Question about Sony Handycam DCR-TRV50 Mini DV Digital Camcorder
The tape will not eject, battery is charged, help! Thank you!
Touch screen is blinking with the letter "C" showing and it's making a repeating chime sound, it has done this before and has stopped after I replace the tape but this time the auto tape eject is not working and the tape is stuck. Thank you for your assistance.
Paul
  • 10,594 Answers
Unplug battery and reattach it again, then try to eject the tape.
If problem still exist and camera shows error code "C:..:.." and beeps then it is problem of tape mechanism.
Posted on Dec 13, 2008
I have an AXM17U camcorder that is showing EO3 and wants battery reattached. I have ussed two different batteries @ full charge with the same result..EO3. What's next?
E03 Take-up error
Most common in the Mini-DV models. This problem can be defective reel tables, or it can also be a defective rotary encoder. You can expect to pay intermediate to major labor for this type of repair. Parts are nominal.
The indication E-03 or E-04 is an Emergency Error Code. In the event of a malfunction the unit will shut down and display a code. This is to inform an independent JVC authorized service center which area of the camcorder to examine in order to ascertain the nature of the problem.
The E-03 or E-04 code relates to one of the tape spindles not turning. This could be the result of too much slack on the video tape. If E-03 or E-04 is displayed it may be possible to correct the problem by removing the tape slack. In order to do this follow these steps:
1) Remove power source for 1 minute.
2) Reattach power source.
3) Press "EJECT" (DO NOT PRESS POWER)
4) Repeat above steps until tape ejects.
5) Tighten and insert a new tape."
Keep us updated.
Apr 07, 2011 | JVC Video Cameras
I went to the general settings icon and erased the entire ipod not knowing the damage it would cause, its definitely frozen and wont connect to itunes; itunes does not register my ipod it only shows the...
1: Plug your iPod into your computer.
2: Hold the power button and the menu button (underneath screen) down simultaneously until the screen goes black, then shows the Apple logo again. Then release the buttons.
3: Wait for five to fifteen minutes until your computer plays a "chime" sound. The iPod should then show the "locked" screen with the battery logo, and you should be good to go. You will probably want to resync your media to your iPod at this point, and make sure it's charged.
Feb 27, 2010 | Apple iPod touch
Cann't eject cassette from Canon ZR60
I had a similar problem last few days with my ZR60.
The problem I had was that the tape won't eject and on repeated attempts to eject it would eject as if it had a mind of its own.
I was messing with it a little bit and realized that the door was not opening fully. Being a delicate item I didn't realize that I was not fully opening the door may be because there was a little friction in the pivot pins or what ever.
Try to gently swing the door open fully and see if it helps.
Since I discovered this problem I tried 10-12 times, and every time it would eject the tape and load it.
I was almost going to give up this camcorder last night thank GOD, I am able to use it.
Good Luck to you.
Dec 27, 2008 | Canon ZR60 Mini DV Digital Camcorder
Tape will not eject / Battery full
while the eject process is trying to happen remove the battery and replace it. keep initiating the eject process and removing the battery and it should finally eject. If you attempt to use the camera again put in a new tape so you don't lose a tape that contains footage you may want to save.
Dec 07, 2008 | Canon ZR100 Mini DV Digital Camcorder
Sony Handycam DCR-HC32 Not Working, Not Ejecting Tape, LCD Flicker
DCR-HC32 need new tape mechanism as shown in below exploded view.
Its part number is as follows..
A-1082-424-A MD (Z210) SUB ASSY
Nov 06, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
Canon mv940 camrecorder won't power up even with charged battery
My friend went back to England and got it sorted there
Thanks
a
Sep 06, 2008 | Canon Video Cameras
Tape ejects immdediately when I load tape.
I own a Sharp VL-Z1 DV video camera. I had this same problem and thought it was from using the ME Maxell tapes. I took the battery out of the unit and let it reset. Worked fine after that.
May 05, 2008 | Canon ZR85 Mini DV Digital Camcorder
Jvc digital video camera mini dv gr-d244u
I have had the same problem...usually had success by taking off the battery, putting it back on, turning the power off and on, etc.  It has always gone back in eventually.  I also tried re-charging the battery and replacing.  Could this be an old battery problem?  Mine is 4.5 years old.
Jan 06, 2008 | Panasonic Palmcorder PV-GS9 Mini DV...
Samsung Mini DV camcorder (Protection-Problem)
SOUNDS LIKE THE TAPE TRANSPORT IS BAD. IT WILL EAT YOUR TAPE SOON. YOU WILL NEED A NEW TRANSPORT OR A NEW CAMCORDER ...SORRY
Dec 14, 2007 | Samsung SC-D103 Mini DV Digital Camcorder
VCR Tape will not play, it keeps ejecting
I have a similar problem. It takes 3 or 4 times to get my Sony VCR to accept a tape. Once it does, everything is fine, until I turn it off. Next day, same trouble. I tried several tapes and brand new tapes. No difference. I have opened the cabinet and used alcohol to clean various stuff, no change.
Feb 02, 2007 | Quasar VV-2002 20 in. TV/VCR Combo
Sony Handycam DCR-TRV50 Mini DV Digital Camcorder Logo
210 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
