Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag tub locked up
Maytag washer will not spin or agitate,tub cannot be turn manually
  • Anonymous Dec 15, 2008
    washer will fill, but then goes silent and cycle does not start :(
  • Roscoe007 May 11, 2010
    Does it still sound like its working fine?
  • 163 Answers
SOURCE: washer won't spin or agitate
jesus crist remember all the work that machine did for your family and forbiden it, it sound to me to be the transmision, but wait for catriver, gona tell you somes tips, put your hammer in the closset by now..good luck
Posted on Aug 06, 2006
  • 878 Answers
On this model the motor turns one way for spin and the other for agitation. This action is controlled by a thrust bearing located just undernieth the plastic cap on the center pully. Many people are thrown off thinking a transmission problem when it's actually this thrust bearing kit. However, it could be the trans. If so you have a 5 year warranty on it, part only. There is also a number of service flashes on this model including: snubber kit, flash number 26-756, which has to do with vibration during spin. Things you want to make sure of is that the pump is not seized up, leakage from the center tub on to the bearing and brake. You may want to call Maytag and inquire about the service flashes on this model, you could be covered. Other than that my guess without seeing it would be the thrust bearing kit, part number 12500036. Not a bad job, the kit comes with instructions. The hardest part is getting that last washer on. Catriver...Post back.
  • 159 Answers
SOURCE: Maytag stacked washer/dryer Model LS7804
OK it may be one of 2 things. I would check the lid switch first. On some maytags the have a lid switch that if it is not working properly it will not let the washer fill. If it will not fill the washer will not wash because the pressure switch did not activate the timer to wash. If the switch checks good you might have a bad timer. If you open the control panel you will find a tech sheet with the wiring diagram. I would follow the fill cycle and check the components. You might also check the water valve to make sure its ok too. But its very rear that both the hot and cold would go at the same time. Good luck!
Posted on Jul 12, 2007
the dr
  • 447 Answers
SOURCE: Maytag top loader washer
The brakes are probably stuck or the cam that releases them is damaged
Posted on Sep 27, 2007
SOURCE: Washer wont spin. BUT, DOOR IS LOCKED. MAH 4000
Solution is right ...its your MCU Easy repair.
Posted on Nov 24, 2007
My washer wont leave sensing mode maytag bravos x model # mvwx500xw1
Shift mode sensor Orange thing at bottom of washer stuck on spin not shifting for agitation common in Whirlpool & Maytag and few others
Jul 04, 2016 | Maytag Washing Machines
What would cause my maytag front load washer not to spin? It is a Maytag front load washer and it will not spin. The water drains out no problem just doesn't spin. Also the drum looks lower than it no
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Jan 06, 2015 | Maytag Washing Machines
Maytag washer tub will not spin.
There is a clutch assembly under the tub that controls the tub and the agitator. It sounds like the problem is with that.
Jan 19, 2014 | Maytag Washing Machines
Maytag neptunefront load won,t spin mod mle2000ayw
Hi Vinod, the lock light is not on. The motor and belt seem okay; it agitates. I think lock light is supposed to come on only when tub is full. Again my manual says nothing on this!!
Sep 28, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Will not spin on spin cycle
That is a single belt driven washer built by maytag. Check the lid switch for propah operation. If it is fine tip the washer back do an inspection of the beltthemobilian_2528.jpg
Check the pump for tightness sometimes they lock up or get something in em. If that is fine turn the main drive pulley and see if it releases the brake and lets the drum turn easily. One direction it locks the tub and agitates and the other direction is pumps out the water and spins.
Manual and more HERE
Jul 01, 2011 | Magic Chef CAV2000 Top Load Washer
Maytag Performa washer drum turns with agitator. Also the brake doesn't stop the drum at end of cycle or when cover lifted.
The first thing to check is the clutch. It's supposed to lock the inner tub and drive the transmission (agitator) when the motor turns in one direction, and spin the tub when the motor turns in the other direction. It's also possible the agitator drive shaft coming out of the transmission and the concentric tub drive shaft are frozen together (worst case) - this is usually caused by a bad bearing seal allowing water to leak into the shaft.
Lifting the lid during the spin cycle should disconnect power to the motor - maybe what you see is the tub continuing to spin because the transmission is acting as a flywheel. Either that, or the lid switch actuator is not working properly.
Nov 27, 2010 | Washing Machines
My washer doesn't wring the clothes out, they are sopping wet.
You are going to need this kit 12002213
Your washer features a main drive pulley with a cam riser the releases the brake and allows the tub to spin.
When the motor turns in one direction the tub is locked and the agitator moves back and forth. When the motor turns in the opposite direction the main drive pulley releases the brake and as the water gets propelled out the tub begins to spin. So what can go wrong? When the cam riser gets wear it won't release the brake. The tub won't move and the clothes will be soggy. Here is a great pictorial of what is involved in replacing the thrust kit. along with some manuals and other stuff. My Maytag notes
Apr 16, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag se1000 washer
sounds like the brake is not engaging properly(locks the tub for agitiation) wouldn't say transmission just yet, don't know the age but probably a few hundred dollar repair, i would recommend a maytag guy to do the repair, requires special brake tools and such,
Mar 06, 2008 | Washing Machines
Maytag top load washer leak
underneath the agitator is a graphite seal ring and nut that seals the inner tub and the outer tub. a suitable spanner wrench or a 6 inch channel lock plier will remove this locknut. replace the seal.
Sep 02, 2007 | Washing Machines
Maytag Atlantis MAV6000 Top Load Washer Logo
41 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
