Question about Sony XM-2002GTR Car Audio Amplifier
Protection mode override
My car has a dual box with two twelves a sony xplod 1200 watt ampand a pioneer radio in it which is 200 watts my speakers cannot take any kind of bass before it goes into protection mode why is that? i turned the filter gain and bass boost down all the way and it still shuts off.
  • 156 Answers
If you have your subs wired to the amp in a bridged configuration, try wiring one to each stereo channel instead. Also, make sure your ground wire is secure and connected to a clean, solid metal part of the vehicle body with the paint scraped off. If this doesn't work, disconnect both subs and try connecting only one at a time; one of the subs may have a problem that is shutting down the amplifier.
Posted on Mar 11, 2007
SOURCE:
Green light comes on for a sec the red light comes on,1200 watt sony xplod amp 10'' Orion sub,I think the subs right around 3000 watts. What's wrong?:(
Your Sony Xplod amplifier turns on briefly (green light) then possibly senses a mismatch between the nominal output impedance of the amplifier and impedance of your Orion sub and goes into protect mode (red light) to prevent internal damage.
Jul 19, 2014 | Car Audio & Video
How do i bridge a 1000 watt amp to two 1200 watt subs
a sony 1000 watt rating is an exagerration. you will blow your 1200 watt speakers far before reaching sonys claim of 1000 watts
Jul 10, 2014 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp going into protection
Is the amp bridged? If you only have one speaker connected to it, I sure hope so. How much power can that speaker safely handle and what is the impedance of the speaker? 2,4,8 ohm? A 1200 watt amp with only one speaker may be too much amp.
Jan 14, 2014 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Ive got an sony xplod 1200 watt amp thats bridgeable ive got two dual 4ohm subwoofers how do i wire this up to get the countinued bass with no cutting off
wire each sub in series inside the box, this makes them each 8 ohms, then run them parallel from the box to the amp bridged. this will give you 500 watts at 4 ohms
Apr 07, 2012 | Sony Car Audio & Video
How to install a power acoustik 30th anniversary version series 4 channel 1200 watt amplifier
Power to battery. Ground to something in trunk. Remote to blue lead on radio. Rca to line or sub out on radio.
Sep 14, 2017 | Power Acoustik Car Audio & Video
My stereo in 1997 chevy caviler is turning off and on when turned up to a high volume. I have a sony xplod 52 watt by 4 channel radio. With two 6x9 sony xplod 50 watt rms and 300 watt peak power in the...
Most likely cause is heat. The clearances behind the radio are often not sufficient to provde the proper air coolling that the higher power radios need. The heat sinks on the rear of the radio require a certain amount of air flow to dissipate the heat generated under high load conditions. If you add summer heat to the equation, you can have the radio going into thermal cutout to protect it circuity.
May 27, 2011 | 1997 Chevrolet Cavalier
I have two sony xplod 12" speakers wich can hold
You only gave us the model of the amp so I will make an assumption that your 12" subs are the Sony XS-GTX120LW. First, they cannot hold 1200 watts a piece. They are meant to be powered with 350 watts RMS. They will hold 1200 watts peak. That means that 1200 watts for a few seconds will be ok. Past that and kiss them goodbye!
Next you indicated that bridged the amp. Since the subs are both 4 ohm single voice coils did you wire them in series or parallel?
It sounds to me like you wired them in parallel resulting in the amp seeing a 2 ohm load. The amp you referenced is only stable when bridged at 4 ohms.
Has the amp begun working again once it cooled down? If not you could have fried the outputs by having the resistance too low.
Dec 21, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
Amplifier For Powering Sony Xplod xs-l121p5
Pump the brakes!
You need to know the RMS power rating of the sub you are powering.
Dont exceed the RMS power rating of the sub by more than 25%.
If you see a peak power rating on either the sub or the amp, ignor it, means nothing. Always compare RMS ratings.
Example: a Sony 12" Xplod sub, boasting 1200 watts, will only handle, 350 watts RMS, so the amp you choose to power the sub should be 350 watts RMS as well, and should not exceed more than 25% of the RMS power handling (487.5 watts).
Bottom line, know your RMS numbers, not Peak.
Byron
www.distinctbeat.com
Dec 06, 2009 | Sony Car Audio & Video
Can I run 8 speakers and 1 sub through 1 1200watt 2:1 Sony Xplod?
asuming the 8s are 4ohms each; wire two in series and that gives you 8ohms then two more in series then you put those together in parallel and it gives you a 4ohm load. repeat with other four for the other side. you should then be able to bridge the sub
series; posative of one speaker to negative of other speaker and that doubles your ohms
parallel; posative to posative negative to negative and that cuts the ohms in half
Apr 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
High distortion
The head unit may be rated at 200 watts but it cannot produce more than ~20 watts of real power per channel. There's no way that it can drive the high end speakers to a level that will be needed to compete with the subs on a 1000 watt amplifier.
Apr 18, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony XM-2002GTR Car Audio Amplifier Logo
360 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Mike Duncan
Mike Duncan
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
