Question about Car Audio & Video
LCD DISPLAY IS BROKEN, I NEED JUST TO REPLACE THE LCD NOT THE WHOLE UNIT, CAN YOU HELP ME - IT IS FOR HONDA 7BK1 6CD CODE 11111-66666 39175-SDA-L110-M2 CQ-EH1360A by MATSUSHITA
SOURCE: missing code honda accord 2002
You lucky lucky person! I am an automotive diagnostic tech,and have delt with this problem literally hundreds of times.you need to remove the head unit and changer from the vehicle this is easier said than done. the front of the dash has to also be removed and those attention-paying-down-to-the-last-detail engeneers and designers were thing job security on this one look in and remove the vent grills for most of the retaining screws holding the front together after its apart and the units are out look on the bottoms and call your local honda dealers sefvice. tell them the number then they will tell you your codes.enjoy you will hate your car after this, caution, your dash will squeek like theres no tomorrow if ALL of the screws are not reinstalled.
Posted on Oct 03, 2008
  • 218 Answers
SOURCE: i have this serial nombre 12232757 and this ref no
U NEED TO CALL YOUR LOCAL HONDA DEALER.THEY ARE THE ONLY ONES WHO CAN GIVE U THE CODE
Posted on May 05, 2009
  • 4889 Answers
SOURCE: I don't know my matsushita radio code;
If this is the Matsushita fitted into a Honda, then try here
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} HONDA codes may be available here
https://radio-navicode.honda.com
You will require the car VIN number and Radio serial Number
If they cannot provide your code then you will have to try your HONDA Main Dealer .....or a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM)
Posted on May 18, 2010
SOURCE: wireing diagram for a matsushita
97 Honda Accord EX leather: I am trying to find some audio parameters on my 6X9 rear speakers. I only find 4Ohm, 16W, USA EASA23DO1B1 on the speaker. I am looking for freq response, power handling, magnet type & wt.
Posted on Jul 19, 2011
abjr301
  • 42 Answers
Your code is 25131
Posted on Aug 19, 2012
LCD display shows broken numbers, why??
You have damaged it by dropping it displays of this type are sensitive to being dropped
repair or replace whole unit
Jan 20, 2017 | Health & Beauty
Korg ax3000 g display not working
It is likely something internal. The LCD is backlit so there is a chance it may be something on the order of a bad connection at the power supply input. Possibly a broken wire- as long as unit was not dropped, using a multi meter to check power is a pretty straight forward way to proceed.
If it got wet, there is possibly a burned out pico fuse, or corrosion on a connector or contact area for the rubber conductors for the display.
If unit was dropped- You may want to contact Korg to see if the display board is available. It likely is not. Which means it is a time and or money investment.
Feb 12, 2012 | Korg Music
Can i repair a broken screen on a lcd tv?
LCD stands for Liquid Crystal Display. It is all one unit and when broken can not be repaired. The only way to fix it would be to purchase a replacement screen but that would probably cost more than replacing the whole TV. You might look for a used TV of the same model with a good screen and a bad circuit board and exchange parts but it is far easier to replace circuit boards than LCD screens so if you find a similiar model with a bad circuit board take the good board from your set to make the one with the good screen work again.
Sep 08, 2010 | Samsung LN-S4095D 40 in. LCD HDTV
SEAT BELT RETRACTOR NO WORK DRIVER SIDE HONDA ACORD 91
Then rewind spring is broken. Just have to replace the whole unit. Try the junkyard.
Jan 31, 2010 | 1997 Honda Accord
Display scrambled on my model # LMVM2055ST
HI. this LCD is attached to the PWB assembly board. Unfortunately, this lcd is not sold separately and, you will need to replace the whole PWB assembly in order to fix this issue.This is actually a pwb(pcb) assembly failure.
CLICK HERE TO ORDER YOUR NEW PWB ASSEMBLY(LCD)
Jun 04, 2009 | LG Microwave Ovens
Replacing indicator light 96 honda accord
It is a sealed unit. Either it will unplug from the back and you will maybe have to twist it a little..gently. Or you will have to replace the whole unit..go to your local auto parts store and go to the parts counter and ask that good looking guy or girl behind there for assistance..Peace
Mar 20, 2009 | 1996 Honda Accord
AC display panel lights
You will need to replace the whole in-dash A/C control unit. Changing the small bulb won't rectify your problem, as the display is LCD.
Mar 12, 2009 | 2001 Chrysler 300M
Nokia display become white
the crystal diode behind the lcd screen has been damaged causing this "white screen".
best chances are to replace the whole lcd screen to get the display in working order again.
cheers.
Jan 23, 2009 | Nokia 3250 Cellular Phone
BROKEN (front) LCD Display for LG Chocolate 3
Search for "chocolate 3 lcd" on Ebay. For ~$26 and a little technical work you can replace the outside & inside LCD module.
Dec 06, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Car Audio & Video Logo
57 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
