Question about Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WMA62 front door will not lock
The door does not click
  • Hotpoint Master
  • 3,463 Answers
If the door locked light is flashing then you probably have a control module problem.
You could try a new door lock but I don't think this will solve the problem..
Make sure the door is shut properly, and that the door catch is o/k.
Plz rate this solution.
Thanks.
Posted on Dec 14, 2008
Hotpoint WMA62 washing machine door won't release
If the machine didnt finish the cycle due to the pump being clogged the door will remained locked also if the lock mechanism went bad, the machine will stay locked. Remove the top of the machine by taking the screws from the top back out. Once removed look down the right hand side and you'll see the lock mechanism, usually with a plastic tab you pull to manually release the lock.
Apr 24, 2012 | Hotpoint WMA64 Front Load Washer
My waashing machine a WMA62 Hotpoint comes on, you
that sounds like your heating element is o/c .... get your heater tested ..01179512835
Dec 30, 2009 | Hotpoint Washing Machines
I have hotpoint wma62 and door lock light flashes, machine will not start as door will not lock any clues ???
Hiya,
yes, i can help..
Firstly, lets start simple. Have you noticed the door lever/handle has got "floppy"? or loose? or easy to squeeze?
This is the most common reason, what happens is there are 2 bits of spring steel behind the handle, these either break or become weak, to test this theory, close the door, put your finger between the handle and the door and push the handle towards the glass, if this works then you need a new spring/handle.
Please let me know,
Please rate my help.
Regards
Sussex engineer.
Oct 22, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WMA62 shaft removal
draw off the spider with a pulley extractor,
Sep 03, 2009 | Hotpoint WMA64 Front Load Washer
Hotpiont wma62 not washing
check the motor brushes and connections to the motor the fault is logged as motor action fault.
Jul 12, 2009 | Hotpoint WMA64 Front Load Washer
Hotpoint WMA62 door will not lock
Sounds like the door lock switch has failed,normally they go bang when fail,they start the machines cycle so are important,when door is shut it should click,this engages a timer which keeps door locked switch is live at mains potential,cant be tested have to be replaced about 12 pounds cost,best for a tech unless you feel competent
Dec 13, 2008 | Hotpoint WMA64 Front Load Washer
Drum on my wma62 won't turn
Hi.
The main drum bearigs have failed, you have to disconnect everything you can to enable you have to
remove the whole drum and container through the top of the m/c.
It is quite an involved repair, and could prove to be expensive. more so if the drum shaft is worn.
Good luck.
if you need any further info, let me know
Nov 20, 2008 | Hotpoint WMA64 Front Load Washer
Hotpoint washing m/c WMA62 - door won't open
sounds like you have a blocked pump or discharge pipe
Oct 12, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
299 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
