Question about Nintendo Wii Console
My wii screen is too small
My screen got smaller than normal one day and i tried going to setting i kept on alternating stuff and it was still the same thing...and it just makes me mad when i see the screen so small i cant play with such a small screen on such a huge wide screen personally)
4 Suggested Answers
SOURCE: CANT MOVE ONTO THE NEXT SCREEN FOR SETTING UP
your sensor bar might be unplugged or you have a low battery
Posted on Jan 25, 2008
SOURCE: A second WII remote device will not function
put on bateries
Posted on Jan 12, 2009
SOURCE: I hooked my wii up
try checking the router firewall settings, and lowering/disabling them
Posted on Jan 25, 2011
The screen on Firefox is huge and I can't find a way to reduce it back to normal size.
If you click on view- you will able to set your zoom back to normal size.
Mar 29, 2013 | Toshiba Computers & Internet
Phillips Magnavox 9p6034c 60 in. rear projection t.v.
are you sure!? or maybe you set at the pip viewer! go to settings!
Oct 01, 2007 | Philips Magnavox 9P6034C 60" Rear...
Zoom on desktop
Try Right Clicking on a empty space on the desktop and select Properties. Click the Settings Tab and go change the screen resolution. The higher the resolution, the smaller the icons. Normal resolution is about 1024x768, but you can make the icons even smaller by increasing the resolution.
If you can't get into the screen resolution that way, turn off the computer and boot up into safe mode.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal.
When the computer boots up click Start/Control Panel or Start/Settings Control Panel and look for Desktop or Appearance and Personalization.
Look for Screen Resolution or open the desktop and click the Settings tab. Make the resolution higher to make the icons smaller. Normal is 1024x768 but you can make it higher.
In Windows 7 just click Start and in the search box type: Screen Resolution. Look up at the top for the returned search results and click on Screen Resolution. Go in and set the resolution higher.
After you change the resolution reboot and let windows go into it's normal boot up mode.
May 23, 2012 | HP Compaq 6710b Notebook
The normal screen is divided in two smaller screen,which are showing the same channel.I want to return the screen to its normal screen size of single screen channel
The smaller picture is PNP called picture and picture.It can be set in to the menu setting.Go to menu setting and search the PNP code.Try to off or diable the PNP menu setting to back the normal single picture.
Jul 09, 2011 | LG 42PC3D 42 in. Plasma Television
Text size on home page, yahoo mail and print is so small i can't read how do i enlarge. I have gone to veiw ,text size selected largest with no result
Hello nancyedawley,
The text size can be enlarged by holding down the [Ctrl] key and pressing the [+] key. The text can be made smaller by pressing the [Ctrl] and [-] key combination.
If this solution is helpful please click a thumbs-up rating.
Have a great day,
martyshaw152
Apr 26, 2011 | Computers & Internet
Trying to connect wii wireless through my westell 7500 modem from verizon. error code 52230 keeps coming up. on phone with nintendo for an hour. they tried all kinds of stuff that did not work. told me...
It appears that the wii wants to work with wap security not wep. Need to go into the router with the 192.168.200.1 gateway. Next o to the security tab. Set up wap2 security password. On the drop down menu choose tkip and aes (both) setting. On the wii I would clear out the wireless settings and then set up a new wireless connection. Search for said and choose your router. Hit connect and enter your password. Save settings and have the wii connect, should get a connection successful message. Grab some popcorn and enjoy Netflix.
Jan 12, 2011 | Nintendo Wii Console
I'm trying to go through the setup to WII fit. My child did the body test with no problems a couple of days ago. I keep getting an error (fidgeting) when I try to take the body test. Tried to do fit test...
If your Wii Fit Balance Board is on carpet, be sure to use the extra foot pads that came with your board. If your carpet is really thick, you may need to use a flat woodend board to set the balance board on.
Finally, make sure that you are NOT using your child's Miii to do your own balance test. Each user of Wii Fit must use their own Mii character.
If you don't like my suggestion, please don't rate this suggestion a '1'. If my suggestion doesn't help, the problem may exceed the scope of what can be answered here. You will need to contact Nintendo directly through their website and open a problem ticket.
Good Luck!
Jan 17, 2009 | Nintendo Wii Fit for Wii
This sucks...
If the Wii is set to 60hz make sure your tv supports it. For the curser problem, try replacing the sensor bar or changing the sensitivity
Mar 30, 2008 | Nintendo Wii Console
Wii image gone
try connecting to a tv that supports 60hz. But you should read up on this stuff before you do anything like that again. Understand , understand? alright! but do not do anything like that again!
Dec 27, 2007 | Nintendo Wii Console
Wii black screen
The following fix should help users who do have problems with some virtual console games for the Nintendo Wii that display only a black screen after starting them while the sound remains normal. This does not work in all occasions but should work if you get the Wii menu when you press Home and works only for games that received an update for the interlaced mode.
Try out the following to see if this fixes the issue. Start the game normally until you see the black screen. Connect the Nunchuck to the Wiimote and press Home to see the menu options. Now press A + 2 + Z together which should result in a short “ping-like” sound.
This should have activated the interlaced mode. Leave the menu and you should see the normal game screen and not the black screen anymore. To change the mode again press A + 1 + Z using the same method as above
Nov 20, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
173 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
