Question about Whistler PI-1200W 1200-Watt Power Inverter Car Audio Amplifier
The fan on my 1200 watt inverter does not start when turned on.
Is the fan on the 1200 watt inverter supposded to come on as soon as you turn on the inverter. If it does not is the inverter defective?
  • 328 Answers
No. the fan is to remove heat(obviously) If there is a small or no load on the inverter the fan wont come on(no heat to get rid of)..........this is so a lightly loaded inverter wont kill your batteries as fast.If you load it up(power something big or power several things at once) the fan should start after a few minutes
hope this helps.Good Luck!
Posted on Dec 15, 2008
Why isthe fan on my new panasonic Genius over the range microwave is noisy NN-SD277
Check to see if the vent is not jamming the motor. It could be something fell into the fan blabes. It could be a noiy motor and this would be a warranty issue.
Oct 11, 2014 | Panasonic "NN-SD277BR 2.0cuft, 1200 Watt...
Microwaves fan and light on permanently
One of the relays is stuck. Hit it firmly and see if the fan turns off
Nov 28, 2013 | Sharp 2.0 cu.ft. 1200 Watt Microwave -...
Xantrex inverter/ charger smells like burning electrical
I would call or e-mail the manufacturer of the inverter. The dealer or dealers may know the issue but likely the manufacturer will be more help.
Some devices like an inverter will have a smell in the beginning, power supplies are like that. You said that the inverter didn't get hot but smell indicates something is hot.
Apr 13, 2017 | Xantrex Electronics - Others
Manual for black and decker 1200 watt invertor
some idea for inverter, collect inverter circuit Books from market.
May 28, 2012 | Black & Decker Vector Cable Kit for 1200...
Bought a new vector maxxsst 1200 watt inverter
Inverter run on batteries sir, and if these batteries are not charged, the run time {the number of hours it will work} reduces.
S0, you will need to connect the inverter to a power source.Theses will allow your batteries to be charged and enable it to run for a long period of time.
Make sure your batteries are still OK.i.e working properly
May 03, 2010 | Vector ® Maxx SST 1200 - watt Power...
Can I connect vacum cleaner big one with Black & Decker 100 Watt power inveter
No,
You will need a much larger power inverter than that to run that vac...
heatman101
Apr 22, 2010 | Black & Decker 100 Watt Plug-In Power To...
Whister 1200 Inverter
if the inverter is wired to a lighter socket then you do not have enough power as lighter sockets are generally limited to 100-150 watts. If you are using the supplied battery clamps, then is the vehicle running to supply enough power to run your TV?
Sep 25, 2009 | Whistler PI-1200W 1200-Watt Power Inverter...
Fan does not work.
Two things...one the fan only workk when the unit get hot or you created short the inversters are very sinsative and if you make mistake you are dead...see try it for ferw min and see...but first try to reset the unit and that by disconnecting the negative and positive from the back and turn the unit on to get all charges in the unit out then reconnect the cables do not forget to ground the unit to avoid sparks.
Sep 09, 2009 | Vector VEC053D 1200-Watt Power Inverter
Power drop
Hey, Question: Is the 2400 watt the peak rating or the continuous rating of the unit, and what is your power source for the inverter. If 2400 is the peak, the 1200 is probably the continuous. Your 75 watt fridge will draw probably 150-170 watts to start up, which will load the inverter to draw 15-17 amps of load on your 12 volt power source. If the battery supply is weak, the current draw at startup will cause the voltage to drop and set off the alarm. Getting the start up out of order may work for a while, but will eventually blow the internal fuses on the inverter, or possibly blow out the capacitors. Check the condition of the battery supply, and make sure the bar fridge is in good working order to resolve this problem.
Jul 18, 2009 | RoadPro RPPI-2500W Inverter
Low voltage output from inverter
I am thinking this a high impediance device problem and this is normal operation - the user manual of my inverter warns about use with high impediance devices - if not I am interested also...
Jan 23, 2009 | Electronics - Others
Whistler PI-1200W 1200-Watt Power Inverter Car Audio Amplifier Logo
181 people viewed this question
Top Whistler Car Audio & Video Experts
xxxxxx xxx
Are you a Whistler Car Audio and Video Expert? Answer questions, earn points and help others
