Question about Boxlight -670k Multimedia Projector
Service mode how do i set convergence for multimedia projectors.
  • 2,237 Answers
There is no convergence. try resetting the settings to factory default through the menu. if you have a dlp, the colorwheel and dmd chip are set. if you have an lcd, the lcd panels are locked down. if they are off, you'll need to go inside and realign them physically. but that's chore, because you have to plug it in, turn it on, see which way you need to go, power down, unplug, remove the top cas, remove the main board, adjust, tighten, replace the board, replace the top, plug in, power up, check the image, and do this as manny times as necessary. leave it to the service centers.
Posted on Jan 28, 2010
  • 22 Answers
You dont it is only an Engineer who can do this as it is very dangerouse due to UV output from the unit when alignment is done.
Marc Engineer
Posted on Jun 17, 2009
    Champion:
  • 205 Answers
Its mechanical adjustment usally preformed in a clean room enviorment. Micron adjustments and glued into place. not a field repair. good luck
Posted on Jul 07, 2009
Seems the rgb is note centered getting 3 ghosts
This is a convergence problem that will require factory service. Convergence adjustments must be made with particular test images and tools to access the internal adjustments. This is not a DIY repair.
Dan
Feb 04, 2010 | Panasonic PTL500U Multimedia Projector
I have a problem with the colors not converging properly.
reset the settings to factory default. the resolution may be off. if the resolution matches and you still have trouble, the lcd panels need physical realignment. only a sharp service center can/should do this. try av solutions in ny. they're really good. www.avsolutionsny.com
Dec 07, 2009 | Sanyo PLC-XP56 Multimedia Projector
Bad convergence. do i need remote to converge unit? i can bring up menu and make those adj's by set top buttons. but i have three misaligned pic's
there is no convergence for these. the lcd panels are fixed. if they are out of alignment, you'll need to replace the entire optical engine. first reset the settings to factory default. see if that helps.
Sep 28, 2009 | InFocus Proxima DP5900 Multimedia...
How do I ADJ the convergence on my PTL555U projector?
These adjustments are internal to the machine, It is not a recommended user adjustment. Typically these are set at the factory under controlled conditions using a known signal source. Also, I'm not 100% sure about your model (I'll investigate further), but it may not be adjustable at all. How far out does the convergence appear to be? Can you see it under normal use conditions or only when using the test pattern?
Thanks,
Dan
Mar 06, 2009 | Panasonic PTL500U Multimedia Projector
Video adjustment on LCD projector
convergence on lcd is a tough issue... you can if you are really good and know what you are doing adjust the panels to correct some convergence issues. but depending on how many hours the unit has, the LCD panels may have warped due to the heat inside the projector, then corrections is pretty impossible.
goto epsons web site,, and find your local service center for help
Jun 24, 2008 | Office Equipment & Supplies
Proxima C160 Color Convergence Issue...
There are no adjustments for convergence in the service menu. The code is: Effect, Blank, Video, Computer, Volume Down, Volume Up.
Jun 01, 2007 | ASK Proxima C160 Multimedia Projector
Help
Your convergence might be out.Go to convergence settings and try the setting and it can be done electronically.
Jan 20, 2007 | Philips ProScreen 4600 Impact Multimedia...
EIKI LC870 Multimedia Projector
there is no convergence on this animal. reset the settings to factory default and set the resolution to match the source. if the colors are way off, you need to adjust the mirrors manually, which is quite an undertaking, and would not recoment doing it yourself.
Jan 02, 2007 | Eiki LC X999 Multimedia Projector
Convergence error on viewsonic projector PJ820
your gonna need to get a service manual from the manufacturer and do a convergence alighnment with the on board generator. Unless some unknowing hands have been inside the unit.?? Contact them here at this link Good Luck service.us@viewsonic.com
May 07, 2006 | ViewSonic Projector PJ802 Pro Multimedia...
184 people viewed this question
Top Boxlight Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Are you a Boxlight Office Equipment and Supply Expert? Answer questions, earn points and help others
