center does not power up as shown here, disconnect it from the Wall Pack ...
[PDF]5 Amp Power Booster - Bachmann Trains
www.bachmanntrains.com/.../449105-AMPInstructi...
Bachmann IndustriesNOT RECOMMENDED FOR CHILDREN UNDER 14 YEARS OF AGE. ... The E-Z Command® 5 Amp Power Booster provides extra power to the track so ... locomotives on our N, HO, OO, S, O, On30, or Large Scale layout. ... Make sure the smaller plug end is connected to the DCC input jack marked DCC IN (figure 2) on the.
Jan 08, 2016 | Bachmann Ho Bachmann Thomas and Friends...
Only runs in reverse, why?
Polar Express only runs in reverse ' O Gauge Railroading ...
ogrforum.ogaugerr.com/topic/polar-express-only-runs-in-reverse
Dec 7, 2011 - Polar Express only runs in reverse ... At this time of the year all Polar Express trains are programmed to run North only. ... This would not be so bad on the Strasburg set because half the time, the prototype runs in reverse.
both trains only go backward - Classic Toy Trains Magazine
cs.trains.com > ... > Forums > Toy train operating and collecting
... trains that i set up around Christmas. The first train, according to the box, is a k-line 0/027 gauge dual motor mp-15. For a long time it has only run backwards.
no forward only reverse - Model Train Forum - the complete model ...
www.modeltrainforum.com > Scale Specific Model Train Forum > O Scale
Oct 18, 2009 - 10 posts - ‎3 authors
There are two switches under the cab; they have no effect on forward motion. This setis 2 or 3 years old and has been run maybe 1 hour total. New Athearn HO Locomotive won't go in reverse ...
Mar 5, 2015
Lionel Rio Grande 8213 only runs in reverse - Model ...
Nov 18, 2013
More results from www.modeltrainforum.com
Jan 01, 2016 | Crafts & Hobbies
Driver Wheels are not aligned properly. Will not run in reverse without de-railing.
Best best is to send it back to the parts & service department, they will either repair it or replace it. It should have a lifetime warrantyif you are the original owne If not under warranty, I believe the charge is $35.00 for repair/replacement.But check with parts & service.
http://www.bachmanntrains.com/home-usa/prod_serv.php
link is to Bachmann Parts & Service.
Apr 10, 2012 | Bachmann HO Scale Classic Collector Series...
Tyco trains are set up have power but trains will not move
Check the engine and transformer by taking the two wires from the transformer and, while holding the engine upside down put on wire against one side wheels and the other wire on the other sides wheels...that will tell you if the engine is at fault.
Jan 28, 2010 | Tyco Ho Vintage Wm Flat Car W/ Tractors...
Sounds like the wheels may be dirty on the one . Have you tried cleaning them? The noisey one may need a little grease on the gears. The one that does not move but lights up, not sure. Have you tried to take the body off and see if a wire is disconnected?
Try going on line and look for a group on Yahoo Groups for N-scale. They will probably be more helpful and you will get more information about N scale trains. Good luck!
Bob D.
Dec 12, 2008 | Seth Thomas Bachman Thomas Annie Clarabel...
Bachmann James The Red Engine Train Set Logo
363 people viewed this question
Top Bachmann Crafts & Hobbies Experts
freddyfox
J.D. Browning
J.D. Browning
Steve
Steve
Are you a Bachmann Craft and Hobby Expert? Answer questions, earn points and help others
