Question about KitchenAid KDRS807SSS Dual Fuel (Electric and Gas) Kitchen Range
I have a KITCHENAID FREESTAND RANGE model KGRS807SSS00. The problem start with the broil top oven burnen not working and now the panel is showing the message: "Enter Probe Temp or remove Probe", there is no Probe connected to the range. My question is: Is there a way to reset the electronic panel of the kitchen? I tried turning the power braker off for a while and nothing happend, I get the same message when turn it back on.
We've had this same problem - they've replaced the electronic panel twice. They say it's a poor design as anything on the stove that splatters gets behind the front seal and kills it.
Posted on May 09, 2010
I comes back to normal after been disconected from the power for about 30 minutes.
Thanks for the recomendations.
Osvaldo
Posted on Dec 15, 2008
Kitchenaid oven won't turn on
FOLLOW the OWNERS instructions to TROUBLE-SHOOT (EG remove the door, clean it & replace it properly, etc.). On my model... check the center top for a simple switch lever... than gets pushed straight in when the door is PROPERLY CLOSED...
(light should go OUT).
ELSE your door switch "thinks" your door is open =
BROKEN or DEFECTIVE DOOR SWITCH
ServiceBench
As much as I detest SEARS... KITCHENAID is close behind:
If you cannot find your door switch issue on a REPUTABLE PARTS SITE
SEARS does have some "COMPETENT EXPECTATIONS"
for their repair service... Act quickly... SEARs is deservedly going out of business.
But first look around... for GOOD VIDEOS
(NOT YOUTUBE)
appliancepartspros, ereplacemntparts, partsselect.com
My KGRS807SSS00 Model Overview from PartSelect com
Search Over 2 1 Million Appliance Parts
Jan 23, 2017 | KitchenAid Kitchen Ranges
Both Oven elements do never come on Together, Top Works When turn on Broil and Bottom when On Bake & Auto. Pls help.
that's normal. The top element is meant for broiling only while the bottom one is meant for baking.
Mar 11, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Frigidaire Gallery oven large element stopped working
Hello -
If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works, contact a professional to have the EOC (electronic oven control) diagnosed.
Sep 19, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I have a two ear old Kitchenaid gas range (KGRS807). It all at once stopped lighting the oven. The top burners still work fine. When you do anything in the oven (Bake , Broil, Convection) the electric...
You will need a new igniter module. The igniter module is told to spark by the control panel. There is also a flame detection for electronic start and that could be bad too.
Apr 16, 2010 | KitchenAid Architect Series KEMC308KSS...
Self cleaning gas range: Bake and broil will not light up.
the thermal fuse in back is out. sometimes they are resetable
Feb 09, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Oven wont turn on.
Ours did that and I installed a new igniter. Took the old one out and went to a store that sells them. Installed it myself.
Sep 29, 2017 | KitchenAid KGST307 Gas Kitchen Range
Broiler will work, but oven wont
Could be the bake igniter is bad and broil igniter is still good. may need to replace the bake igniter you will need a complete model number off range to determine the part number of the igniteryou may need.
Jan 07, 2009 | KitchenAid KGST307 Gas Kitchen Range
KITCHENAID KESS908SPW ELECTRIC RANGE
are you sure the oven doesnt need 2 voltage supplies?control voltage and load voltage.
Aug 12, 2007 | KitchenAid KESS908SPB / KESS908SPW...
KitchenAid KDRS807SSS Dual Fuel (Electric and Gas) Kitchen Range Logo
452 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
