Question about Kingston Technologies 512MB DataTraveler I (DTI512KR) Hard Drive
My card has an extra file
I use my card in an mp3 player...it was always working but now when i have like 70 files it tells me i have 71..so i took off everything on the card and on my computer it reads the card COMPLTELY EMPTY but on my mp3 it says there is 1 file and even if i try to play it..it says " 04 Err" pls help!!!!!!!!! :/
    Problem Solver:
  • 12 Answers
If you just want to wipe everything off the card, you can always just format it. Go into "My Computer," right-click on the drive in question, and choose "Format." Click the "Start" button at the bottom and wait for your computer to completely wipe and reformat your card.
Then just put your old music files back on the card and try it in your MP3 player again.
Keep in mind that some files are "hidden" when you look at them on your computer (unless you've chosen to "Show hidden files and folders"). These files are typically system-generated files used by your software to store temporary settings.
Posted on Jul 21, 2009
I just got a VL-547 MP3 Player from my dad he has NO CLUE how to do anything on it because he took to his iPod Touch, how can I get music onto it?
Putting Files on Your Player
  1. Plug in your official Visual Land mp3 player to your PC with the included USB cable.
  2. Locate your player on the PC by opening 'My Computer', it should show up as an extra drive. Open the player drive.
  3. Locate the directory where the files you want on the player are located on your PC, and open that folder.
  4. Click and hold on the desired file to transfer, and then "Drag" it over to the player's external drive folder, and unclick to 'drop' the file onto the player.
  5. Your Visual Land Player may support synching with Windows Media Player, but it is not guaranteed. Your Visual Land Player however will NOT support other synching software such as iTunes, MusicMatch, or any other programs. Simply use the process above to put files on your
Jan 21, 2011 | Visual Land VL-547 MP3 Player
Unable to Play Music & microSDHC Card
Unfortunately, you can't use a microSDHC card in the TH1101. The TH1101 was designed to work with microSD cards. The microSDHC is a newer standard; while those cards will fit into the slot, they will not function properly in microSD devices. You'll have to limit yourself to microSD cards 2GB and smaller.
Jul 07, 2010 | RCA TH1101 MP3 Player
Ipod
The only way to get extra space for more songs when your 8gb Nano is full is to eliminate some of the songs/pictures/files,etc that is on the player. There is no expansion SD card slot on the Nano. You can eliminate some of the songs/pictures,etc. by the following method: Hook up your mp3 player to your computer Go to your desktop and double left click on "My Computer" When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there. Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible. Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete" Now you mp3 player should be clear of the files/songs you do not want. Be careful and do not delete files needed to operate your MP3 player. Good Luck, I hope this helps Please rate me, Thank You
Dec 26, 2009 | Apple iPod nano
I have nokia 3110c my music player is not open and play the songs . can please tell me how to rectify the problem and pls tell me how to format my phone
Hi...
This issue occurs if the Files were in Read Only mode.
Please connect the Memory card to computer through data cabled or Memory Card Reader.
Select Music Files Folder Right click on it and Uncheck Hidden and Read Only then select Archive. Click on Apply and OK.
Now insert Memory Card then try to play if your issue should resolve.
Please answer below if this issue still persists.
Music file type either MP3 or any and its size.
Best Regards,
Suraj.
Feb 18, 2009 | Nokia 3110 Cellular Phone
Wont play all songs i have downloaded
some songs need to go trough the software because they dont work with that format file on the mp3 double check to see if your computer accidently double the songs
Jul 10, 2008 | Creative Labs Zen Touch MP3 Player
Getting 4GB Micro SD to work
The card will not add to the MP3's memory, it shows up as a removable disk on Windows Media Player version 11.
Otherwise, you can manually drag & drop files thru My Computer>Removable Disk (*).
FYI, the memory card will only support un-protected MP3 files, not Rhapsody or other subscription content. Also, you will need to free up some space on the player to allow some free space for the database to accommodate for the additional music.
Best of Luck.
Please RATE my solution BELOW.
Nov 20, 2007 | SanDisk Sansa e250 MP3 Player
HA90 MP3/WMA player
When I was looking at this product, I contacted the manufacturer and they made it clear the unit worked best with a 512 mb or smaller card. The problem is not with Sandisk or the SD manufacturer, it is with the HA90.
Mar 02, 2007 | Harley Davidson Road Tech HA90 MP3 Player
Video files not detected !
I always heard that if you stored videos or pictures into cards they wouldn't work. The cards are only for music.
Nov 20, 2006 | SanDisk Sansa e250 MP3 Player
AAC Files Transfer
Yes look in the net to get a mp3 converter toacc then just drag those files you converted to your SD card it will work. search google mp3 to acc.
Jul 19, 2006 | Panasonic E-Wear SD SV-SW20 (128 MB) MP3...
Computers & Internet Logo
53 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
