Question about Kohler 12 kW Emergency Power System - 12RES-L
Kohler lp shuts down
The generator was starting then shutting down after 20 seconds. yesterday the repairman replaced the govenor. today it starts but revs up and down then shuts down after 20 seconds. will continue to run if i hold the throttle steady. if i let go it revs up the down then shuts down. thoughts... will i damage it if i hold the throttle steady to keep it running,
ty
paul
  • 1 more comment
  • wchorne Jan 17, 2009
    I may have a similar problem. See my post.
    Bill in Salisbury
  • Dan408 Jan 27, 2009
    I have a 11rmy LP, it will start and run from 5 seconds up to 1 minute. I changed the regulator, electronic governor, diodes, filters and plugs. This unit is 9 years with only 150 hrs.
  • Carl Gehrke
    Carl Gehrke May 11, 2010
    No matter what you shouldn't hold the governor arm or the throttle to prevent the governor from working, you could do serious damage to the engine in a very short time. I'm not as familiar with your generator as I am others, can you tell me if you have and electronic governor or a mechanical one? Also am I correct in thinking that this is an LP fueled generator? If you've got LP fuel you could very easily be having issues related to fuel pressure and/or delivery volume - this is especially true in cold places :-)
    Hope this helps,
    Carl
What you need to know is there enough fuel going to the regulator. It should be 7 to 11 inches Water Column. If not your problem may be not enough fuel. That includes when the heater in your house kicks on and what ever gas appliance you may have. Once you verify that you need to figure out if you have the proper pressure coming out of the regular on the inside of the generator. Next I would look at compression of the cylinders. It may need new piston rings.
Posted on Oct 09, 2009
Why does my Kohler 7.3 generator start and runs great for about 5 min. then shuts downRestarts fine but shuts down seconds later. Upon removing rad cap, fluid is seen moving upon warm up. How do I...
change the oil to the correct specification first. As the engine runs the heat changes the viscosity and overheats or trips the oil alert switch. If its over 10 years old change the oil alet magnetic switch
Jun 12, 2014 | Kohler Electrical Supplies
Kohler Generator won't start
If you have a drip leg near generator open that up for a sec and then try it again.
Nov 16, 2012 | Kohler Electrical Supplies
Kholer power systems generators 18RESL auto shut down code UU
UU is generator under voltage. Check to see if it does it without laod also. if it does you will need a pro to check and ohm the rotor and stator for shorts
Jul 11, 2012 | Kohler Electrical Supplies
The monitoring system of our Kohler propane generator has sent a "UU" message. What does this mean as it causes the generator to shut down 10 seconds after starting? Also how can this be...
The monitoring system of our Kohler propane generator has sent a "UU" message. What does this mean as it causes the generator to shut down 10 seconds after starting? Also how can this be corrected?
May 28, 2011 | Kohler 12 kW Emergency Power System -...
Kohler Model 12RES LP gas generator starts normally but immediately shuts down with over-voltage alarm. Control panel replaced.
Sounds like a short in one of the windings to me. Can you verify that the engine rpm is not exceeding specs? If you can modify the engine speed Id say slow it down and see what the voltage read is.
Jul 22, 2010 | Kohler 12 kW Emergency Power System -...
Kohler confidant 4 generator will not run.
i got the same gen and with the same problem
mike
Sep 24, 2009 | Kohler Electrical Supplies
My Kohler 17RES has stopped doing it's scheduled weekly exercise. How can I get it exercising again?
On your Automatic Transfer Switch ( the little gray box you see on the right in the picture above) you have two blue buttons. One is a Manual test switch. The other has a clock on it and this is your exercise set button. Hold it down for a FULL 3 seconds if you want it to excercise without a load (not powering your home) Hold it down for a FULL 6 seconds if you want it to exercise with a load every week. Your generator will start and run for 20 minutes, and then shut down. Now every week your generator will exercise at the time and day that you pushed the set button.
Aug 08, 2009 | Kohler 12 kW Emergency Power System -...
Kohler 12 kW Emergency Power System - 12RES-L Logo
653 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
Craig Butler
Craig Butler
John Trevino
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
