Question about Panasonic Diga DMR-EH75V DVD Recorder/VCR/HDD
While copying the unit got a U88 error and will not recover.
After formating the disk. While starting the copy process the DVD recorder chuncked three times and said it was recovering. I took the disk out and tryed other disks but nothing works. It won't even play a disk. When there is not a disk in it, it still thinks there is a disk in it and try to read it. I held the power for 10 seconds to try to reset it to no avail. I held the stop and the channel up and it is now stuck on please wait. Thanks for any help you can give me.
David
5 Suggested Answers
  • 4234 Answers
SOURCE: Panasonic DVD Recorder
We need to narrow down where the problem lies. Even without finalizing the disc, you should be able to play back the recording. Can you do this? If you can play back the recording, the problem exists in the finalization stage and we'll need to concentrate there. Pplease update this and we'll proceed to the next step.
Thanks,
Dan
Posted on Sep 08, 2008
pogiboi
  • 85 Answers
SOURCE: "NO READ" on Panasonic DMR-EZ27 DVD Recorder
good day 2 you,, ,, i have some little advice on you,,
just open the top cover of your player and check the RIBBON WIRE of the LENS/EYE part then clean theGOLD FINGER/LINES
and get some clean cotton buds and a lighter fluid 2 clean the lens,,,,,ok,,
PS. dont use cd cleaner fluids,,, that wont clean, , , , , ,just lighter fluid ok!!!
GODBLESS U
Posted on Sep 22, 2008
Palmbeach
  • 185 Answers
SOURCE: DVD recorder continually stuck on a loop trying to read disk.
Hi again
I am so pleased to hear that you have restored the DMR E55 and for taking the trouble to let me know. It's always satisfying to achieve something like that and I guess you'll get even more pleasure from using it now than you did before. They are good machines and well worth the effort to keep them going.
Thanks again and kind regards
Posted on Feb 01, 2009
SOURCE: panasonic dmr-es45v
The disc drive motor is burned out, its junk...if you didn't finalize the discs, they're junk too unless you buy another Panasonic DMR.
Posted on Feb 10, 2009
SOURCE: I have a Panasonic VHS-DVD player/recorder model
FOR AL THOSE WHO HAVE A PANASONIC DMR-ES35VS THERE ARE MAJOUR PROBLEMS WITH THE RAM DRIVE WHEN IT IS DEFECTIVE THE DVD PLAYER WILL MAKE A SOUND LIKE IF ITS TRYING TO READ OR YOU WILL HERE A SORT OF SCRATCHING SOUND THIS MEANE YOUR RAM DRIVE IS DEFECT IT WILL COST 200 DOLLARS FOR THE PART
Posted on Oct 27, 2010
My olympus vn-8100 flashed system error and stopped working
Ok, try this, works for me:
- Remove the batteries- Insert its again- Connect the recorder via usb to pc- Copy one by one each archive you need to recover, after copy delete them from the recorder- Copy SYSTEM, RECORDER AND MANUALS FOLDER to pc- Format from the pc the recorder (i use a mac - disk utility) yes it is, ERASE!- Copy again the folders: SYSTEM-RECORDER-MANUALS- Unplug the recorder, remove the batteries, insert again- Turn on the recorder, it will display a different error, format the recoder, it will restore and reset the systems files.- It works for me!-
Jan 10, 2012 | Olympus VN8100PC Voice Recorder
For some reason I can no longer copy from my VHS tape to my DVD disk in my Toshiba DVR620KU DVD Video Recorder. I have tried some of the same tapes which had copied just fine in the past. I am using the...
How old is Toshiba DVR620KU recorder and how long it started this problem?
Does it playback previously recorded discs correctly?
Did you tried lens cleaning disc in recorder to clean optical lens?
These info will help me to suggest a solution.
Thanks.
Jul 22, 2011 | toshibadirect.com
Panasonic DMR EH56 permanent U88 Error on DVD- and HDD-Drive
displays when ther was somthing unusal detected with the disc while recoding playback or copy this is diplayed when the unit is in the recovery process to return to normal operation the unit is not broken once the display clears you can use the unit again
Jul 14, 2009 | Panasonic DMR-E55 DVD Recorder
Error code E 4 54040990
jamesgranger - I think your DVD recorder is still having trouble reading the DVD+RW. It should not have a problem using a DVD+RW many times. Try taking the DVD+RW and put it in your computer. Find it in Explorer, right-click and choose "Erase". Then try to record to it using the DVD recorder again. If it works, you can use this to record, though it might be a pain.
The fact that your machine will record to the +R means that it works. Failing to work (record or erase) on the +RW means it's not reading it well. I would try running the lens cleaner again if it were mine. Also, I would make sure that the unit didn't have a lot of dust in it. If you can, power it off and use some spray-air to be sure there's no dust. You may have cleaned the lens, but if there's a lot of dust inside the unit, it will quickly find it's way back to the lens and you'll have the same problem. Michael
Jul 09, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Recorded DVD will not play in another player
try playing on computer. if ok copy on hard drive and burn it. if it wont work on your computer. there was an error in the making of the disk..
Apr 15, 2009 | Televison & Video
Screen says cant record copy protected movie
Is this a new problem or has it always been like this? The unit will throw that error message if there's a copy protection flag on the broadcast source.
To make matters worse, there are three flags a broadcaster can set. Copy Always, Copy Once, and Copy Never.
Copy Always and Copy Never are pretty self-explanatory but the Copy Once flag with this unit only works with certain media, namely DVD-RAM and DVD-RW in VR mode with CPRM (Content Protection for Recordable Media.
Copy Always flag should work with all media. I don't know of any easy way to figure out which broadcasts have which flag but try changing your media and recording mode first.
P.S. You may also want to reset to factory default settings by pressing FF and RW together on the player. Also make sure you're running the latest firmware.
Good Luck!
Feb 02, 2009 | Samsung DVD-VR357
Cyberhome DVR 1600 DVD
What format are you recording in?If the recorder is set for DVD +R, and your playback machine won't read the disc, you may need to record on a DVD-R, or a DVD +-R. Or vice-versa. Some DVDRW discs will record on one machine and won't play on another. The media are incompatible. Another problem - if you are copying a copy-protected disc, it might not play back either. Are you sure you are finalizing the disc? This process takes 4-5 minutes and requires two or three responses sometime.
Dec 03, 2008 | Cyberhome DVR 1600 DVD Recorder
DMR-ES15 Stops after 45 Min.
U88 means the unit has detected an error while recording or playing and has entered its recovery process to restore the unit to normal operation. You could try using a DVD-RAM disk or a different make of DVD-R but, as you say the unit is new, you should probably return it to the retailer for exchamge, repair or refund according to unit age and retailer's return policy.
Nov 03, 2008 | Panasonic DMR-ES10 DVD Recorder
After copying some home
best bet get video on hard drive computer 1st then use nero make your movie and then burn no faste rthen 8x
Mar 13, 2008 | Televison & Video
U88
the dvd disc you are using is copyright you cant copy the disc.. "the disc is encrypted'
Feb 07, 2008 | Panasonic DMRES15 DVD Recorder
Panasonic Diga DMR-EH75V DVD Recorder/VCR/HDD Logo
61 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
