Question about Bose link AL8 wireless home-wide audio link - No Color System
Bose Lifestyle 18 ser.ii
No color on TV when playing DVDs
  • 734 Answers
No there is no problem with the cable!!!!Set colors for DVD from TV menu>>AV color
There is a separate channel (AV) for the DVD players need to be configured by TV menu option.
Thanks
Posted on Dec 13, 2008
  • 10,594 Answers
Change color system in TV to Auto, if TV has multi-color system.
  • Bose Master
  • 19,396 Answers
Check the video cable at the back.
  • Ginko
    Ginko Dec 13, 2008
    Check the video cable at the back, when you get no color on a single device, it is often because of a bad video connection cable.
    Try moving the cables and see if you get color, test a replacement cable, or a different kind of connection. For example, if you connect through HDMI cable, try RCA A/V cables.
    If still no luck, test the DVD on a different TV, if picture is B&W, then DVD unit is defective.
Came over from uk 7 months ago and brought a bose 18 lifestyle and it wont play oz dvd's can I change the software in the system with a up grade disc
Yeah you are in a different region and there are regional codes on DVDs so it wont play the American disc probably. There may be a way in the menu to change your regional code
Mar 01, 2011 | Bose Lifestyle 18 System
Pink and green colours seem to be too vibrant when watching dvd's on lifestyle 48
I have a Lifestyle 48 which suddenly started producing a pink and green image when playing DVDs (regular TV was fine.) After speaking with Bose support, I did the following which resolved the problem:
1. Removed power from the video switcher. (or from the bose itself if you don't use the switcher.)
2. Reattach all the video cables on the back of the bose and ensure all connections to the TV and switcher (if applicable) are tight.
After performing these steps, my DVD image went back to normal. I suspect it was a loose cable in the end, but no harm in performing the power disconnect.
Apr 11, 2010 | Bose Lifestyle 35 System
The voices on DVDs are too low and are drowned out
The centre channel normally has the voices - sounds like it:
  • isn't connected,
  • isn't working or
  • is turned down too far
  • or the system could be faulty
Apr 03, 2010 | Bose Lifestyle 18 System
I have a Bose Lifestyle 35 Series II and want to know whether it's compatible with a DVD+RW. I'll burn it in a Toshiba recorder, finalize it and then play it on the Bose. Will it play?
Hi This what Bose say about formats
"The Lifestyle® 35 system plays DVD-video in interlaced format, as well as music on CD, CD-R (recordable) and CD-RW (re-writable). The system also plays MP3 files on CD and AM/FM radio. "
So by the sound of this i suspec that you may struggle with DVD/RW. but my best advice is try it.
Nov 10, 2009 | Bose Lifestyle 35 Series II System
Connect lifestyle 48 to plasma and dvr
You need to buy a Bose VS 2, video enhancer. Your cable/sattelite, vcr and aux connect to the VS 2 and the VS2 connects one HDMI cable to the TV. The VS2 then upconverts DVDs played on the lifestyle through the VS2/HDMI.
Sep 10, 2009 | Bose Lifestyle 48 System
Bose lifestyle 48 dvd black and white only
Go to the "Bose" menu screen viewing on your TV (make sure no dvd is in the player) Go to your Video controls and check your output, chances are, if your using the component output your player is set to "S-Video". Should fix the problem. Hope this helps. If it's still not viewing correctly, post a comment and I will help you some more
Jul 26, 2009 | Bose Lifestyle 48 System
Black and white picture for DVDs not tv
Make sure you don't have a componet plug in a A\V hole or the other way around.
Mar 15, 2009 | Bose Lifestyle 18 System
Cannot find a device code for ATT Uverse DVR cable box
SOrry for your plight, the Bose staff are correct, they do release occassional firmware updates via a DVD or a CD throught their costumers mailer. If you are not part of this mailer, you may go to any Bose service center and request the latest update disc for your Lifestyle 18-II system. Udpates should be able to help you sort out your problem.
Glad to be of service...
Jan 21, 2009 | Bose Lifestyle 18 System
No sound from my bose lifestyle 18 system
CHECK THE SOUND SYSTEM ARE YOU SELECTED FROM AUDIO SETUP CONFIGARATION.
CHECK THE MUTING STATUS.
BEST REGARDS NUWAN.
Dec 23, 2008 | Bose Lifestyle 18 System
Center speaker static noise
Sorry sp106s, you have to take that to bose service center.
Its a complicated problem. Something is wrong in the amplifier
section inside your sub box. Only authorize servicemen can
open it, not any tech'n can.
Good Luck
Dec 03, 2008 | Bose Lifestyle 18 System
Bose link AL8 wireless home-wide audio link - No Color System Logo
105 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
